TMS570LC4357: FlashAPI driver code
Part Number: TMS570LC4357
The FEE driver makes calls to the Flash APIs. I am linking the code to the flash driver. However I need access to the source code for the Flash API as  for a Safety Critical Systems we need the source code to characterise it and remove any dead/deactivated code. How/where can I get access to the flash driver code for F021_API_Cortex_BE_L2FMC_V3D16.lib?
  • Hi Veena,
    TI does not normally distribute the source code. The reason is that modifying the code can potentially impact the flash in the devices. A modified API must not be used in your application. For creating a flash programming solution, the flash API library must be used as provided by TI.
    For certification purposes we can provide source code to the customer, if they have a valid NDA with TI.
    Thanks & regards,
    Jagadish.
