Part Number: MCU-PLUS-SDK-AM243X
Hello!
With a new board, I am currently working on once again trying to run the USB CDC Echo example project. Currently, I am on the step of flashing the module after setting up the UART terminal. I have confirmed multiple times that COM5 is the UART port (as noticed by the 'cccs' being printed out on the terminal) and was able to successfully flash (with the success message). However, after powering down/removing all connections from the board to change the bootmode to OSPI, then repowering the board, COM5 does not print out the expected message- it just remains flat/still. Is there a step that is missing here, or some other command I should have run? Thank you!
For reference, this is what I am looking at:
Thank you!
