Part Number: TM4C1294NCPDT
Further queries relating to this issue;
we need to understand more on the manifestation of ESD failures in the microprocessor.
We have just found another forum entry – see
http://e2e.ti.com/support/microcontrollers/tiva_arm/f/908/p/318646/1735906?pi239031350=3
Amit here is referring to adding capacitors on the USB as per an errata – however we cannot find the information he is referring to, can you supply any info regarding capacitor selection?
I am looking at a couple of ideas (not sure if they will help us)
- We use USB connected to PB0&1 (followed the recommended guides) – but I will look at adding isolation – maybe a buffer IC - of the signal lines to the port.
- Adding current limiting resistors to I/O lines.
I will have three failed uP next week – unfortunately others have been dumped. Would we be able to arrange De-Capping?
Can you help?
Linda
