AM263P4-Q1: ADC triggered by ePWM
Part Number: AM263P4-Q1
What are the ePWM registers are need to be used for ADC trigger by ePWM, along with ADC registers?
Based on my understanding I prepared flow chart. Please confirm whether it is correct or not?
ePWM event
SOCA (ADC trigger)
ADC conversion starts
ADC conversion completes
ADC interrupt occurs
ISR read values.
Which registers are responsible for ADC conversion start to the Interrrupt occurrence. Can I use ePWM or ADC registers
Thank you!
Rajkumar
  • Hello, First of all, I recommend to implement these kind of routines in SysConfig and then you see exact API for each function separately.  Both ePWM and ADC registers are needed here, but they serve different roles:
    ePWM registers (ETSEL, ETPS) → only generate the trigger event (SOCA)
    ADC registers (ADCSOCxCTL, ADCINTSEL, ADCINTFLG) → control everything from conversion start through interrupt generation
    The conversion-to-interrupt path is purely ADC registers. The ePWM only initiates the sequence.
    Masoud
