Part Number: LP-MSPM0G3507
I changed the dependencies to the latest SDK and sysconfig:
And got the following error:
Hey Keith,
Thank you for reporting this. I've conferred with internal MSPM0SDK team and they were able to spot the issue pretty quickly, and it seems to be related to the SYSCTL module specifically in Sysconfig. As a work around, you can utilize the ClockTree tool to setup your clocks and it should generate the correct pin defines. This is being filed internally to be fixed.
As a reminder, the ClockTree tool can be found in Sysconfig as a left side tab. MAke sure the "Use Clock Tree" button is selected within SYSCTL for the Clock Tree to override SYSCTL settings. You may need to take the extra step in disballing any Xtals in the SYSCTL portion of Sysconfig as it can sometimes conflict with ClockTree trying to set those pins.
