Part Number: MSPM0C1104
Other Parts Discussed in Thread: BQ76952
Dear sir,
I am using M0C1104 (TSSOP20 package) for i2c communication. In CSS,I am facing issues in reading memory location using I2c with EEPROM(M24C08) and BQ76952.
I am able to read correct data on some memory locations but on other locations I am getting garbage data.
Tested I2C SCL clock is 100khz /400Khz for EEPROM and 400 KHz for BQ76952.
Function used
I2C_ReadReg(COMMAND, RX_Data, 2);
7 bit I2C_TARGET_ADDRESS = 0x50 ( for eeprom 0xA0 >>1) and 0x08 (for bQ76952 0x10 >> 1)
#include "BQ769x2_protocol.h"
uint8_t RX_Data[4];
volatile uint8_t COMMAND = 0x0E;
int main(void)
SYSCFG_DL_init();
DL_SYSCTL_disableSleepOnExit();
while (1)
Please help what might be the problem for I2C to not work properly.
please provide some sample code for I2C memory read and write with BQ76952
Thank you so much
