CCS/RM57L843: Impossible to load a program into LaunchPad RM57L843
Part Number: RM57L843
Other Parts Discussed in Thread: HALCOGEN
It’s impossible to launch a program into a Load development board.
The error is the following:
CortexR5: File Loader: Memory write failed: Flash verification failed
CortexR5: GEL: File: C:\Users\mohan_000\workspace_v8\Build-LAUNCHXL2-RM57x\Debug\Build-LAUNCHXL2-RM57x.out: Load failed.
CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
I am new user of this software. so i request to give answer with reason why the error come. thanks for the help!
    The error itself is covered in the Data Verification Errors article below:
    software-dl.ti.com/.../troubleshooting-data_verification_errors.html
    In summary, it may be caused by several root causes:
    - Your code is incorrectly configured and thus trying to write to invalid memory regions. If you can, try to flash an example code from HalCoGen or a pre-built binary that you know it works well. That will help isolate the issue to the code or the device.
    - If the above does not work, the Flash is not operating correctly or is not being erased successfully. The debugging options shown in the original thread are very useful to diagnose and try to recover the Flash memory.
    - If that does not work, there is a strong chance the device itself is not properly working. I would then try with a different development board to try to isolate the issue to a specific development board.
    Hope this helps,
    Rafael
