Other Parts Discussed in Thread: TM4C1233H6PGE
Steps:
Fresh install of CCS Version: 20.2.0.12__1.8.0. Prompted by CCS that updates were available. Went ahead and performed the updates.
Attempted a project import from v 11.2.0 and got an error from Ccs-server popup indicating to check the log file, so the following is a direct copy and paste. Project cannot be imported as it appears to be missing some sort of device dependency. Please advise. Kind regards,
Brad
!SESSION 2025-06-26 16:36:52.469 -----------------------------------------------
eclipse.buildId=unknown
java.version=21.0.6
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2020\ccs\eclipse\ccs.preferences.ini -ccs.socketPath \\.\pipe\712212d6c3ef345ff2d4c4db92782335.sock -ccs.workspaceFolderPaths c:\Users\10000246\workspace_ccstheia;c:\dev -ccs.defaultImportDestinationPath c:\Users\10000246\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop
Command-line arguments: -os win32 -ws win32 -arch x86_64 -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2020\ccs\eclipse\ccs.preferences.ini -data C:\Users\10000246\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\712212d6c3ef345ff2d4c4db92782335 -ccs.socketPath \\.\pipe\712212d6c3ef345ff2d4c4db92782335.sock -ccs.workspaceFolderPaths c:\Users\10000246\workspace_ccstheia;c:\dev -ccs.defaultImportDestinationPath c:\Users\10000246\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop
!ENTRY com.ti.ccs.core 1 0 2025-06-26 16:36:55.572
!MESSAGE [ccs.trace] CCSServer> IDE session in progress: b596f191-6e8a-468f-a5af-c4887a4f6e94 (server v20.2.0.202505162334)
!ENTRY com.ti.ccs.project 1 0 2025-06-26 16:37:30.513
!MESSAGE File devices/DA830-DA828.xml does not exist. Was included by file C:\ti\ccs2020\ccs\ccs_base\common\targetdb\boards\dskda830.xml
!ENTRY org.eclipse.osgi 4 0 2025-06-26 16:37:34.953
!MESSAGE Application error
!STACK 1
java.lang.NullPointerException: Cannot invoke "String.matches(String)" because the return value of "java.lang.Throwable.getMessage()" is null
at com.ti.ccs.core.LogFilterManager$2.run(LogFilterManager.java:122)
at com.ti.ccs.core.LogFilterManager$XLog.log(LogFilterManager.java:59)
at org.eclipse.core.internal.utils.Policy.log(Policy.java:160)
at org.eclipse.core.internal.resources.Filter.match(Filter.java:67)
at org.eclipse.core.internal.resources.Filter.filterExcludes(Filter.java:160)
at org.eclipse.core.internal.resources.Filter.filter(Filter.java:115)
at org.eclipse.core.internal.resources.Resource.filterChildren(Resource.java:1994)
at org.eclipse.core.internal.resources.Resource.filterChildren(Resource.java:1957)
at org.eclipse.core.internal.localstore.UnifiedTree.getLocalList(UnifiedTree.java:364)
at org.eclipse.core.internal.localstore.UnifiedTree.addChildren(UnifiedTree.java:148)
at org.eclipse.core.internal.localstore.UnifiedTree.addNodeChildrenToQueue(UnifiedTree.java:254)
at org.eclipse.core.internal.localstore.UnifiedTree.accept(UnifiedTree.java:120)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refreshResource(FileSystemResourceManager.java:978)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.refresh(FileSystemResourceManager.java:961)
at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1568)
at org.eclipse.core.internal.resources.Project.open(Project.java:1088)
at org.eclipse.core.internal.resources.Project.open(Project.java:1113)
at com.ti.ccs.project.services.ProjectImporter.internalImportProject(ProjectImporter.java:437)
at com.ti.ccs.project.services.ProjectImporter$1.run(ProjectImporter.java:346)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2315)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2340)
at com.ti.ccs.project.services.ProjectImporter.importProject(ProjectImporter.java:341)
at com.ti.ccs.project.services.ProjectImporter.importProject(ProjectImporter.java:270)
at com.ti.ccs.server.core.WorkspaceSynchronizer.initializeWorkspaceFolder(WorkspaceSynchronizer.java:526)
at com.ti.ccs.server.core.WorkspaceSynchronizer.initialize(WorkspaceSynchronizer.java:366)
at com.ti.ccs.server.CCSServer.startUp(CCSServer.java:407)
at com.ti.ccs.server.CCSServer.start(CCSServer.java:288)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
!ENTRY com.ti.ccs.project 4 0 2025-06-26 16:37:35.260
!MESSAGE An internal error was logged by 'com.ti.ccs.project'.
!STACK 0
at org.eclipse.core.internal.resources.Resource.isFilteredWithException(Resource.java:1940)
at org.eclipse.core.internal.resources.Resource.isFiltered(Resource.java:1912)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.allResourcesFor(FileSystemResourceManager.java:235)
at org.eclipse.core.internal.resources.WorkspaceRoot.findContainersForLocationURI(WorkspaceRoot.java:79)
at org.eclipse.core.internal.resources.WorkspaceRoot.findContainersForLocationURI(WorkspaceRoot.java:72)
at org.eclipse.core.internal.resources.WorkspaceRoot.findContainersForLocation(WorkspaceRoot.java:67)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.getBuildFullPath(ManagedBuildManager.java:2473)
at org.eclipse.cdt.managedbuilder.internal.core.Builder.getDefaultOutputSettings(Builder.java:2640)
at org.eclipse.cdt.managedbuilder.internal.core.Builder.getOutputEntries(Builder.java:2624)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.BuildBuildData.getOutputDirectories(BuildBuildData.java:58)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultBuildData.copySettingsFrom(CDefaultBuildData.java:58)
at org.eclipse.cdt.internal.core.settings.model.CBuildSettingCache.<init>(CBuildSettingCache.java:45)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.copyBuildData(CConfigurationDescriptionCache.java:204)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultConfigurationData.copySettingsFrom(CDefaultConfigurationData.java:101)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:129)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:199)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:511)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:242)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:376)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:358)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.findBuildInfo(ManagedBuildManager.java:1682)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.getBuildInfo(ManagedBuildManager.java:1814)
at com.ti.ccs.project.ProjectCoreUtils.getBuildInfo(ProjectCoreUtils.java:304)
at com.ti.ccs.project.ProjectCoreUtils.getBuildInfo(ProjectCoreUtils.java:291)
at com.ti.ccs.project.ProjectCoreUtils.getActiveBuildConfiguration(ProjectCoreUtils.java:580)
at com.ti.ccs.project.ProjectStateListener.onProjectImported(ProjectStateListener.java:162)
at com.ti.ccs.project.model.ProjectStateMonitor$ResourceChangeListener$6.visit(ProjectStateMonitor.java:561)
at com.ti.ccs.project.model.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:1081)
at com.ti.ccs.project.model.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:559)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:305)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:295)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:158)
at org.eclipse.core.internal.resources.Workspace.broadcastBuildEvent(Workspace.java:367)
at org.eclipse.core.internal.events.AutoBuildJob$AutoBuildOffJob.run(AutoBuildJob.java:326)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.core.resources 4 2 2025-06-26 16:37:35.342
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:352)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:345)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:574)
at org.eclipse.cdt.core.model.CoreModel.getProjectDescription(CoreModel.java:237)
at com.ti.ccs.project.model.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:507)
!ENTRY org.eclipse.core.resources 4 2 2025-06-26 16:37:35.351
!STACK 0
at com.ti.ccs.project.model.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:579)
at org.eclipse.core.internal.events.AutoBuildJob$AutoBuildOffJob.run(AutoBuildJob.java:327)
!ENTRY org.eclipse.core.jobs 2 2 2025-06-26 16:37:36.103
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: com.ti.ccs.server.core.WorkspaceSynchronizer$WorkspaceFolderWatcherJob
