Part Number: MCU-PLUS-SDK-AM243X
Hi
Sysconfig becomes slow as when we add more details to it, like I/O and peripherals.
Is anything done?
Rasty
Hi
Is anything done?
Rasty
Hi Rasty,
Please tell which MCU+SDK are you using?
What all peripherals have you added? How much delay are you seeing with peripherals and without peripherals?
Tushar
Hi
We use motor_control_sdk_am243x_09_01_00_06
As you can see, If I just change click in list of pad for GPIO, sysconfig freezes for 2 minutes.
Rasty
Hi Rasty,
Can you please tell is it happening with all GPIO pins or a specific pin is creating the issue?
Is it happening when configured GPIO instance reaches to a specific number? E.g. configured 5 GPIO instance and the 6th one creating problem.
Tushar
Hi Tushar
It does not matter. Everything I touch is slow.
Can share with you our sysconfig. Privately if possible.
Rasty
Hi Rasty,
It would be really helpful. You can provide me the file on E2E private chat.
Tushar
Hi Rasty,
I have checked my messages and it seems that I haven't received any file from you. Can you please double check once?
Meanwhile, I have just checked the release notes on MCU+SDK where Sysconfig crash issues exist when large number of GPIOs are added.
This issue requires fix in the Sysconfig device data itself. The issue has been fixed in the SDK v09.02 and Sysconfig v1.20.
Please refer below image.
Please refer RELEASE_NOTES_09_02_00 for details.
Please try once with the SDK v09.02 and Sysconfig v1.20 and update the results.
Tushar
