AM2634: AM2634COLFHAZCZR with DP83869HM PHY bringup
Part Number: AM2634
Other Parts Discussed in Thread: DP83869HM, SYSCONFIG
Hi Team
I am currently working on the AM2634COLFHAZCZR custom board with DP83869HM PHY bring-up, and I have installed the software packages from the link below.
www.ti.com/.../08.05.00.24
After opening the Ethernet examples, I want to know which example is the simplest and most suitable for Ethernet bring-up.
My goal is only basic Ethernet bring-up.
I tested one of the examples, but it is not working on my custom board.
C:\ti\mcu_plus_sdk_am263x_08_05_00_24\examples\networking\lwip\enet_lwip_cpsw\am263x-cc\r5fss0-0_freertos
I need guidance on how to edit the example.syscfg file — specifically how to configure Ethernet and the PHY in the SysConfig file.
Please provide a step-by-step process, including any changes required in the example code and how to modify the project according to my custom board and PHY.
Could you please suggest this?
  • Please use the latest version of SDK 11.01
    https://www.ti.com/tool/download/MCU-PLUS-SDK-AM263X/11.01.00.19
    It would be highly recomended to use this as the version you are using it more than 2 yrs old
  • Please provide a step-by-step process, including any changes required in the example code and how to modify the project according to my custom board and PHY.
    Please refer to this  software-dl.ti.com/.../custom_enetphy_guide.html
  • Hi Nilabh Anand
    I have installed this version and chosen the example listed below.
    C:\ti\mcu_plus_sdk_am263x_11_01_00_19\source\networking\enet\core\examples\lwip\enet_lwip_cpsw\am263x-cc\r5fss0-0_freertos.
    I edited the example.syscfg file based on my PHY (DP83869HM). After making these changes, I rebuilt the project and flashed it to the board.
    The UART log is showing only this output, and I am not getting an IP address. Flash successfully completed log.
    Flash Sucessfully log
    Cortex_R5_0: GEL Output: Loading Gel Files on R5F0
    Cortex_R5_0: GEL Output: Gel files loading on R5F0 Complete
    Cortex_R5_0: GEL Output: ***OnTargetConnect() Launched***
    Cortex_R5_0: GEL Output: AM263x Initialization Scripts Launched.
    Please Wait...
    Cortex_R5_0: GEL Output: AM263x_Cryst_Clock_Loss_Status() Launched
    Cortex_R5_0: GEL Output: Crystal Clock present
    Cortex_R5_0: GEL Output: AM263x_SOP_Mode() Launched
    Cortex_R5_0: GEL Output: SOP MODE = 0x00000000
     QSPI - 4S Functional boot mode
    Cortex_R5_0: GEL Output: AM263x_Read_Device_Type() Launched
    Cortex_R5_0: GEL Output: EFuse Device Type Value = 0x000000AA
    Cortex_R5_0: GEL Output: AM263x_Check_supported_mode() Launched
     The Device supports both LockStep & Dual Core mode
     mode = 1
    Cortex_R5_0: GEL Output: MSS_CTRL Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_TOP_RCM Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_RCM Control Registers Unlocked
    Cortex_R5_0: GEL Output: MSS_IOMUX Control Registers Unlocked
    Cortex_R5_0: GEL Output: TOP_CTRL Control Registers Unlocked
    *** R5FSS0 DualCore Reset ***
    *** R5FSS1 DualCore Reset ***
    Cortex_R5_0: GEL Output: R5F ROM Eclipse
    Cortex_R5_0: GEL Output: R5FSS0_0 Released
    Cortex_R5_0: GEL Output: R5FSS0_1 Released
    Cortex_R5_0: GEL Output: R5FSS1_0 Released
    Cortex_R5_0: GEL Output: R5FSS1_1 Released
     All R5F Cores Released for program load
    Cortex_R5_0: GEL Output: L2 Mem Init Complete
    Cortex_R5_0: GEL Output: MailBox Mem Init Complete
    Cortex_R5_0: GEL Output: *********** R5FSS0/1 Dual Core mode Configured********
    Cortex_R5_0: GEL Output: CORE PLL Configuration Complete
    Cortex_R5_0: GEL Output: PER PLL Configuration Complete
    Cortex_R5_0: GEL Output: SYS_CLK DIVBY2
    Cortex_R5_0: GEL Output: DPLL_CORE_HSDIV0_CLKOUT0 selected as CLK source for R5FSS & SYS CLKs
     CLK Programmed R5F=400MHz and SYS_CLK=200MHz
     *** Enabling Peripheral Clocks ***
    Cortex_R5_0: GEL Output: Enabling RTI[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling RTI_WDT[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling UART[0:5]/LIN[0:5] Clocks
    Cortex_R5_0: GEL Output: Enabling QSPI Clocks
    Cortex_R5_0: GEL Output: Enabling I2C Clocks
    Cortex_R5_0: GEL Output: Enabling TRACE Clocks
    Cortex_R5_0: GEL Output: Enabling MCAN[0:3] Clocks
    Cortex_R5_0: GEL Output: Enabling GPMC Clocks
    Cortex_R5_0: GEL Output: Enabling ELM Clocks
    Cortex_R5_0: GEL Output: Enabling MMCSD Clocks
    Cortex_R5_0: GEL Output: Enabling MCSPI[0:4] Clocks
    Cortex_R5_0: GEL Output: Enabling CONTROLSS Clocks
    Cortex_R5_0: GEL Output: Enabling CPTS Clocks
    Cortex_R5_0: GEL Output: Enabling RGMI[5,50,250] Clocks
    Cortex_R5_0: GEL Output: Enabling XTAL_TEMPSENSE_32K Clocks
    Cortex_R5_0: GEL Output: Enabling XTAL_MMC_32K Clocks
     ***All IP Clocks are Enabled***
    Cortex_R5_0: AM2634
    Cortex_R5_0: Board Selected : CC
    Cortex_R5_0: GEL Output: CPU https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1620224/am2634-am2634colfhazczr-with-dp83869hm-phy-bringup/6248581#reset (soft reset) has been issued through GEL.
  • Hi Nilabh Anand
    I am checking the static IP process on Ethernet. I have enabled it.
    /* uncomment the next two lines for Static IP */
    #define USE_DHCP 0
    #define USE_AUTOIP 0
    The remaining code was not changed, but the Ethernet is still not detected.
    In test.c file
    const ip_addr_t gStaticIP[IP_ADDR_POOL_COUNT]               =  { IPADDR4_INIT_BYTES(192, 168, 2, 200), /* For NetifIdx = 0 */
        IPADDR4_INIT_BYTES(  10,  64,  2, 200),}; /* For NetifIdx = 1 */
    const ip_addr_t gStaticIPGateway[IP_ADDR_POOL_COUNT] =  { IPADDR4_INIT_BYTES(192, 168, 2, 100), /* For NetifIdx = 0 */
        IPADDR4_INIT_BYTES(  10,   64, 2, 100),}; /* For NetifIdx = 1 */
    const ip_addr_t gStaticIPNetmask[IP_ADDR_POOL_COUNT] =  { IPADDR4_INIT_BYTES(255,255,255,0), /* For NetifIdx = 0 */
  • Have you set the local IP address of your machine to local IP address and gateway
  • Also can you attach the UART logs from the application, that will help me see the status of application
  • Hi Nilabh Anand
    I have configured the local IP address and gateway on my PC as follows:
    IP address: 192.168.1.100
    Gateway: 192.168.2.1
    UART logs are not coming, just one log only coming.
  • Hi Nilabh Anand
    I enabled debug logs in #include "lwipopts.h", but the debug logs are not appearing. I have attached my project files here. Please check and let me know if any modifications are required.
    i am looking for UART logs from application, which should be like below:
    dev.ti.com/.../EXAMPLES_ENET_LWIP_CPSW_TCPCLIENT.html
    CPSW LWIP TCP CLIENT
    EnetPhy_bindDriver:1729
    PHY 3 is alive
    PHY 12 is alive
    Starting lwIP, local interface IP is dhcp-enabled
    Host MAC address-0 : 70:ff:76:1e:7e:52
    [LWIPIF_LWIP] NETIF INIT SUCCESS
    Enet IF UP Event. Local interface IP:0.0.0.0
    [LWIPIF_LWIP] Enet has been started successfully
    Waiting for network UP ...
    Cpsw_handleLinkUp:1323
    MAC Port 1: link up
    Network Link UP Event
    Enet IF UP Event. Local interface IP:192.168.1.10
    Network is UP ...
    TCP Client Menu:
    Enter TCP server IPv4 address:(example: 192.168.101.100)
    192.168.1.20
    IP eneterd is: 192.168.1.20
    <<<< ITERATION 1 >>>>
    Connecting to: 192.168.1.20:8888
    Connection with the server is established
    "Hello over TCP 1" was sent to the Server
    Successfully received the packet 1
    "Hello over TCP 2" was sent to the Server
    Successfully received the packet 2
    "Hello over TCP 3" was sent to the Server
    Successfully received the packet 3
    "Hello over TCP 4" was sent to the Server
    Successfully received the packet 4
    "Hello over TCP 5" was sent to the Server
    Successfully received the packet 5
    Connection closed
    <<<< ITERATION 2 >>>>
    Connection closed
  • Hi Nibah Anand
    I am currently working on the Static IP method. I have shared the UART log. When I try to ping the IP address, it shows ‘Destination Unreachable.
    I given my PC address: 192.168.1.125
    Board IP address: 192.168.1.200
    In Static IP address
        IPADDR4_INIT_BYTES(192,168,1,200),   // Board IP
        IPADDR4_INIT_BYTES(10,64,1,200),
        IPADDR4_INIT_BYTES(192,168,1,1),     // Router Gateway
        IPADDR4_INIT_BYTES(10,64,1,1),
        IPADDR4_INIT_BYTES(255,255,252,0),
  • I see link call back up missing in your logs,
    That means LwiP has not detected any link, that is the cause of the ping fails.
  • Hi Nilabh Anand
    I have shared my latest log, but the ping is not working. I need some information based on this. Please let me know what the issue might be and whether any changes are required in the software code or in the SysConfig file.
    Uart Log
          ENET LWIP App
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 2
    Mdio_open:318
    Open MAC port 1
    PHY 3 is alive
    [0]: Starting lwIP, local interface IP is 192.168.1.200
    Host MAC address-0 : 70:ff:76:1d:ec:f2
    [0]status_callback==UP, local interface IP is 192.168.1.200
    UDP server listening on port 5001
    Cpsw_handleExternalPhyLinkUp:1044
    [0] link_callback==UP
          7.733s : CPU load =   7.09 %
         12.733s : CPU load =   1.89 %
         17.733s : CPU load =   1.87 %
         22.733s : CPU load =   1.87 %
         27.733s : CPU load =   1.86 %
         32.733s : CPU load =   1.86 %
         37.733s : CPU load =   1.86 %
         42.733s : CPU load =   1.86 %
         47.733s : CPU load =   1.86 %
         52.733s : CPU load =   1.86 %
         57.733s : CPU load =   1.86 %
         62.733s : CPU load =   1.86 %
         67.733s : CPU load =   1.86 %
         72.733s : CPU load =   1.86 %
         77.733s : CPU load =   1.86 %
         82.733s : CPU load =   1.86 %
         87.733s : CPU load =   1.86 %
         92.733s : CPU load =   1.86 %
         97.733s : CPU load =   1.86 %
    Later, I changed the PING value to 1, but I am getting an log error as shown below.[lwipcfg.h file]
    #define LWIP_PING_APP 1
    // I changed PING value is 1, log is
          ENET LWIP App
    Mdio_open:318
    Open MAC port 1
    PHY 3 is alive
    UDP server: Error creating Socket
  • Please find the attached schematic for our custom board. Could you kindly review it, particularly at the Ethernet PHY level . Also, I would appreciate it if    could forward this request to the appropriate Ethernet PHY team on the forum for further verification.
    e2e.ti.com/.../6254991
    7558.CUSTOM_BOARD-REV02.pdf
    Thank you for your support.
    It would be better to create a thread in the ethernet phy forum specifically, as I am not aware of which PHY expert to be looped in. I would really appreciate if you can do the same.
  • Later, I changed the PING value to 1, but I am getting an log error as shown below.[
    This is not needed, please revert it back, Ping  is enabled by default in the lwip stack.
    Can you try to run the examples to see if phy and mac loopback are working or not:
    software-dl.ti.com/.../EXAMPLES_ENET_CPSW_LOOPBACK.html
  • Hi Nilabh Anand
    Ping is not working and the loopback test is also failing. I have attached the log here. Please let me know what the possible issue might be and whether any changes are required in the software code or in the SysConfig file.
  • Hi Nilabh Anand,
    I hope you are doing well.
    I have documented all the SysConfig changes that were made to the example project in order to bring up Ethernet and attempt ping functionality on our custom board. I am attaching the detailed document along with the code zip file for your reference.
    Could you please review the document and the attached code from your end and also kindly verify it with your team/experts? We would greatly appreciate your guidance if any additional corrections or configurations are required.
    We are deeply expecting  your support would help us move forward and close this activity.
    Syscnfg file.docx
    enet_lwip_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang (1).zip
    I reviewed your docx file. Can you please help me with the below data:
    1. PHY Loopback example:
    First run the PHY loopback example:
    1.1 make sure your hardware connections are fine,
    1.2 make sure you see PHY link up and PHY alive logs
    1.3 Please share the application logs that you see, compare with the logs here: software-dl.ti.com/.../EXAMPLES_ENET_CPSW_LOOPBACK.html
    1.4 Please share the CPSW_STATS after your application has executed (Even if failed).
    Steps to get CPSW_STATS: https://dev.ti.com/tirex/explore/node?node=A__AaBu6ik6ZY8v2032wjLx6Q__AM26X-ACADEMY__t0CaxbG__LATEST
    2. MAC Loopback example
    Next, run the MAC Loopback example:
    2.1 make sure your hardware connections are fine,
    2.2 make sure you see PHY link up and PHY alive logs, MAC Port open logs. compare with the logs here: software-dl.ti.com/.../EXAMPLES_ENET_CPSW_LOOPBACK.html
    2.3 Please share the application logs that you see
    2.4 Please share the CPSW_STATS after your application has executed (Even if failed).
    Steps to get CPSW stats: https://dev.ti.com/tirex/explore/node?node=A__AaBu6ik6ZY8v2032wjLx6Q__AM26X-ACADEMY__t0CaxbG__LATEST
    3. LWIP example:
    When running LWIP example, once you get the IP address, try to ping the device, once you see ping failure, halt the core and get the LWIP stats.
    Follow the steps here to get lwip stats: dev.ti.com/.../node
    Please share the above stats, which will help us understand the exact Ethernet behavior here
    Also, for the PHY part, requesting to create a separate thread in the PHY forum for quicker support.
    Shaunak
  • Hi Shaunak Deshpande
    I have attached the debug log. It shows that there are no transmit or receive bits. Could you please help me check which configuration needs to be set in the SysConfig file?
    The above means, no packets were recieved by the LwIP stack. Before we jump to sysconfig/ Software , we will have to make sure the Ethernet data-paths are working fine.
    Can you also share CPSW_STATS to see if the CPSW hardware received any packets?
    Shaunak
    I have documented all the SysConfig changes for your reference. Please review it and let me know if any changes are required.
    Debug log.docx
    EEPROM is required to store the MAC address. Since my custom board does not have an EEPROM, if I enable Auto MAC assignment in the SysConfig file, will an EEPROM be required?
  • Hi Pavan,
    We will have to modify the sysconfig template file as well, i will share the steps. The SDK examples are created for the default TI Eval kits which by default have the MAC address stored in the EEPROM. We will basically have to remove the dependency of sysconfig template files on the EEPROM APIs to read MAC address. Even if Auto-MAC assignment is enabled, at run-time it wont read from eeprom but to avoid build errors, we need to remove the EEPROM references.
    Shaunak
    Thank you for your reply. Could you please share the detailed steps? It would be very helpful to move forward in project.
  • Hi Pavan,
    I will provide this by end of the day today.
    Shaunak
  • Hi Shaunak,
    Case 1: EEPROM Enabled (Default), MAC is Manual Entry
    • Custom Board:PING is not working.
    • EVL Board: PING is working.
    Case 2: CUSTOM_BOARD Option Enabled in SysConfig, MAC is Manual Entry
    • Custom Board: PING is not working.
    • EVL Board: Debug logs are not appearing.
    As per our understanding, since we are using the same components, the behavior should be the same for both the EVM board and our custom board.
    Kindly confirm if this behavior is expected and advise on the correct configuration to be used.
          ENET LWIP App
    Open MAC port 1
    Mdio_normal_ioctl_handler_ENET_MDIO_IOCTL_C22_ASYNC_READ_COMPLETE:396
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    Mdio_normal_ioctl_handler_ENET_MDIO_IOCTL_C22_ASYNC_WRITE_COMPLETE:471
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
          7.602s : CPU load =   3.64 %
         12.602s : CPU load =   0.74 %
         17.602s : CPU load =   0.74 %
         22.602s : CPU load =   0.74 %
         27.602s : CPU load =   0.74 %
         32.602s : CPU load =   0.74 %
         37.602s : CPU load =   0.74 %
         42.602s : CPU load =   0.74 %
         47.602s : CPU load =   0.74 %
         52.602s : CPU load =   0.74 %
         57.602s : CPU load =   0.74 %
    EVM.log
          ENET LWIP App
    Open MAC port 1
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
    EnetMod_ioctl:1603
          8.594s : CPU load =   3.86 %
         13.594s : CPU load =   0.74 %
         18.594s : CPU load =   0.74 %
         23.594s : CPU load =   0.74 %
         28.594s : CPU load =   0.74 %
         33.594s : CPU load =   0.74 %
         38.594s : CPU load =   0.74 %
         43.594s : CPU load =   0.74 %
         48.594s : CPU load =   0.74 %
         53.594s : CPU load =   0.74 %
         58.594s : CPU load =   0.74 %
         63.594s : CPU load =   0.74 %
         68.594s : CPU load =   0.74 %
         73.594s : CPU load =   0.74 %
         78.594s : CPU load =   0.74 %
         83.594s : CPU load =   0.74 %
         88.594s : CPU load =   0.74 %
         93.594s : CPU load =   0.74 %
         98.594s : CPU load =   0.74 %
        103.594s : CPU load =   0.74 %
        108.594s : CPU load =   0.74 %
    I've reached out to you over email. Lets get no a quick call, i would like to run some experiments on the custom board to verify the functionality.
    Shaunak
  • Hi Shaunak,
    Thanks for reaching out. I’m available for a quick call—please let me know a convenient time. I’ll keep the custom board ready for testing.
    please share team meeting link
    Thank you
    Pavan kumar
  • Hi Shaunak,
    As discussed in the meeting, could you please share the appropriate contact person’s email so that I can connect them with my TS team? They will proceed with the schematic review as per our discussion.
    Thank you
    Pavan kumar
  • Hi Shaunak
    We have tested with the latest version (11.0.1). The MAC loopback method is working fine, and we are currently checking the PHY loopback as well.
    I have shared the MAC loopback results—please have a look.
     Enet Loopback: Iteration 1
    CPSW_3G Test
    0 From 4 To 2
    Open MAC port 1
    Setting in NO-PHY mode for MAC port 1
    initQs() txFreePktInfoQ initialized with 16 pkts
    Received 5000 packets
    Delete EnetApp_rxTask() and exit..
    Transmitted 5000 packets
    Delete EnetApp_txTask() and exit..
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxBcastFrames           = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txBcastFrames           = 5000
      txOctets                = 2590000
      octetsFrames512to1023   = 10000
      netOctets               = 5180000
      txPri[0]                = 5000
      txPriBcnt[0]            = 2590000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Cpsw_handleLinkDown:1642
    Test complete: PASS
     Enet Loopback: Iteration 2
    CPSW_3G Test
    0 From 2 To 1
    Open MAC port 1
    PHY 3 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
     Enet Loopback: Iteration 3
    CPSW_3G Test
    Open MAC port 1
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
     Enet Loopback: Iteration 4
    CPSW_3G Test
    Open MAC port 1
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
     Enet Loopback: Iteration 5
    CPSW_3G Test
    Open MAC port 1
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
    Loopback application completed
    All tests have passed!!
  • Hi Pavan Kumar,
    Can you please let me know what was changed which led to the software working?
    Can you also try an external loop-back (enet_layer2_cpsw example).
    Shaunak
  • Hi Shaubak Deshpande
    We have assigned the MAC address manually. While testing PHY loopback, we are only getting the below log.
    External loop back(enet_layer2_cpsw example) also testing but error is coming.
    Description	Resource	Path	Location	Type
    fatal error: 'drivers/sciclient.h' file not found	l2_cpsw_common.h	/enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang	line 47	C/C++ Problem
    gmake: *** [l2_cpsw_cfg.o] Error 1	enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang		 	C/C++ Problem
    gmake: *** [l2_cpsw_dataflow.o] Error 1	enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang		 	C/C++ Problem
    gmake: *** [l2_cpsw_main.o] Error 1	enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang		 	C/C++ Problem
    gmake: Target 'all' not remade because of errors.	enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang		 	C/C++ Problem
    recipe for target 'l2_cpsw_cfg.o' failed	subdir_rules.mk	/enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Release	line 52	C/C++ Problem
    recipe for target 'l2_cpsw_dataflow.o' failed	subdir_rules.mk	/enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Release	line 52	C/C++ Problem
    recipe for target 'l2_cpsw_main.o' failed	subdir_rules.mk	/enet_l2_cpsw_am263x-cc_r5fss0-0_freertos_ti-arm-clang/Release	line 52	C/C++ Problem
  • Hi Shaunak,
    We have added an external EEPROM to our custom board.
    While testing the custom board, we observed that in MAC loopback, logs are printed properly when the MAC address is assigned manually. However, when auto MAC assignment is used, getting error in log
    Also, during PHY loopback testing, the logs are not coming properly even with EEPROM and with out EEPROM
    Please find the attached log for reference.
    Could you please help us  in this case?
    CPSW_3G Test
    Assertion @ Line: 285 in syscfg/ti_board_config.c: ENET_GET_NUM_MAC_ADDR(numMacMax) <= ENET_BOARD_NUM_MACADDR_MAX : failed !!!
    CPSW_3G Test
    Open MAC port 1
    PHY 0 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Cpsw_handleLinkDown:1679
    Test complete: PASS
    CPSW_3G Test
    EnetAppUtils_reduceCoreMacAllocation: Reduced Mac Address Allocation for CoreId:0 From 4 To 1
    Open MAC port 1
    PHY 0 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
    CPSW_3G Test
    Open MAC port 1
    PHY 0 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
    CPSW_3G Test
    Open MAC port 1
    PHY 0 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
    CPSW_3G Test
    Open MAC port 1
    PHY 0 is alive
     Port 0 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
     Port 1 Statistics
      rxGoodFrames            = 5000
      rxOctets                = 2590000
      txGoodFrames            = 5000
      txOctets                = 2590000
      netOctets               = 5180000
      txPri[0]                = 5000
    Test complete: PASS
    CPSW_3G Test
    CPSW_3G Test
    Open MAC port 1
    EnetPhy_bindDriver:1873
    PHY 0 is alive
    Cpsw_handleLinkUp:1653
    Thanks and Regards
    Pavan kumar
