Part Number: RM44L520
Other Parts Discussed in Thread: SYSCONFIG, HALCOGEN
How can I set the RM44L520 MCU from the SYSCONFIG tool?
I'm going to try to assign a PIN allocation using SYSCONFIG tool.
Hi EunKi Kim,
No, you should not use SYSCONFIG, you have to use HALCoGen to generate hardware level drivers for RM44520.
In this HALCoGen you will get PINMUX window to change the pin configurations for the device.
You can download HALCoGen from below link:
HALCOGEN IDE, configuration, compiler or debugger | TI.com
And also refer below highlighted tutorial for to understand how to use basic tools for Hercules devices
Thanks & regards,
Jagadish.
