Part Number: MSPM0G3507
I have an application that requires me to use the ADCs for a while in RUN mode, and then enter STANDBY mode to achieve lowest power consumption. I am trying to turn off the ADCs, but am seeing ~600uA per ADC excess current while in STANDBY mode.
I have taken the example sysctl_power_policy_sleep_to_standby as a basis, and can see that the SHUTDOWN current is expected with all the relevant jumpers removed from the Launchpad board. Even with MCLK set to use the PLL, I am still seeing the expected low current.
If I then use Sysconfig to enable an ADC (repeat mode, ULPCLK, FIFO enabled, PowerDown mode set to manual as this is needed for my application) I can see that the autogenerated setup code is added to the project. I expect that I should be able to add calls to DL_ADC12_disableConversions(ADC12_0_INST) and DL_ADC12_disablePower(ADC12_0_INST) immediately after the call to SYSCFG_DL_init() in the main() function and still see the low current that I measured previously. However, it is ~600uA higher.
What is the correct way to power down the ADC after it has been configured to achieve the lowest possible STANDBY current? After that, what's the minimum amount of reconfiguration that should be needed to start it back up again when the device goes back into RUN mode?
