Part Number: AM2634
Hi
is it possible to use Debug Trace with only 4 data lines.
could you share Application note for same on how to interface.
Thank You
Abdur Razak.
Part Number: AM2634
Hi
Thank You
Abdur Razak.
Hi Abdul Razak,
Sorry, I am absolutely not clear about your question. Can you explain me in detail what is your hardware connectivity exactly ?
Aakash
Hi Aakash,
Could you share Debugger Part Numbers which support JTAG and 4 - Trace signals. for AM2634
will this support https://www.lauterbach.com/products/LA-3503
Thank You
Abdul Razak.
You already get on-board trace (ETM) with AM2634 through JTAG with a small 32kB buffer. I assume that you mean off-board trace.
In short, I think you need to ask Lauterbach that question but the part you mention is just a debug probe not an off-board trace probe as far as I know. Their software is called TRACE32 but that implies nothing about the features enabled in it. That is a function of the hardware licenses.
I think you need something like an additional PowerTrace module. Regarding the number of trace data pins required, this is a good answer:
