Other Parts Discussed in Thread: ENERGIA
Hey !
Can anyone give me the Energia coding of DC motor related ON TM4C123G board
Thank you
While in 'complete agreement' w/Vendor's Ralph - if you provide a (recently confirmed) link to your 'H-Bridge' it is likely that I can advise.
And - may it be noted - that as, "Points #1 thru #4 - embedded w/in those (same) guidelines - had (little) chance of 'being noted or read' - point #5 had (almost surely) NO CHANCE AT ALL! It is 'EFFECTIVE Message Delivery' ONLY ... which (may) succeed. (as vendor's Ralph - and I have discussed ... putting 'teeth' into 'forum Guidelines' - is (clearly) required!)
You must (better) describe (ideally link) what is meant by, 'TM4C123G' board. Which candidate pins did you choose - that would prove useful - as well.
It is (still) unsettling that crack 'energia crüe' ... STILL employ this TM4C forum - as their 'Tech Dumping Ground!' (my response will be 'one-time only' - unless and until - (that, 'deliberately Off-Loading crüe' - assumes (some) of my workload...)
