Part Number: TM4C1290NCPDT
Dear Expert
Cross validation: Serial number 71901887LTF240901660558 can be burned normally/Serial number 71901887LTF24090160621 burned NG
1) After swapping two TM4C129ENCPDTI3R chips, the BMS board that could be programmed normally failed to be programmed, while the BMS board that could not be programmed normally could be programmed normally;
2) After replacing the BMS board that cannot be burned after swapping with a new TM4C129ENCPDTI3R chip, it can be burned normally.
