Part Number: MSPM0G3507
I'm experiencing this exact same issue. The solution is not provided in the following E2E thread. Can someone post the solution?
Stuart
Stuart
Hi Stuart,
For this issue, the cause of the problem is not setting up the environment correctly.
Please refer to Keil Quick Start Guide and follow the steps to set up correctly.
Yuhao
Yuhao,
As far as I can tell, I have followed the Keil Quick Start Guide instruction exactly. Yet I still have this issue. Do you have any further suggestions? What was the resolution on the other linked E2E thread?
Stuart
Hi Stuart,
The solution for the E2E thread you linked is to follow the Keil Quick Start Guide.
If that does not work, please check if your MSPM0 CMSIS-Pack is latest.
What is the version of Keil you are using?
Yuhao
