hi All,
I am not able to install TI RTOS 2.16.01.14 on macOS , the installer is not running , and not able to build wolfssl using xdc tools , need suggestion .
regards
chiranth
hi All,
regards
chiranth
I don't have much experience with TI-RTOS installer for macOS. Have you tried other version like 2.16.00.08?
Which XDCtools version do you use? Please make sure to only use XDCTools 3.32.00.06. Any higher versions have known issues with TI-RTOS for Tiva.
Hi Charles ,
2.16.00.08 version didnt run the installer, i am using XDCTools 3.32.00.06 core with JRE , XDCTools is not able to build TI RTOS giving error as the make dosnt contain "%" .
Chiranth
Hi Chiranth,
As much as I would like to help, I don't have much knowledge on how the installer was created let alone for macOS. Since TI-RTOS 2.16.00 was released in 2016, I tend to think the installer will only work with the macOS versions around that time. If you are using the latest macOS versions then there is a good chance of compatibility issue.
Must you work with macOS? Is it possible for you to use Windows?
I don't know if this thread will help you.
Hi Chiranth,
I will close this thread since you have the same post that was already answered. https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1234731/tm4c129encpdt-unable-to-install-tirtos-on-macos
