Hello TI,
As reported in http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/t/179988.aspx the bit fields in the ADCTSSEL register do not respond as documented in the data sheet (currently July 17, 2013 version).
On my LM4F232H5QD Development Board, fitted with a new TM4C123GH6PGEI, I must set ADCTSSEL = 0x00000010 in order to successfully trigger ADC0 SS1 from PWM Module 1. According to the data sheet, 0x00001000 should do the trick, but it does not. Only 0x00000010 triggers ADC0 SS1 from PWM Module 1.
Please consider correcting the data sheet to match the silicon. Also, are there any plans to add an API function for the ADCTSSEL register's functionality in the Tiva Peripheral Driver Library?
Thank you for your consideration!
Dave
