Part Number: MSPM0G3507
Hi
If I disable some peripheral during sleep using the API, as example:
Hi
Hi Dominik,
No you do not need to re-set these register values when you reset the PWREN bit. In general peripherals should retain their register values if you power them down then back up.
However, certain PD1 peripherals will not retain their register settings if you drop into stop or standby mode.
Please also be aware that you need to wait for 4 ULPCLK cycles after setting PWREN again before you modify peripheral registers:
Brandon Fisher
