Part Number: AM2432
Other Parts Discussed in Thread: LP-AM243
My customer is now evaluating the EtherCAT stack provided by TI, but DC synchronization error occurred.
- Where, what or how can they confirm that DC synchronization is working correctly with the source code on LP-AM243?
- The specifications of the EtherCAT Slave Stack provided by TI can be found at the following URL. How was the DC Synchronous 50us confirmed ?
https://dev.ti.com/tirex/explore/content/ind_comms_sdk_am243x_09_02_00_15/docs/am243x/ethercat_slave/ethercat_datasheet.html
- DC Sync Error doesn’t occur on the EtherCAT Slave Beckhoff SSC Demo. Is any setting required on TI EtherCAT stack ?
< Environment >
SDK : ind_comms_sdk_am243x_9_02_00_15
Program : ethercat_slave_demo (Default)
AM243x-lp ASSY: PROC109A(001)
Control period : 2ms
Connecting Servo Amp as the first slave and LP-AM243x as the second slave
< Phenomena >
DC Sync Error is shown on the following object dictionalies.
0x1C33:20, 0x1C32:20 Sync Error always becomes True.
0x1C33:0C, 0x1C32:0C Cycle Time Too Small always is incremented.
The above parameters on Servo Amp are correct.
Thanks and regards,
Hideaki
