Part Number: TMS570LC4357-EP
Other Parts Discussed in Thread: HALCOGEN, TMS570LC4357
I am currently working with the TMS570LC4357-EP MCU and using HALCoGen to configure the peripherals.
I would like to generate a periodic interrupt every 1 ms using the RTI (Real-Time Interrupt) module. I see the RTI configuration options in HALCoGen, but I am not fully clear on the correct steps to configure the counter, compare value, and interrupt to achieve a 1 ms periodic timer.
Could you please help clarify:
What is the recommended configuration in HALCoGen to generate a 1 ms periodic interrupt using RTI?
How should the compare value be calculated based on the RTI clock?
Is there any example code or reference project available that demonstrates configuring RTI for a 1 ms interrupt on the TMS570LC4357?
