Part Number: EK-TM4C123GXL
Tool/software: TI-RTOS
Hi TI Forum,
I am new to TI-RTOS and TIVA C. I'm planning to use C++ with TI-RTOS. I am facing a problem while creating a Task in static way. I'm giving task definition in main.cpp. I'm getting the following error
warning #10229-D: output section ".data" refers to load symbol "[Task Function name]" and hence cannot be compressed; compression "lzss" is ignored
when i searched in .map file . I found that [Task Function name] is allocated with address UNDEFED.
I tried creating dynamically in main.cpp . The code is compiling cleanly and detecting the [Task Function name] with some defined address.
my question is can't we use .cpp with combination of TI-RTOS. If yes, we can you say where am i going wrong.?
Thanks in advance.
