AM2634: FSM subsystem reset is not working
Part Number: AM2634
During my development I faced a weird issue, The FSM reset was working fine without any problem but lately, I was updating some configuration files in the application. After that the FSM reset is not working.
The MCAL code did not change (I am using MCAL version 9.1.0.0) and I have made many debugging without finding the root cause.
In the older binary, once I step over _wfi() the ECU resets, but no reset in the newer binary happens.
Could you please guide me on that?
 * Function name: Target_R5SS0TriggerSubsystemReset
 * Description  : Function to trigger Subsystem reset.
 * Parameter    : None
 * Return value : None
 * Remarks      : None
 * REQ          : None
static void Target_R5SS0TriggerSubsystemReset (void)
    volatile uint32 regVal;
    ctrlBASE_t*   ptrCTRLRegs;
    regVal = 0U;
    /* Get the base address of the MSS RCM configuration registers */
    ptrCTRLRegs = (ctrlBASE_t*)MCAL_CSL_MSS_CTRL_U_BASE;
    regVal = ptrCTRLRegs->R5SS0_CONTROL;
    CSL_FINS(regVal, MSS_CTRL_R5SS0_CONTROL_RESET_FSM_TRIGGER, 0x7);
    ptrCTRLRegs->R5SS0_CONTROL = regVal;
    /* execute wfi, and reset core0 */
    __wfi();
Yours,
Abdelrhman Afifi
    Can you replicate this issue in Mcal example? Please share your configurations and replicated example code.
    Gunjan
    I did not build the MCAL example, and this was working fine.
    Are there any prerequisites for triggering an FSM reset?
    Yours,
    Abdelrhman Afifi
  • Also, there is no API in the MCAL for triggering a subsystem reset (FSM) to replicate it using the MCAL example.
  • Here is the register dump before stepping over _wfi()
    521177 13
    R PC 0x0000000B 0x701E8E9C
    R SP 0x0000000B 0x701F2B78
    R LR 0x0000000B 0x701EA097
    R CPSR 0x0000000B 0x600001BF
    R R0 0x0000000B 0x50D00000
    R R1 0x0000000B 0x53208000
    R R2 0x0000000B 0x00000300
    R R3 0x0000000B 0x00800000
    R R4 0x0000000B 0x00000007
    R R5 0x0000000B 0x53200010
    R R6 0x0000000B 0x00000000
    R R7 0x0000000B 0x00000000
    R R8 0x0000000B 0x000004BC
    R R9 0x0000000B 0x0004B568
    R R10 0x0000000B 0x00000000
    R R11 0x0000000B 0x000000D0
    R R12 0x0000000B 0x00000000
    R R13 0x0000000B 0x701F2B78
    R R14 0x0000000B 0x701EA097
    R USER_Registers_R8_USER 0x0000000B 0x000004BC
    R USER_Registers_R9_USER 0x0000000B 0x0004B568
    R USER_Registers_R10_USER 0x0000000B 0x00000000
    R USER_Registers_R11_USER 0x0000000B 0x000000D0
    R USER_Registers_R12_USER 0x0000000B 0x00000000
    R USER_Registers_R13_USER 0x0000000B 0x701F2B78
    R USER_Registers_R14_USER 0x0000000B 0x701EA097
    R FIQ_Registers_SPSR_FIQ 0x0000000B 0x600001BF
    R FIQ_Registers_R8_FIQ 0x0000000B 0x000004BC
    R FIQ_Registers_R9_FIQ 0x0000000B 0x0004B568
    R FIQ_Registers_R10_FIQ 0x0000000B 0x00000000
    R FIQ_Registers_R11_FIQ 0x0000000B 0x000000D0
    R FIQ_Registers_R12_FIQ 0x0000000B 0x00000000
    R FIQ_Registers_R13_FIQ 0x0000000B 0x701F2B78
    R FIQ_Registers_R14_FIQ 0x0000000B 0x701EA097
    R Supervisor_Registers_SPSR_SVC 0x0000000B 0x5A0E14AA
    R Supervisor_Registers_R13_SVC 0x0000000B 0x701AAE18
    R Supervisor_Registers_R14_SVC 0x0000000B 0x701C2480
    R Abort_Registers_SPSR_ABT 0x0000000B 0x480F458C
    R Abort_Registers_R13_ABT 0x0000000B 0x701AAF18
    R Abort_Registers_R14_ABT 0x0000000B 0xFA18BE1D
    R IRQ_Registers_SPSR_IRQ 0x0000000B 0x4000013F
    R IRQ_Registers_R13_IRQ 0x0000000B 0x701AAC18
    R IRQ_Registers_R14_IRQ 0x0000000B 0x701E4DBA
    R Undefined_Registers_SPSR_UND 0x0000000B 0x340B8758
    R Undefined_Registers_R13_UND 0x0000000B 0x701AB018
    R Undefined_Registers_R14_UND 0x0000000B 0x9DB1D00F
    R All_Banked_Registers_SPSR_FIQ 0x0000000B 0x600001BF
    R All_Banked_Registers_R8_FIQ 0x0000000B 0x000004BC
    R All_Banked_Registers_R9_FIQ 0x0000000B 0x0004B568
    R All_Banked_Registers_R10_FIQ 0x0000000B 0x00000000
    R All_Banked_Registers_R11_FIQ 0x0000000B 0x000000D0
    R All_Banked_Registers_R12_FIQ 0x0000000B 0x00000000
    R All_Banked_Registers_R13_FIQ 0x0000000B 0x701F2B78
    R All_Banked_Registers_R14_FIQ 0x0000000B 0x701EA097
    R All_Banked_Registers_SPSR_SVC 0x0000000B 0x5A0E14AA
    R All_Banked_Registers_R13_SVC 0x0000000B 0x701AAE18
    R All_Banked_Registers_R14_SVC 0x0000000B 0x701C2480
    R All_Banked_Registers_SPSR_ABT 0x0000000B 0x480F458C
    R All_Banked_Registers_R13_ABT 0x0000000B 0x701AAF18
    R All_Banked_Registers_R14_ABT 0x0000000B 0xFA18BE1D
    R All_Banked_Registers_SPSR_IRQ 0x0000000B 0x4000013F
    R All_Banked_Registers_R13_IRQ 0x0000000B 0x701AAC18
    R All_Banked_Registers_R14_IRQ 0x0000000B 0x701E4DBA
    R All_Banked_Registers_SPSR_UND 0x0000000B 0x340B8758
    R All_Banked_Registers_R13_UND 0x0000000B 0x701AB018
    R All_Banked_Registers_R14_UND 0x0000000B 0x9DB1D00F
    R Debug_Registers_REG_DIDR 0x0000000B 0x77040013
    R Debug_Registers_BPWP_VERSION 0x0000000B 0x00040013
    R Debug_Registers_BPWP_NUM_BP_AVAILABLE 0x0000000B 0x00000008
    R Debug_Registers_BPWP_NUM_BP_WITH_CONTEXT 0x0000000B 0x00000001
    R Debug_Registers_BPWP_FIRST_CONTEXT_BP 0x0000000B 0x00000007
    R Debug_Registers_BPWP_NUM_WP_AVAILABLE 0x0000000B 0x00000008
    R Debug_Registers_BPWP_BP_ADDR0 0x0000000B 0x94AF7E7C
    R Debug_Registers_BPWP_BP_ADDR1 0x0000000B 0x1BE8DB44
    R Debug_Registers_BPWP_BP_ADDR2 0x0000000B 0x88E85680
    R Debug_Registers_BPWP_BP_ADDR3 0x0000000B 0x3E22092C
    R Debug_Registers_BPWP_BP_ADDR4 0x0000000B 0xA3F71F70
    R Debug_Registers_BPWP_BP_ADDR5 0x0000000B 0x25D3E944
    R Debug_Registers_BPWP_BP_ADDR6 0x0000000B 0xD8E8C5C0
    R Debug_Registers_BPWP_BP_ADDR7 0x0000000B 0x2EE506A1
    R Debug_Registers_BPWP_BP_ADDR8 0x0000000B 0x94AF7E7C
    R Debug_Registers_BPWP_BP_ADDR9 0x0000000B 0x1BE8DB44
    R Debug_Registers_BPWP_BP_ADDR10 0x0000000B 0x88E85680
    R Debug_Registers_BPWP_BP_ADDR11 0x0000000B 0x3E22092C
    R Debug_Registers_BPWP_BP_ADDR12 0x0000000B 0xA3F71F70
    R Debug_Registers_BPWP_BP_ADDR13 0x0000000B 0x25D3E944
    R Debug_Registers_BPWP_BP_ADDR14 0x0000000B 0xD8E8C5C0
    R Debug_Registers_BPWP_BP_ADDR15 0x0000000B 0x2EE506A1
    R Debug_Registers_BPWP_BP_CNTL0 0x0000000B 0x045E0186
    R Debug_Registers_BPWP_BP_CNTL1 0x0000000B 0x0F0B0006
    R Debug_Registers_BPWP_BP_CNTL2 0x0000000B 0x111E0006
    R Debug_Registers_BPWP_BP_CNTL3 0x0000000B 0x1B6F0180
    R Debug_Registers_BPWP_BP_CNTL4 0x0000000B 0x063F0182
    R Debug_Registers_BPWP_BP_CNTL5 0x0000000B 0x02670062
    R Debug_Registers_BPWP_BP_CNTL6 0x0000000B 0x037501E2
    R Debug_Registers_BPWP_BP_CNTL7 0x0000000B 0x0D7501E6
    R Debug_Registers_BPWP_BP_CNTL8 0x0000000B 0x045E0186
    R Debug_Registers_BPWP_BP_CNTL9 0x0000000B 0x0F0B0006
    R Debug_Registers_BPWP_BP_CNTL10 0x0000000B 0x111E0006
    R Debug_Registers_BPWP_BP_CNTL11 0x0000000B 0x1B6F0180
    R Debug_Registers_BPWP_BP_CNTL12 0x0000000B 0x063F0182
    R Debug_Registers_BPWP_BP_CNTL13 0x0000000B 0x02670062
    R Debug_Registers_BPWP_BP_CNTL14 0x0000000B 0x037501E2
    R Debug_Registers_BPWP_BP_CNTL15 0x0000000B 0x0D7501E6
    R Debug_Registers_BPWP_WP_ADDR0 0x0000000B 0xEF6CCC64
    R Debug_Registers_BPWP_WP_ADDR1 0x0000000B 0x8CE56010
    R Debug_Registers_BPWP_WP_ADDR2 0x0000000B 0xDA5B2F60
    R Debug_Registers_BPWP_WP_ADDR3 0x0000000B 0xE58A1A50
    R Debug_Registers_BPWP_WP_ADDR4 0x0000000B 0x63FF79A0
    R Debug_Registers_BPWP_WP_ADDR5 0x0000000B 0xD3D5F62C
    R Debug_Registers_BPWP_WP_ADDR6 0x0000000B 0xBBA3DB4C
    R Debug_Registers_BPWP_WP_ADDR7 0x0000000B 0x435E2EE0
    R Debug_Registers_BPWP_WP_ADDR8 0x0000000B 0xEF6CCC64
    R Debug_Registers_BPWP_WP_ADDR9 0x0000000B 0x8CE56010
    R Debug_Registers_BPWP_WP_ADDR10 0x0000000B 0xDA5B2F60
    R Debug_Registers_BPWP_WP_ADDR11 0x0000000B 0xE58A1A50
    R Debug_Registers_BPWP_WP_ADDR12 0x0000000B 0x63FF79A0
    R Debug_Registers_BPWP_WP_ADDR13 0x0000000B 0xD3D5F62C
    R Debug_Registers_BPWP_WP_ADDR14 0x0000000B 0xBBA3DB4C
    R Debug_Registers_BPWP_WP_ADDR15 0x0000000B 0x435E2EE0
    R Debug_Registers_BPWP_WP_CNTL0 0x0000000B 0x1D081ECA
    R Debug_Registers_BPWP_WP_CNTL1 0x0000000B 0x0B120D64
    R Debug_Registers_BPWP_WP_CNTL2 0x0000000B 0x011F1B72
    R Debug_Registers_BPWP_WP_CNTL3 0x0000000B 0x0F0E029E
    R Debug_Registers_BPWP_WP_CNTL4 0x0000000B 0x0F120F54
    R Debug_Registers_BPWP_WP_CNTL5 0x0000000B 0x0A17012E
    R Debug_Registers_BPWP_WP_CNTL6 0x0000000B 0x05150C68
    R Debug_Registers_BPWP_WP_CNTL7 0x0000000B 0x1C1F1122
    R Debug_Registers_BPWP_WP_CNTL8 0x0000000B 0x1D081ECA
    R Debug_Registers_BPWP_WP_CNTL9 0x0000000B 0x0B120D64
    R Debug_Registers_BPWP_WP_CNTL10 0x0000000B 0x011F1B72
    R Debug_Registers_BPWP_WP_CNTL11 0x0000000B 0x0F0E029E
    R Debug_Registers_BPWP_WP_CNTL12 0x0000000B 0x0F120F54
    R Debug_Registers_BPWP_WP_CNTL13 0x0000000B 0x0A17012E
    R Debug_Registers_BPWP_WP_CNTL14 0x0000000B 0x05150C68
    R Debug_Registers_BPWP_WP_CNTL15 0x0000000B 0x1C1F1122
    R System_Registers_CP15_ID_CODE 0x0000000B 0x411FC153
    R System_Registers_CP15_MAIN_ID 0x0000000B 0x411FC153
    R System_Registers_CP15_CACHE_TYPE 0x0000000B 0x8003C003
    R System_Registers_CP15_TCM_TYPE 0x0000000B 0x00010001
    R System_Registers_CP15_MPU_TYPE 0x0000000B 0x00001000
    R System_Registers_CP15_MULTIPROCESSOR_ID 0x0000000B 0xC0000000
    R System_Registers_CP15_PROCESSOR_FEATURE_0 0x0000000B 0x00000131
    R System_Registers_CP15_PROCESSOR_FEATURE_1 0x0000000B 0x00000001
    R System_Registers_CP15_DEBUG_FEATURE_0 0x0000000B 0x00010400
    R System_Registers_CP15_AUXILIARY_FEATURE_0 0x0000000B 0x00000000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_0 0x0000000B 0x00210030
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_1 0x0000000B 0x00000000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_2 0x0000000B 0x01200000
    R System_Registers_CP15_MEMORY_MODEL_FEATURE_3 0x0000000B 0x00000211
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_0 0x0000000B 0x02101111
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_1 0x0000000B 0x13112111
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_2 0x0000000B 0x21232141
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_3 0x0000000B 0x01112131
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_4 0x0000000B 0x00010142
    R System_Registers_CP15_INSTRUCTION_SET_ATTRIBUTE_5 0x0000000B 0x00000000
    R System_Registers_CP15_CURRENT_CACHE_SIZE_ID 0x0000000B 0xF00FE019
    R System_Registers_CP15_CURRENT_CACHE_LEVEL_ID 0x0000000B 0x09200003
    R System_Registers_CP15_CACHE_SIZE_SELECTION 0x0000000B 0x00000001
    R System_Registers_CP15_SYSTEM_CONTROL 0x0000000B 0x00E5187D
    R System_Registers_CP15_AUXILIARY_CONTROL 0x0000000B 0x00000227
    R System_Registers_CP15_COPROCESSOR_ACCESS 0x0000000B 0xC0F00000
    R System_Registers_CP15_DATA_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_INSTRUCTION_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_AUX_DATA_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_AUX_INSTRUCTION_FAULT_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_DATA_FAULT_ADDRESS 0x0000000B 0x00000000
    R System_Registers_CP15_INSTRUCTION_FAULT_ADDRESS 0x0000000B 0x00000000
    R System_Registers_CP15_MPU_REGION_BASE_ADDRESS 0x0000000B 0x50200000
    R System_Registers_CP15_MPU_REGION_SIZE_ENABLE 0x0000000B 0x00000027
    R System_Registers_CP15_MPU_REGION_ACCESS 0x0000000B 0x00001310
    R System_Registers_CP15_MPU_REGION_NUMBER 0x0000000B 0x00000008
    R System_Registers_CP15_TCM_BTCM_REGION 0x0000000B 0x0008001D
    R System_Registers_CP15_TCM_ATCM_REGION 0x0000000B 0x00000025
    R System_Registers_CP15_TCM_TCM_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_PERFORMANCE_MONITOR_CONTROL 0x0000000B 0x41151800
    R System_Registers_CP15_COUNT_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_COUNT_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_OVERFLOW_FLAG_STATUS 0x0000000B 0x00000000
    R System_Registers_CP15_COUNTER_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_CYCLE_COUNT 0x0000000B 0x00000000
    R System_Registers_CP15_EVENT_SELECTION 0x0000000B 0x00000000
    R System_Registers_CP15_PERFORMANCE_MONITOR_COUNT 0x0000000B 0x00000000
    R System_Registers_CP15_USER_ENABLE 0x0000000B 0x00000000
    R System_Registers_CP15_INTERRUPT_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_INTERRUPT_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_SLAVE_PORT_CONTROL 0x0000000B 0x00000000
    R System_Registers_CP15_FCSE_PID 0x0000000B 0x00000000
    R System_Registers_CP15_CONTEXT_ID 0x0000000B 0x00000000
    R System_Registers_CP15_USER_READ_WRITE_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_USER_READ_ONLY_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_PRIVILEDGED_ONLY_THREAD_PROCESS_ID 0x0000000B 0x00000000
    R System_Registers_CP15_SECONDARY_AUXILIARY_CONTROL 0x0000000B 0x00400000
    R System_Registers_CP15_NVAL_IRQ_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_FIQ_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_RESET_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_DEBUG_REQUEST_ENABLE_SET 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_IRQ_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_FIQ_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_RESET_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_NVAL_DEBUG_REQUEST_ENABLE_CLEAR 0x0000000B 0x00000000
    R System_Registers_CP15_BUILD_OPTIONS_1 0x0000000B 0x00080000
    R System_Registers_CP15_BUILD_OPTIONS_2 0x0000000B 0x4ABFC5C7
    R System_Registers_CP15_CORRECTABLE_FAULT_LOCATION 0x0000000B 0x00000000
    R R5SS0_CORE0_TCMA_ROM_R5SS0_CORE0_TCMA_ROM_R5SS0_CORE0_TCMA_ROM_ROM_START_TCMA 0x0000000B 0x70117100
    R R5SS0_CORE0_TCMA_RAM_R5SS0_CORE0_TCMA_RAM_R5SS0_CORE0_TCMA_RAM_RAM_START_TCMA 0x0000000B 0x70117100
    R R5SS0_CORE0_TCMA_RAM_R5SS0_CORE0_TCMA_RAM_R5SS0_CORE0_TCMA_RAM_RAM_END_TCMA 0x0000000B 0x00000000
    R R5SS0_CORE0_TCMB_RAM_R5SS0_CORE0_TCMB_RAM_R5SS0_CORE0_TCMB_RAM_RAM_START_TCMA 0x0000000B 0x00000000
    R R5SS0_CORE0_TCMB_RAM_R5SS0_CORE0_TCMB_RAM_R5SS0_CORE0_TCMB_RAM_RAM_END_TCMA 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CTRL0 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CTRL1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CTRL2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_INTS 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_INTR 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_STATUS_REG 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_INT_OFFSET_REG 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_BUSY 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_PCOUNT_REG1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_SCOUNT_REG1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CURSEC_REG1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_WDTOPLD1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_BCTOPLD1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGL1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGH1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGL1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGH1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGL1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGH1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGL1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGH1 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_PCOUNT_REG2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_SCOUNT_REG2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CURSEC_REG2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_WDTOPLD2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_BCTOPLD2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGL2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGH2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGL2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGH2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGL2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGH2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGL2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGH2 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_PCOUNT_REG3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_SCOUNT_REG3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CURSEC_REG3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_WDTOPLD3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_BCTOPLD3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGL3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGH3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGL3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGH3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGL3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGH3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGL3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGH3 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_PCOUNT_REG4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_SCOUNT_REG4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_CURSEC_REG4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_WDTOPLD4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_BCTOPLD4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGL4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SIGREGH4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGL4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_CRC_REGH4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGL4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_PSA_SECSIGREGH4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGL4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_RAW_DATAREGH4 0x0000000B 0x00000000
    R MCRC0_MCRC0_MCRC0_MCRC_BUS_SEL 0x0000000B 0x00000007
    R MCRC0_MCRC0_MCRC0_MCRC_RESERVED 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_PID 0x0000000B 0x4F400000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED1 0x0000000B 0x4F400000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED2 0x0000000B 0x4F400000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED3 0x0000000B 0x4F400000
    R QSPI0_QSPI0_QSPI0_SYSCONFIG 0x0000000B 0x00000004
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED4 0x0000000B 0x00000004
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED5 0x0000000B 0x00000004
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED6 0x0000000B 0x00000004
    R QSPI0_QSPI0_QSPI0_INTR_STATUS_RAW_SET 0x0000000B 0x00000003
    R QSPI0_QSPI0_QSPI0_INTR_STATUS_ENABLED_CLEAR 0x0000000B 0x00000003
    R QSPI0_QSPI0_QSPI0_INTR_ENABLE_SET 0x0000000B 0x00000003
    R QSPI0_QSPI0_QSPI0_INTR_ENABLE_CLEAR 0x0000000B 0x00000003
    R QSPI0_QSPI0_QSPI0_INTC_EOI 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED7 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED8 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_MSS_QSPI_RESERVED9 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_SPI_CLOCK_CNTRL 0x0000000B 0x80000000
    R QSPI0_QSPI0_QSPI0_SPI_DC 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_SPI_CMD 0x0000000B 0x00FF4001
    R QSPI0_QSPI0_QSPI0_SPI_STATUS 0x0000000B 0x00020000
    R QSPI0_QSPI0_QSPI0_SPI_DATA 0x0000000B 0x03A1293A
    R QSPI0_QSPI0_QSPI0_SPI_SETUP0 0x0000000B 0x0000366B
    R QSPI0_QSPI0_QSPI0_SPI_SETUP1 0x0000000B 0x00020203
    R QSPI0_QSPI0_QSPI0_SPI_SETUP2 0x0000000B 0x00020203
    R QSPI0_QSPI0_QSPI0_SPI_SETUP3 0x0000000B 0x00020203
    R QSPI0_QSPI0_QSPI0_SPI_SWITCH 0x0000000B 0x00000003
    R QSPI0_QSPI0_QSPI0_SPI_DATA1 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_SPI_DATA2 0x0000000B 0x00000000
    R QSPI0_QSPI0_QSPI0_SPI_DATA3 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_CONTROLSS_G0_EPWM0_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMXLINK 0x0000000B 0x04210421
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMXLINK2 0x0000000F 0x0021
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_EPWMXLINKXLOAD 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_CONTROLSS_G0_EPWM1_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMXLINK 0x0000000B 0x08420842
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMXLINK2 0x0000000F 0x0042
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_EPWMXLINKXLOAD 0x0000000F 0x0002
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_CONTROLSS_G0_EPWM2_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMXLINK 0x0000000B 0x0C630C63
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMXLINK2 0x0000000F 0x0063
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_EPWMXLINKXLOAD 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_CONTROLSS_G0_EPWM3_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMXLINK 0x0000000B 0x10841084
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMXLINK2 0x0000000F 0x0084
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_EPWMXLINKXLOAD 0x0000000F 0x0004
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_CONTROLSS_G0_EPWM4_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMXLINK 0x0000000B 0x14A514A5
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMXLINK2 0x0000000F 0x00A5
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_EPWMXLINKXLOAD 0x0000000F 0x0005
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_CONTROLSS_G0_EPWM5_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMXLINK 0x0000000B 0x18C618C6
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMXLINK2 0x0000000F 0x00C6
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_EPWMXLINKXLOAD 0x0000000F 0x0006
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_CONTROLSS_G0_EPWM6_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMXLINK 0x0000000B 0x1CE71CE7
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMXLINK2 0x0000000F 0x00E7
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_EPWMXLINKXLOAD 0x0000000F 0x0007
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_CONTROLSS_G0_EPWM7_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMXLINK 0x0000000B 0x21082108
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMXLINK2 0x0000000F 0x0108
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_EPWMXLINKXLOAD 0x0000000F 0x0008
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_CONTROLSS_G0_EPWM8_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMXLINK 0x0000000B 0x25292529
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMXLINK2 0x0000000F 0x0129
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_EPWMXLINKXLOAD 0x0000000F 0x0009
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_CONTROLSS_G0_EPWM9_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMXLINK 0x0000000B 0x294A294A
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMXLINK2 0x0000000F 0x014A
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_EPWMXLINKXLOAD 0x0000000F 0x000A
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_CONTROLSS_G0_EPWM10_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMXLINK 0x0000000B 0x2D6B2D6B
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMXLINK2 0x0000000F 0x016B
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_EPWMXLINKXLOAD 0x0000000F 0x000B
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_CONTROLSS_G0_EPWM11_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMXLINK 0x0000000B 0x318C318C
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMXLINK2 0x0000000F 0x018C
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_EPWMXLINKXLOAD 0x0000000F 0x000C
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_CONTROLSS_G0_EPWM12_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMXLINK 0x0000000B 0x35AD35AD
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMXLINK2 0x0000000F 0x01AD
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_EPWMXLINKXLOAD 0x0000000F 0x000D
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_CONTROLSS_G0_EPWM13_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMXLINK 0x0000000B 0x39CE39CE
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMXLINK2 0x0000000F 0x01CE
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_EPWMXLINKXLOAD 0x0000000F 0x000E
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_CONTROLSS_G0_EPWM14_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMXLINK 0x0000000B 0x3DEF3DEF
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMXLINK2 0x0000000F 0x01EF
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_EPWMXLINKXLOAD 0x0000000F 0x000F
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_CONTROLSS_G0_EPWM15_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMXLINK 0x0000000B 0x42104210
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMXLINK2 0x0000000F 0x0210
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_EPWMXLINKXLOAD 0x0000000F 0x0010
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_CONTROLSS_G0_EPWM16_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMXLINK 0x0000000B 0x46314631
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMXLINK2 0x0000000F 0x0231
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_EPWMXLINKXLOAD 0x0000000F 0x0011
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_CONTROLSS_G0_EPWM17_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMXLINK 0x0000000B 0x4A524A52
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMXLINK2 0x0000000F 0x0252
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_EPWMXLINKXLOAD 0x0000000F 0x0012
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_CONTROLSS_G0_EPWM18_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMXLINK 0x0000000B 0x4E734E73
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMXLINK2 0x0000000F 0x0273
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_EPWMXLINKXLOAD 0x0000000F 0x0013
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_CONTROLSS_G0_EPWM19_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMXLINK 0x0000000B 0x52945294
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMXLINK2 0x0000000F 0x0294
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_EPWMXLINKXLOAD 0x0000000F 0x0014
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_CONTROLSS_G0_EPWM20_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMXLINK 0x0000000B 0x56B556B5
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMXLINK2 0x0000000F 0x02B5
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_EPWMXLINKXLOAD 0x0000000F 0x0015
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_CONTROLSS_G0_EPWM21_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMXLINK 0x0000000B 0x5AD65AD6
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMXLINK2 0x0000000F 0x02D6
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_EPWMXLINKXLOAD 0x0000000F 0x0016
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_CONTROLSS_G0_EPWM22_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMXLINK 0x0000000B 0x5EF75EF7
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMXLINK2 0x0000000F 0x02F7
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_EPWMXLINKXLOAD 0x0000000F 0x0017
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_CONTROLSS_G0_EPWM23_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMXLINK 0x0000000B 0x63186318
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMXLINK2 0x0000000F 0x0318
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_EPWMXLINKXLOAD 0x0000000F 0x0018
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_CONTROLSS_G0_EPWM24_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMXLINK 0x0000000B 0x67396739
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMXLINK2 0x0000000F 0x0339
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_EPWMXLINKXLOAD 0x0000000F 0x0019
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_CONTROLSS_G0_EPWM25_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMXLINK 0x0000000B 0x6B5A6B5A
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMXLINK2 0x0000000F 0x035A
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_EPWMXLINKXLOAD 0x0000000F 0x001A
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_CONTROLSS_G0_EPWM26_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMXLINK 0x0000000B 0x6F7B6F7B
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMXLINK2 0x0000000F 0x037B
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_EPWMXLINKXLOAD 0x0000000F 0x001B
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_CONTROLSS_G0_EPWM27_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMXLINK 0x0000000B 0x739C739C
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMXLINK2 0x0000000F 0x039C
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_EPWMXLINKXLOAD 0x0000000F 0x001C
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_CONTROLSS_G0_EPWM28_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMXLINK 0x0000000B 0x77BD77BD
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMXLINK2 0x0000000F 0x03BD
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_EPWMXLINKXLOAD 0x0000000F 0x001D
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_CONTROLSS_G0_EPWM29_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMXLINK 0x0000000B 0x7BDE7BDE
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMXLINK2 0x0000000F 0x03DE
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_EPWMXLINKXLOAD 0x0000000F 0x001E
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_CONTROLSS_G0_EPWM30_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBCTL 0x0000000F 0x0083
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMSYNCINSEL 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMSYNCOUTEN 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TRREM 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMXLINK 0x0000000B 0x7FFF7FFF
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMXLINK2 0x0000000F 0x03FF
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETEST 0x0000000F 0x0001
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMREV 0x0000000B 0x03000502
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_HRPWMREV 0x0000000B 0x00000300
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBRED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DBFED 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CMPD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETPS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_RESERVED 0x0000000B 0x00030000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETINTMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETSOCAMIXEN 0x0000000F 0x0003
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_ETSOCBMIXEN 0x0000000B 0x00000003
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_EPWMXLINKXLOAD 0x0000000F 0x001F
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_CONTROLSS_G0_EPWM31_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_CONTROLSS_G1_EPWM0_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_CONTROLSS_G1_EPWM1_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_CONTROLSS_G1_EPWM2_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_CONTROLSS_G1_EPWM3_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_CONTROLSS_G1_EPWM4_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_CONTROLSS_G1_EPWM5_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_CONTROLSS_G1_EPWM6_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_CONTROLSS_G1_EPWM7_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_CONTROLSS_G1_EPWM8_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_CONTROLSS_G1_EPWM9_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_CONTROLSS_G1_EPWM10_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_CONTROLSS_G1_EPWM11_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_CONTROLSS_G1_EPWM12_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_CONTROLSS_G1_EPWM13_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_CONTROLSS_G1_EPWM14_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_CONTROLSS_G1_EPWM15_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_CONTROLSS_G1_EPWM16_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_CONTROLSS_G1_EPWM17_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_CONTROLSS_G1_EPWM18_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_CONTROLSS_G1_EPWM19_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_CONTROLSS_G1_EPWM20_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_CONTROLSS_G1_EPWM21_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_CONTROLSS_G1_EPWM22_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_CONTROLSS_G1_EPWM23_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_CONTROLSS_G1_EPWM24_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_CONTROLSS_G1_EPWM25_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_CONTROLSS_G1_EPWM26_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_CONTROLSS_G1_EPWM27_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_CONTROLSS_G1_EPWM28_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_CONTROLSS_G1_EPWM29_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_CONTROLSS_G1_EPWM30_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TRREM 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETEST 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBRED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DBFED 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CMPD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETPS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_CONTROLSS_G1_EPWM31_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_CONTROLSS_G2_EPWM0_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_CONTROLSS_G2_EPWM1_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_CONTROLSS_G2_EPWM2_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_CONTROLSS_G2_EPWM3_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_CONTROLSS_G2_EPWM4_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_CONTROLSS_G2_EPWM5_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_CONTROLSS_G2_EPWM6_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_CONTROLSS_G2_EPWM7_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_CONTROLSS_G2_EPWM8_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_CONTROLSS_G2_EPWM9_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_CONTROLSS_G2_EPWM10_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_CONTROLSS_G2_EPWM11_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_CONTROLSS_G2_EPWM12_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_CONTROLSS_G2_EPWM13_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_CONTROLSS_G2_EPWM14_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_CONTROLSS_G2_EPWM15_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_CONTROLSS_G2_EPWM16_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_CONTROLSS_G2_EPWM17_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_CONTROLSS_G2_EPWM18_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_CONTROLSS_G2_EPWM19_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_CONTROLSS_G2_EPWM20_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_CONTROLSS_G2_EPWM21_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_CONTROLSS_G2_EPWM22_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_CONTROLSS_G2_EPWM23_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_CONTROLSS_G2_EPWM24_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_CONTROLSS_G2_EPWM25_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_CONTROLSS_G2_EPWM26_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_CONTROLSS_G2_EPWM27_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_CONTROLSS_G2_EPWM28_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_CONTROLSS_G2_EPWM29_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_CONTROLSS_G2_EPWM30_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TRREM 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETEST 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBRED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DBFED 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CMPD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETPS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_CONTROLSS_G2_EPWM31_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_CONTROLSS_G3_EPWM0_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_CONTROLSS_G3_EPWM1_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_CONTROLSS_G3_EPWM2_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_CONTROLSS_G3_EPWM3_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_CONTROLSS_G3_EPWM4_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_CONTROLSS_G3_EPWM5_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_CONTROLSS_G3_EPWM6_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_CONTROLSS_G3_EPWM7_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_CONTROLSS_G3_EPWM8_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_CONTROLSS_G3_EPWM9_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_CONTROLSS_G3_EPWM10_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_CONTROLSS_G3_EPWM11_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_CONTROLSS_G3_EPWM12_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_CONTROLSS_G3_EPWM13_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_CONTROLSS_G3_EPWM14_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_CONTROLSS_G3_EPWM15_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_CONTROLSS_G3_EPWM16_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_CONTROLSS_G3_EPWM17_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_CONTROLSS_G3_EPWM18_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_CONTROLSS_G3_EPWM19_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_CONTROLSS_G3_EPWM20_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_CONTROLSS_G3_EPWM21_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_CONTROLSS_G3_EPWM22_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_CONTROLSS_G3_EPWM23_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMSYNCINSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBCTR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBSTS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMSYNCOUTEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBCTL3 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQTSRCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_PCCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_VCAPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_VCNTCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_HRCNFG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_RESERVED 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_HRCNFG2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_HRPCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TRREM 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_GLDCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_GLDCFG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMXLINK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMXLINK2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETEST 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_HRPWMREV 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCTLA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCTLA2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCTLB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCTLB2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_AQCSFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBREDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBRED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBFEDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DBFED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBPHS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBPRDHR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBPRD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TBPRDHRB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CMPD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_GLDCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_SWVDELVAL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZSEL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZDCSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCTLDCA 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCTLDCB 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZEINT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCBCFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZOSTFLG 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZCBCCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZOSTCLR 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZFRC 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_TZTRIPOUTSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETPS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETFLG 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETCLR 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETFRC 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETINTPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETSOCPS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETCNTINITCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETCNTINIT 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETINTMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETSOCAMIXEN 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_ETSOCBMIXEN 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCACTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCBCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCFCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCCAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCFOFFSET 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCFOFFSETCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCFWINDOW 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCFWINDOWCNT 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_BLANKPULSEMIXSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCCAPMIXSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCCAP 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCAHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCALTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCBHTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_DCBLTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CAPCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CAPGATETRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CAPINTRIPSEL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CAPTRIPSEL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_SPARE1 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_SPARE2 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMLOCK 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_HWVDELVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_VCNTVAL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMPCTL1 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XLOADCTL 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_EPWMXLINKXLOAD 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XREGSHDW1STS 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XREGSHDW2STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XREGSHDW3STS 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP1_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP2_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP3_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP4_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP5_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP6_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP7_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XCMP8_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_CONTROLSS_G3_EPWM24_XTBPRD_ACTIVE 0x0000000B 0x00000000
    R CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_TBCTL 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_TBCTL2 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_RESERVED 0x0000000F 0x0000
    R CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_CONTROLSS_G3_EPWM25_EPWMSYNCINSEL 0x0000000F 0x0000
