RTOS/TM4C129EKCPDT: TivaC NDK TCP: Can't receive large packets ACK PSH ACK is not reveice
Part Number: TM4C129EKCPDT
Other Parts Discussed in Thread: SYSBIOS, EK-TM4C1294XL
Tool/software: TI-RTOS
a big  tcp packet >1460 and send  ack and psh ack is not reveiced
ndk is  ndk_2_25_00_09
for code is your example
and this   don't   solve the problem
https://e2e.ti.com/support/legacy_forums/embedded/tirtos/f/355/p/497052/2108344#2108344
 I think it is a bug.
ti is the code:
the setting is
the packet for wireshark
    What is the status of the target? Can you pause it and check Tools->ROV->SysMin->outputBuf to see if there is anything. Also ROV->BIOS->Scan for Errors. Anything on the CCS console (in case the target flush any text to it).
    Is this on the out-of-box TCP Echo (with just the buffer settings you high-lighted above)? What did you send on the host side?
    Todd
  • my target is that my code can reveice 1800 bit packet . I am good at TCP/IP and TI-RTOS. my code is OK buffer is OK . I think some wrong with my configuration or somewrong with ndk . I hope you give me a code for revecie 1800 bit packet for TCP. TCP WIN >2920.
    I think it is the ndk bug, it isn't support for more than 1460 data for a packet .
    Can you attach your modified EMACSnow.c for me to take a look at.
    Gerardo
     * Copyright (c) 2014-2015 Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ======== EMACSnow.c ========
     *  This driver currently supports only 1 EMACSnow port. In the future
     *  when multiple ports are required, this driver needs to move all the
     *  EMACSnow_Data fields into the EMACSnow_Object structure. The APIs need
     *  to get to the fields via the pvt_data field in the NETIF_DEVICE that
     *  is passed in. ROV must be changed to support the change also.
     *  The NETIF_DEVICE structure should go into the EMACSnow_Object also.
     *  This changes are not being done at this time because of the impact on
     *  the complexity of the code.
    #include <xdc/runtime/Assert.h>
    #include <xdc/runtime/Diags.h>
    #include <xdc/runtime/Error.h>
    #include <xdc/runtime/Log.h>
    #include <xdc/runtime/System.h>
    #include <xdc/runtime/Types.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Swi.h>
    #include <ti/sysbios/family/arm/m3/Hwi.h>
    #include <string.h>
    #include <ti/drivers/EMAC.h>
    #include <ti/drivers/emac/EMACSnow.h>
    /* device specific driver includes */
    #include <stdint.h>
    #include <stdbool.h>
    #include <inc/hw_memmap.h>
    #include <inc/hw_types.h>
    #include <inc/hw_emac.h>
    #include <inc/hw_ints.h>
    #include <inc/hw_gpio.h>
    #include <inc/hw_flash.h>
    #include <driverlib/debug.h>
    #include <driverlib/emac.h>
    #include <driverlib/sysctl.h>
    #include <inc/hw_sysctl.h>
    /* Name of the device. */
    #define ETHERNET_NAME "eth0"
    #ifndef NUM_RX_DESCRIPTORS
    #define NUM_RX_DESCRIPTORS 4
    #endif
    #ifndef NUM_TX_DESCRIPTORS
    #define NUM_TX_DESCRIPTORS 4
    #endif
    #ifndef EMAC_PHY_CONFIG
    #define EMAC_PHY_CONFIG         (EMAC_PHY_TYPE_INTERNAL |                     \
                                     EMAC_PHY_INT_MDIX_EN |                       \
                                     EMAC_PHY_AN_100B_T_FULL_DUPLEX)
    #endif
    uint32_t g_ulStatus;
    bool enablePrefetch = FALSE;
    /* Debug counters for PHY issue                   */
    volatile unsigned int phyCounter[3] = {0, 0, 0};
    static void EMACSnow_handleRx();
    static void EMACSnow_processTransmitted();
     *  Helper struct holding a DMA descriptor and the pbuf it currently refers
     *  to.
    typedef struct {
      tEMACDMADescriptor Desc;
      PBM_Handle hPkt;
    } tDescriptor;
    typedef struct {
        tDescriptor *pDescriptors;
        uint32_t     ulNumDescs;
        uint32_t     ulWrite;
        uint32_t     ulRead;
    } tDescriptorList;
     * Global variable for this interface's private data.  Needed to allow
     * the interrupt handlers access to this information outside of the
     * context of the lwIP netif.
    static tDescriptor g_pTxDescriptors[NUM_TX_DESCRIPTORS];
    static tDescriptor g_pRxDescriptors[NUM_RX_DESCRIPTORS];
    static tDescriptorList g_TxDescList = {
        g_pTxDescriptors, NUM_TX_DESCRIPTORS, 0, 0
    static tDescriptorList g_RxDescList = {
        g_pRxDescriptors, NUM_RX_DESCRIPTORS, 0, 0
    /* EMAC function table for snowflake implementation */
    const EMAC_FxnTable EMACSnow_fxnTable = {
            EMACSnow_init,
            EMACSnow_isLinkUp
    /* Application is required to provide this variable */
    extern EMAC_Config EMAC_config;
     *  The struct is used to store the private data for the EMACSnow controller.
    typedef struct EMACSnow_Data {
        STKEVENT_Handle  hEvent;
        PBMQ             PBMQ_tx;
        PBMQ             PBMQ_rx;
        uint32_t         rxCount;
        uint32_t         rxDropped;
        uint32_t         txSent;
        uint32_t         txDropped;
        uint32_t         abnormalInts;
        uint32_t         isrCount;
        uint32_t         linkUp;
        tDescriptorList *pTxDescList;
        tDescriptorList *pRxDescList;
    } EMACSnow_Data;
    /* Only supporting one EMACSnow device */
    static EMACSnow_Data EMACSnow_private;
    static volatile Bool EMACSnow_initialized = FALSE;
    #define PHY_PHYS_ADDR 1
     *  ======== signalLinkChange ========
     *  Signal the stack based on linkUp parameter.
    static void signalLinkChange(STKEVENT_Handle hEvent, uint32_t linkUp,
            unsigned int flag)
        if (linkUp) {
            /* Signal the stack that the link is up */
            STKEVENT_signal(hEvent, STKEVENT_LINKUP, flag);
        else {
            /* Signal the stack that the link is down */
            STKEVENT_signal(hEvent, STKEVENT_LINKDOWN, flag);
     *  ======== EMACSnow_processPendingTx ========
    static void EMACSnow_processPendingTx()
        uint8_t     *pBuffer;
        uint32_t     len;
        PBM_Handle   hPkt;
        tDescriptor *pDesc;
         *  If there are pending packets, send one.
         *  Otherwise quit the loop.
        hPkt = PBMQ_deq(&EMACSnow_private.PBMQ_tx);
        if (hPkt != NULL) {
            pDesc = &(EMACSnow_private.pTxDescList->pDescriptors[EMACSnow_private.pTxDescList->ulWrite]);
            if (pDesc->hPkt) {
                PBM_free(hPkt);
                EMACSnow_private.txDropped++;
                return;
            /* Get the pointer to the buffer and the length */
            pBuffer = PBM_getDataBuffer(hPkt) + PBM_getDataOffset(hPkt);
            len = PBM_getValidLen(hPkt);
            /* Fill in the buffer pointer and length */
            pDesc->Desc.ui32Count = len;
            pDesc->Desc.pvBuffer1 = pBuffer;
            pDesc->Desc.ui32CtrlStatus = DES0_TX_CTRL_FIRST_SEG;
            pDesc->Desc.ui32CtrlStatus |= (/*DES0_TX_CTRL_IP_ALL_CKHSUMS |*/ DES0_TX_CTRL_CHAINED);
            pDesc->Desc.ui32CtrlStatus |= (DES0_TX_CTRL_LAST_SEG |
                                           DES0_TX_CTRL_INTERRUPT);
            EMACSnow_private.pTxDescList->ulWrite++;
            if (EMACSnow_private.pTxDescList->ulWrite == NUM_TX_DESCRIPTORS) {
                EMACSnow_private.pTxDescList->ulWrite = 0;
            pDesc->hPkt = hPkt;
            pDesc->Desc.ui32CtrlStatus |= DES0_TX_CTRL_OWN;
            EMACSnow_private.txSent++;
            EMACTxDMAPollDemand(EMAC0_BASE);
        return;
     *  ======== EMACSnow_handlePackets ========
    static void EMACSnow_handlePackets(UArg arg0, UArg arg1)
        Log_print1(Diags_USER1, "EMACSnow_handlePackets handling packets status = 0x%x", g_ulStatus);
        /* Process the transmit DMA list, freeing any buffers that have been
         * transmitted since our last interrupt.
        if (g_ulStatus & EMAC_INT_TRANSMIT) {
            Log_print0(Diags_USER1, "EMACSnow_handlePackets Tx ones...");
         * Process the receive DMA list and pass all successfully received packets
         * up the stack.  We also call this function in cases where the receiver has
         * stalled due to missing buffers since the receive function will attempt to
         * allocate new pbufs for descriptor entries which have none.
        if (g_ulStatus & (EMAC_INT_RECEIVE | EMAC_INT_RX_NO_BUFFER |
            EMAC_INT_RX_STOPPED)) {
            Log_print0(Diags_USER1, "EMACSnow_handlePackets Rx ones...");
        Log_print0(Diags_USER1, "EMACSnow_handlePackets re-enable peripheral...");
        EMACIntEnable(EMAC0_BASE, (EMAC_INT_RECEIVE | EMAC_INT_TRANSMIT |
                            EMAC_INT_TX_STOPPED | EMAC_INT_RX_NO_BUFFER |
                            EMAC_INT_RX_STOPPED | EMAC_INT_PHY));
     *  ======== EMACSnow_processTransmitted ========
        tDescriptor *pDesc;
         * Walk the list until we have checked all descriptors or we reach the
         * write pointer or find a descriptor that the hardware is still working
         * on.
        for (ulNumDescs = 0; ulNumDescs < NUM_TX_DESCRIPTORS; ulNumDescs++) {
            pDesc = &(EMACSnow_private.pTxDescList->pDescriptors[EMACSnow_private.pTxDescList->ulRead]);
            /* Has the buffer attached to this descriptor been transmitted? */
            if (pDesc->Desc.ui32CtrlStatus & DES0_TX_CTRL_OWN) {
                /* No - we're finished. */
                break;
            /* Does this descriptor have a buffer attached to it? */
            if (pDesc->hPkt) {
                /* Yes - free it if it's not marked as an intermediate pbuf */
                if (!((uint32_t)(pDesc->hPkt) & 1)) {
                    PBM_free(pDesc->hPkt);
                pDesc->hPkt = NULL;
            else {
                /* If the descriptor has no buffer, we are finished. */
                break;
            /* Move on to the next descriptor. */
            EMACSnow_private.pTxDescList->ulRead++;
            if (EMACSnow_private.pTxDescList->ulRead == NUM_TX_DESCRIPTORS) {
                EMACSnow_private.pTxDescList->ulRead = 0;
     *  ======== EMACSnow_primeRx ========
    static void EMACSnow_primeRx(PBM_Handle hPkt, tDescriptor *desc)
        desc->hPkt = hPkt;
        desc->Desc.ui32Count = DES1_RX_CTRL_CHAINED;
        /* We got a buffer so fill in the payload pointer and size. */
        desc->Desc.pvBuffer1 = PBM_getDataBuffer(hPkt) + PBM_getDataOffset(hPkt);
        desc->Desc.ui32Count |= (ETH_MAX_PAYLOAD << DES1_RX_CTRL_BUFF1_SIZE_S);
        /* Give this descriptor back to the hardware */
        desc->Desc.ui32CtrlStatus = DES0_RX_CTRL_OWN;
     *  ======== EMACSnow_handleRx ========
        PBM_Handle       hPkt;
        PBM_Handle       hPktNew;
        int32_t          len;
        tDescriptorList *pDescList;
        uint32_t         ulDescEnd;
        /* Get a pointer to the receive descriptor list. */
        pDescList = EMACSnow_private.pRxDescList;
        /* Determine where we start and end our walk of the descriptor list */
        ulDescEnd = pDescList->ulRead ? (pDescList->ulRead - 1) : (pDescList->ulNumDescs - 1);
        /* Step through the descriptors that are marked for CPU attention. */
        while (pDescList->ulRead != ulDescEnd) {
            /* Does the current descriptor have a buffer attached to it? */
            hPkt = pDescList->pDescriptors[pDescList->ulRead].hPkt;
            if (hPkt) {
                /* Determine if the host has filled it yet. */
                if (pDescList->pDescriptors[pDescList->ulRead].Desc.ui32CtrlStatus &
                    DES0_RX_CTRL_OWN) {
                  /* The DMA engine still owns the descriptor so we are finished. */
                  break;
                /* Yes - does the frame contain errors? */
                   DES0_RX_STAT_ERR) {
                     *  This is a bad frame so discard it and update the relevant
                     *  statistics.
                    Log_error0("EMACSnow_handleRx: DES0_RX_STAT_ERR");
                    EMACSnow_private.rxDropped++;
                    EMACSnow_primeRx(hPkt, &(pDescList->pDescriptors[pDescList->ulRead]));
                    pDescList->ulRead++;
                    break;
                else {
                    /* Allocate a new buffer for this descriptor */
                    hPktNew = PBM_alloc(ETH_MAX_PAYLOAD);
                    if (hPktNew == NULL) {
                         *  Leave the packet in the descriptor and owned by the driver.
                         *  Process when the next interrupt occurs.
                        break;
                    /* This is a good frame so pass it up the stack. */
                    len = (pDescList->pDescriptors[pDescList->ulRead].Desc.ui32CtrlStatus &
                          DES0_RX_STAT_FRAME_LENGTH_M) >> DES0_RX_STAT_FRAME_LENGTH_S;
                    /* Remove the CRC */
                    PBM_setValidLen(hPkt, len - 4);
                     *  Place the packet onto the receive queue to be handled in the
                     *  EMACSnow_pkt_service function (which is called by the
                     *  NDK stack).
                    PBMQ_enq(&EMACSnow_private.PBMQ_rx, hPkt);
                    Log_print2(Diags_USER2, "EMACSnow_handleRx: Enqueued recv packet 0x%x, length = %d",
                        (IArg)hPkt, len - 4);
                    /* Update internal statistic */
                    EMACSnow_private.rxCount++;
                     *  Notify NDK stack of pending Rx Ethernet packet and
                     *  that it was triggered by an external event.
                    STKEVENT_signal(EMACSnow_private.hEvent, STKEVENT_ETHERNET, 1);
                    /* Prime the receive descriptor back up for future packets */
                    EMACSnow_primeRx(hPktNew,
            /* Move on to the next descriptor in the chain, taking care to wrap. */
            if (pDescList->ulRead == pDescList->ulNumDescs) {
                pDescList->ulRead = 0;
     *  ======== EMACSnow_processPhyInterrupt ========
    void EMACSnow_processPhyInterrupt()
        uint16_t value, status;
        uint32_t config, mode, rxMaxFrameSize;
         * Read the PHY interrupt status.  This clears all interrupt sources.
         * Note that we are only enabling sources in EPHY_MISR1 so we don't
         * read EPHY_MISR2.
        value = EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_MISR1);
        /* Read the current PHY status. */
        status = EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_STS);
        /* Has the link status changed? */
        if (value & EPHY_MISR1_LINKSTAT) {
            /* Is link up or down now? */
            if (status & EPHY_STS_LINK) {
                EMACSnow_private.linkUp = true;
            else {
                EMACSnow_private.linkUp = false;
            /* Signal the stack for this link status change (from ISR) */
            signalLinkChange(EMACSnow_private.hEvent, EMACSnow_private.linkUp, 1);
        /* Has the speed or duplex status changed? */
        if (value & (EPHY_MISR1_SPEED | EPHY_MISR1_SPEED | EPHY_MISR1_ANC)) {
            /* Get the current MAC configuration. */
            EMACConfigGet(EMAC0_BASE, (uint32_t *)&config, (uint32_t *)&mode,
                            (uint32_t *)&rxMaxFrameSize);
            /* What speed is the interface running at now?
            if (status & EPHY_STS_SPEED) {
                /* 10Mbps is selected */
                config &= ~EMAC_CONFIG_100MBPS;
            else {
                /* 100Mbps is selected */
                config |= EMAC_CONFIG_100MBPS;
            /* Are we in full- or half-duplex mode? */
            if (status & EPHY_STS_DUPLEX) {
                /* Full duplex. */
                config |= EMAC_CONFIG_FULL_DUPLEX;
            else {
                /* Half duplex. */
                config &= ~EMAC_CONFIG_FULL_DUPLEX;
            /* Reconfigure the MAC */
            EMACConfigSet(EMAC0_BASE, config, mode, rxMaxFrameSize);
     *  ======== EMACSnow_hwiIntFxn ========
    void EMACSnow_hwiIntFxn(UArg callbacks)
        EMACSnow_Object *object = (EMACSnow_Object *)(EMAC_config.object);
        uint32_t status;
        /* Check link status */
        status = (EMACPHYRead(EMAC0_BASE, 0, EPHY_BMSR) & EPHY_BMSR_LINKSTAT);
        /* Signal the stack if link status changed */
        if (status != EMACSnow_private.linkUp) {
            signalLinkChange(EMACSnow_private.hEvent, status, 1);
        /* Set the link status */
        EMACSnow_private.linkUp = status;
        EMACSnow_private.isrCount++;
        /* Read and Clear the interrupt. */
        status = EMACIntStatus(EMAC0_BASE, true);
        EMACIntClear(EMAC0_BASE, status);
         *  Disable the Ethernet interrupts.  Since the interrupts have not been
         *  handled, they are not asserted.  Once they are handled by the Ethernet
         *  interrupt, it will re-enable the interrupts.
        EMACIntDisable(EMAC0_BASE, (EMAC_INT_RECEIVE | EMAC_INT_TRANSMIT |
        if (status & EMAC_INT_ABNORMAL_INT) {
            EMACSnow_private.abnormalInts++;
        g_ulStatus = status;
        if (status & EMAC_INT_PHY) {
            EMACSnow_processPhyInterrupt();
        Log_print1(Diags_USER1, "EMACSnow_hwiIntFxn Posting Swi status = 0x%x", g_ulStatus);
        /* Have the Swi handle the incoming packets and re-enable peripheral */
        Swi_post(object->swi);
     *  ======== EMACSnow_emacStart ========
     *  The function is used to initialize and start the EMACSnow
     *  controller and device.
    int EMACSnow_emacStart(struct NETIF_DEVICE* ptr_net_device)
        uint16_t value;
        EMACSnow_HWAttrs *hwAttrs = (EMACSnow_HWAttrs *)(EMAC_config.hwAttrs);
        Hwi_Params  hwiParams;
        Error_Block eb;
        UInt32 ui32FlashConf;
         *  Create the Swi that handles incoming packets.
         *  Take default parameters.
        Error_init(&eb);
        object->swi = Swi_create(EMACSnow_handlePackets,
                                 NULL, &eb);
        if (object->swi == NULL) {
            Log_error0("EMACSnow_emacStart: Swi_create failed");
            return (-1);
        /* Create the hardware interrupt */
        Hwi_Params_init(&hwiParams);
        hwiParams.priority = hwAttrs->intPriority;
        object->hwi = Hwi_create(hwAttrs->intNum, EMACSnow_hwiIntFxn,
                &hwiParams, &eb);
        if (object->hwi == NULL) {
            Log_error0("EMACSnow_emacStart: Hwi_create failed");
            return (-1);
        /* Clear any stray PHY interrupts that may be set. */
        value = EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_MISR2);
        /* Configure and enable the link status change interrupt in the PHY. */
        value = EMACPHYRead(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_SCR);
        value |= (EPHY_SCR_INTEN_EXT | EPHY_SCR_INTOE_EXT);
        EMACPHYWrite(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_SCR, value);
        EMACPHYWrite(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_MISR1, (EPHY_MISR1_LINKSTATEN |
                     EPHY_MISR1_SPEEDEN | EPHY_MISR1_DUPLEXMEN | EPHY_MISR1_ANCEN));
        HWREG(EMAC0_BASE + EMAC_O_CC) |= EMAC_CC_POL;
        /* Read the PHY interrupt status to clear any stray events. */
         *  Set MAC filtering options.  We receive all broadcast and multicast
         *  packets along with those addressed specifically for us.
        EMACFrameFilterSet(EMAC0_BASE, (EMAC_FRMFILTER_HASH_AND_PERFECT |
                           EMAC_FRMFILTER_PASS_MULTICAST));
        /* Clear any pending interrupts. */
        EMACIntClear(EMAC0_BASE, EMACIntStatus(EMAC0_BASE, false));
        /* Enable the Ethernet MAC transmitter and receiver. */
        EMACTxEnable(EMAC0_BASE);
        EMACRxEnable(EMAC0_BASE);
        /* Enable the Ethernet RX and TX interrupt source. */
        /* Enable the Ethernet Interrupt handler. */
        Hwi_enableInterrupt(hwAttrs->intNum);
        EMACPHYWrite(EMAC0_BASE, PHY_PHYS_ADDR, EPHY_BMCR, (EPHY_BMCR_ANEN |
                     EPHY_BMCR_RESTARTAN));
        Log_print0(Diags_USER2, "EMACSnow_emacStart: start completed");
         * Turns ON the prefetch buffer if it was disabled in EMACSnow_NIMUInit
        if (enablePrefetch == TRUE) {
            ui32FlashConf = HWREG(FLASH_CONF);
            ui32FlashConf &= ~(FLASH_CONF_FPFOFF);
            ui32FlashConf |= FLASH_CONF_FPFON;
            HWREG(FLASH_CONF) = ui32FlashConf;
        return (0);
     *  ======== EMACSnow_emacStop ========
     *  The function is used to de-initialize and stop the EMACSnow
    int EMACSnow_emacStop(struct NETIF_DEVICE* ptr_net_device)
        PBM_Handle hPkt;
        int i = 0;
        Hwi_disableInterrupt(hwAttrs->intNum);
        if (object->hwi != NULL) {
            Hwi_delete(&(object->hwi));
        if (object->swi != NULL) {
            Swi_delete(&(object->swi));
        while (PBMQ_count(&EMACSnow_private.PBMQ_rx)) {
            /* Dequeue a packet from the driver receive queue. */
            hPkt = PBMQ_deq(&EMACSnow_private.PBMQ_rx);
            PBM_free(hPkt);
        while (PBMQ_count(&EMACSnow_private.PBMQ_tx)) {
            PBM_free(hPkt);
        for (i = 0; i < NUM_RX_DESCRIPTORS; i++) {
            if (g_pRxDescriptors[i].hPkt != NULL) {
                PBM_free(g_pRxDescriptors[i].hPkt);
        Log_print0(Diags_USER2, "EMACSnow_emacStop: stop completed");
        return (0);
     *  ======== EMACSnow_emacPoll ========
     *  The function is used to poll the EMACSnow controller to check
     *  if there has been any activity
    void EMACSnow_emacPoll(struct NETIF_DEVICE* ptr_net_device, uint timer_tick)
        uint32_t newLinkStatus;
        /* Send pending Tx packets */
        EMACSnow_processPendingTx();
        newLinkStatus =
        if (newLinkStatus != EMACSnow_private.linkUp) {
            signalLinkChange(EMACSnow_private.hEvent, newLinkStatus, 0);
        EMACSnow_private.linkUp = newLinkStatus;
     *  ======== EMACSnow_emacSend ========
     *  The function is the interface routine invoked by the NDK stack to
     *  pass packets to the driver.
    int EMACSnow_emacSend(struct NETIF_DEVICE* ptr_net_device, PBM_Handle hPkt)
         *  Enqueue the packet onto the end of the transmit queue.
         *  This is done to ensure that the packets are sent in order.
        PBMQ_enq(&EMACSnow_private.PBMQ_tx, hPkt);
        Log_print2(Diags_USER2, "EMACSnow_emacSend: enqueued hPkt = 0x%x, len = %d", (IArg)hPkt, PBM_getValidLen(hPkt));
        /* Transmit pending packets */
        return (0);
     *  ======== EMACSnow_emacioctl ========
     *  The function is called by the NDK core stack to configure the driver
    int EMACSnow_emacioctl(struct NETIF_DEVICE* ptr_net_device, uint cmd,
                   void* pbuf, uint size)
        /* No control commands are currently supported for this driver */
        Log_print0(Diags_USER2, "EMACSnow_emacioctl: emacioctl called");
        if ((cmd == NIMU_ADD_MULTICAST_ADDRESS) || (cmd == NIMU_DEL_MULTICAST_ADDRESS)) {
            return (0);
        return (-1);
     *  ======== EMACSnow_pkt_service ========
     *  The function is called by the NDK core stack to receive any packets
     *  from the driver.
    void EMACSnow_pkt_service(NETIF_DEVICE* ptr_net_device)
        PBM_Handle  hPkt;
        /* Give all queued packets to the stack */
             *  Prepare the packet so that it can be passed up the networking stack.
             *  If this 'step' is not done the fields in the packet are not correct
             *  and the packet will eventually be dropped.
            PBM_setIFRx(hPkt, ptr_net_device);
            Log_print1(Diags_USER2,
                       "EMACSnow_pkt_service: give packet 0x%x to NDK via NIMUReceivePacket",
                       (IArg)hPkt);
            /* Pass the packet to the NDK Core stack. */
            NIMUReceivePacket(hPkt);
        /* Work has been completed; the receive queue is empty. */
        return;
     *  ======== EMACSnow_init ========
     *  The function is used to initialize the EMACSnow driver
    void EMACSnow_init(uint32_t index)
        /* Currently only supports 1 EMACSnow peripheral */
        Assert_isTrue((index == 0), NULL);
        EMACSnow_initialized = TRUE;
        Log_print0(Diags_USER2, "EMACSnow_init: setup successfully completed");
     *  ======== EMACSnow_InitDMADescriptors ========
     * Initialize the transmit and receive DMA descriptor lists.
    void EMACSnow_InitDMADescriptors(void)
        int32_t     i;
        PBM_Handle  hPkt;
        /* Transmit list -  mark all descriptors as not owned by the hardware */
        for (i = 0; i < NUM_TX_DESCRIPTORS; i++) {
            g_pTxDescriptors[i].hPkt = NULL;
            g_pTxDescriptors[i].Desc.ui32Count = 0;
            g_pTxDescriptors[i].Desc.pvBuffer1 = 0;
            g_pTxDescriptors[i].Desc.DES3.pLink = ((i == (NUM_TX_DESCRIPTORS - 1)) ?
                   &g_pTxDescriptors[0].Desc : &g_pTxDescriptors[i + 1].Desc);
            g_pTxDescriptors[i].Desc.ui32CtrlStatus = DES0_TX_CTRL_INTERRUPT |
                                                      DES0_TX_CTRL_CHAINED;
         * Receive list -  tag each descriptor with a buffer and set all fields to
         * allow packets to be received.
            hPkt = PBM_alloc(ETH_MAX_PAYLOAD);
            if (hPkt) {
                EMACSnow_primeRx(hPkt, &(g_pRxDescriptors[i]));
            else {
                System_abort("EMACSnow_InitDMADescriptors: PBM_alloc error\n");
                g_pRxDescriptors[i].Desc.pvBuffer1 = 0;
                g_pRxDescriptors[i].Desc.ui32CtrlStatus = 0;
            g_pRxDescriptors[i].Desc.DES3.pLink =
                    ((i == (NUM_RX_DESCRIPTORS - 1)) ?
                    &g_pRxDescriptors[0].Desc : &g_pRxDescriptors[i + 1].Desc);
        /* Set the descriptor pointers in the hardware. */
        EMACRxDMADescriptorListSet(EMAC0_BASE, &g_pRxDescriptors[0].Desc);
        EMACTxDMADescriptorListSet(EMAC0_BASE, &g_pTxDescriptors[0].Desc);
     *  ======== EMACSnow_NIMUInit ========
     *  The function is used to initialize and register the EMACSnow
     *  with the Network Interface Management Unit (NIMU)
    int EMACSnow_NIMUInit(STKEVENT_Handle hEvent)
        Types_FreqHz freq;
        NETIF_DEVICE *device;
        Log_print0(Diags_USER2, "EMACSnow_NIMUInit: init called");
        /* Make sure application has initialized the EMAC driver first */
        Assert_isTrue((EMACSnow_initialized == TRUE), NULL);
        /* Initialize the global structures */
        memset(&EMACSnow_private, 0, sizeof(EMACSnow_Data));
         *  This is a work-around for EMAC initialization issues found on
         *  the TM4C129 devices. The bug number is:
         *  SDOCM00107378: NDK examples for EK-TM4C1294XL do not work
         *  The following disables the flash pre-fetch (if it is not already disabled).
         *  It is enable within the in the EMACSnow_emacStart() function.
        if ((ui32FlashConf & (FLASH_CONF_FPFOFF)) == FALSE) {
            enablePrefetch = TRUE;
            ui32FlashConf &= ~(FLASH_CONF_FPFON);
            ui32FlashConf |= FLASH_CONF_FPFOFF;
        /* Allocate memory for the EMAC. Memory freed in the NDK stack shutdown */
        device = mmAlloc(sizeof(NETIF_DEVICE));
        if (device == NULL) {
            Log_error0("EMACSnow: Failed to allocate NETIF_DEVICE structure");
            return (-1);
        /* Initialize the allocated memory block. */
        mmZeroInit (device, sizeof(NETIF_DEVICE));
        device->mac_address[0] = hwAttrs->macAddress[0];
        device->mac_address[1] = hwAttrs->macAddress[1];
        device->mac_address[2] = hwAttrs->macAddress[2];
        device->mac_address[3] = hwAttrs->macAddress[3];
        device->mac_address[4] = hwAttrs->macAddress[4];
        device->mac_address[5] = hwAttrs->macAddress[5];
        /* Initialize the Packet Device Information struct */
        PBMQ_init(&EMACSnow_private.PBMQ_rx);
        PBMQ_init(&EMACSnow_private.PBMQ_tx);
        EMACSnow_private.hEvent       = hEvent;
        EMACSnow_private.pTxDescList  = &g_TxDescList;
        EMACSnow_private.pRxDescList  = &g_RxDescList;
        EMACSnow_private.rxCount      = 0;
        EMACSnow_private.rxDropped    = 0;
        EMACSnow_private.txSent       = 0;
        EMACSnow_private.txDropped    = 0;
        EMACSnow_private.abnormalInts = 0;
        EMACSnow_private.isrCount = 0;
        SysCtlPeripheralEnable(SYSCTL_PERIPH_EMAC0);
        SysCtlPeripheralReset(SYSCTL_PERIPH_EMAC0);
        SysCtlPeripheralEnable(SYSCTL_PERIPH_EPHY0);
        SysCtlPeripheralReset(SYSCTL_PERIPH_EPHY0);
        while (!SysCtlPeripheralReady(SYSCTL_PERIPH_EPHY0) ||
               !SysCtlPeripheralReady(SYSCTL_PERIPH_EMAC0)) {
            /* Keep waiting... */
            phyCounter[0]++;
        EMACPHYConfigSet(EMAC0_BASE, EMAC_PHY_CONFIG);
        BIOS_getCpuFreq(&freq);
        EMACInit(EMAC0_BASE, freq.lo,
                 EMAC_BCONFIG_MIXED_BURST | EMAC_BCONFIG_PRIORITY_FIXED,
                 4, 4, 0);
        /* Set MAC configuration options. */
        EMACConfigSet(EMAC0_BASE, (EMAC_CONFIG_FULL_DUPLEX |
                                   //EMAC_CONFIG_CHECKSUM_OFFLOAD |
                                   EMAC_CONFIG_7BYTE_PREAMBLE |
                                   EMAC_CONFIG_IF_GAP_96BITS |
                                   EMAC_CONFIG_USE_MACADDR0 |
                                   EMAC_CONFIG_SA_FROM_DESCRIPTOR |
                                   EMAC_CONFIG_BO_LIMIT_1024),
                      (EMAC_MODE_RX_STORE_FORWARD |
                       EMAC_MODE_TX_STORE_FORWARD |
                       EMAC_MODE_TX_THRESHOLD_64_BYTES |
                       EMAC_MODE_RX_THRESHOLD_64_BYTES), 0);
        /* Program the MAC address into the Ethernet controller. */
        EMACAddrSet(EMAC0_BASE, 0, (uint8_t *)device->mac_address);
        /* Initialize the DMA descriptors. */
        EMACSnow_InitDMADescriptors();
        /* Populate the Network Interface Object. */
        strcpy(device->name, ETHERNET_NAME);
        device->mtu         = ETH_MAX_PAYLOAD - ETHHDR_SIZE;
        device->pvt_data    = (void *)&EMACSnow_private;
        /* Populate the Driver Interface Functions. */
        device->start       = EMACSnow_emacStart;
        device->stop        = EMACSnow_emacStop;
        device->poll        = EMACSnow_emacPoll;
        device->send        = EMACSnow_emacSend;
        device->pkt_service = EMACSnow_pkt_service;
        device->ioctl       = EMACSnow_emacioctl;
        device->add_header  = NIMUAddEthernetHeader;
        /* Register the device with NIMU */
        if (NIMURegister(device) < 0) {
            Log_print0(Diags_USER1, "EMACSnow_NIMUInit: failed to register with NIMU");
            return (-1);
        Log_print0(Diags_USER2, "EMACSnow_NIMUInit: register with NIMU");
        return (0);
     *  ======== EMACSnow_linkUp ========
    bool EMACSnow_isLinkUp(uint32_t index)
        newLinkStatus =
        if (EMACSnow_private.linkUp) {
            return (true);
        else {
            return (false);
    EMACSnow.c
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    * are met:
    #include <string.h>
    #include <stdint.h>
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    It doesn't look like your EMAC version has the fixes detailed on the thread you attached. Try with the EMAC version found in that thread which I have attached here.
    Gerardo
    4645.EMACSnow.c
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    * are met:
    #include <string.h>
    #include <stdint.h>
  • it is OK ,it work good and thank you very much
