Part Number: MSP-EXPCC430RFX
The CAL_ADC_20T30=1029 ,CAL_ADC_20T85=1896. The temperature is calculated by the formula provided in datasheet IntDegC =(SavedADC12MEM0-CAL_ADC_20T30)*((85-30)/(float)(CAL_ADC_20T85-CAL_ADC_20T30))+30; The IntDegC=64 when running the program.
#include "msp430.h" #include "hal_adc.h" volatile signed int SavedADC12MEM0 = 0; volatile unsigned long SavedADC12MEM1 = 0; volatile signed int IntDegC, IntDegF; volatile unsigned long Vcc = 0; unsigned char exit_active_from_ADC12 = 0; int CAL_ADC_20T30, CAL_ADC_20T85; float m = 0, c = 0; // Workaround for ADC29 erratum. Manual 25C [RoomTemp] calibration for // temp sensor to replace faulty 30C Cal value. //--ADC software temperature calibration constant, workaround for ADC27 erratum // regarding faulty temperature calibration constant, is stored in INFOB // Perform manual SW calibration if the default cal value is faulty #ifdef __TI_COMPILER_VERSION__ // If CCS compiler is used #pragma DATA_SECTION(adcTemp25Calibration, ".infoB"); int adcTemp25Calibration; #elif __IAR_SYSTEMS_ICC__ // If IAR compiler is used #define INFOB _Pragma("location=\"INFOB\"") INFOB __no_init int adcTemp25Calibration; #endif /**********************************************************************//** * @brief Turns on and initializes ADC12 in order to * sample temperature, Vcc * * @param none * * @return none *************************************************************************/ void HalAdcInit(void) { //Sequence of channels, once, ADC12CLK=MODOSC UCSCTL8 |= MODOSCREQEN; REFCTL0 &= ~REFVSEL_3; REFCTL0 |= REFVSEL_1 + REFON; // Configure internal 2.5V reference __delay_cycles(1900); // delay for reference to settle ADC12CTL0 &= ~ADC12ENC; // Ensure ENC is clear ADC12CTL0 = ADC12ON + ADC12SHT0_15 + ADC12MSC; ADC12CTL1 = ADC12SHP + ADC12CONSEQ_1 + ADC12SSEL_0; ADC12CTL2 = ADC12RES_2; ADC12MCTL0 = ADC12SREF_1 + TEMP_CHANNEL; ADC12MCTL1 = ADC12SREF_1 + VCC_CHANNEL + ADC12EOS; ADC12IE = 0x00; CAL_ADC_20T30 = (*(int *)0x01A1E); //ADC temp calibration consts for 2.0V ref CAL_ADC_20T85 = (*(int *)0x01A20); if ( ((unsigned int)adcTemp25Calibration) == 0xFFFF ) { m = (85-30)/(float)(CAL_ADC_20T85 - CAL_ADC_20T30); //calculate the slope c = 85 - m*CAL_ADC_20T85; } else { // Calculate slope for 25C room temp //CAL_ADC_20T30 = adcTemp25Calibration; m = (85-25)/(float)(CAL_ADC_20T85 - adcTemp25Calibration); //calculate the slope c = 85 - m*CAL_ADC_20T85; } } /**********************************************************************//** * @brief Return light sensor sampled value in degree Celsius * * @param none * * @return lightSensorValue light sensor ADC sampled value *************************************************************************/ int HalAdcGetTempRaw(void) { return SavedADC12MEM0; } /**********************************************************************//** * @brief Return light sensor sampled value in degree Celsius * * @param none * * @return lightSensorValue light sensor ADC sampled value *************************************************************************/ unsigned long HalAdcGetTempDegC(void) { return IntDegC; } /**********************************************************************//** * @brief Return light sensor sampled value in degree Fahrenheit * * @param none * * @return lightSensorValue light sensor ADC sampled value *************************************************************************/ unsigned long HalAdcGetTempDegF(void) { return IntDegF; } /**********************************************************************//** * @brief Return light sensor sampled value * * @param none * * @return lightSensorValue light sensor ADC sampled value *************************************************************************/ unsigned long HalAdcGetVcc(void) { return Vcc; } /**********************************************************************//** * @brief Turns off / disable the ADC12. * * @param none * * @return none *************************************************************************/ void HalAdcShutDown(void) { //Turn off ADC module and internal reference ADC12CTL0 &= ~ADC12ENC; ADC12CTL0 = 0x00; ADC12IE = 0x00; REFCTL0 &= ~REFON; } /**********************************************************************//** * @brief Converts the ADC readings into Vcc & Temp. * * @param none * * @return none *************************************************************************/ void HalAdcConvertTempVcc(void) { IntDegF = 10*(SavedADC12MEM0*m + c) *((float)9/5) + 320; IntDegC = 10*(SavedADC12MEM0*m + c); Vcc = (SavedADC12MEM1 * 40) >> 12; } /*----------------------------------------------------------------------------*/ /**********************************************************************//** * @brief Starts the ADC conversion. * * @param none * * @return none *************************************************************************/ void HalAdcStartRead(void) { ADC12IFG = 0x00; // Clear all ADC12 channel int flags REFCTL0 |= REFON; // Turn on ADC12 reference __delay_cycles(1900); // delay for reference to settle ADC12IE = BIT1; // Enable memory 1 interrupt ADC12CTL0 |= ADC12ENC | ADC12SC ; // Start conversion } /**********************************************************************//** * @brief Sets the flag that causes an exit into active CPU mode from * the ADC12 ISR. * * @param quit * * - 1 - Exit active from ADC12 ISR * - 0 - Remain in LPMx on exit from ADC12ISR * * @return none *************************************************************************/ void HalAdcSetQuitFromISR(unsigned char quit) { exit_active_from_ADC12 = quit; } /*----------------------------------------------------------------------------*/ #pragma vector=ADC12_VECTOR __interrupt void ADC12_ISR(void) { ADC12CTL0 &= ~ADC12ENC; // Disable ADC12 conversions REFCTL0 &= ~REFON; // Disable reference (if enabled) SavedADC12MEM0 = ADC12MEM0; // Store the sampled data SavedADC12MEM1 = ADC12MEM1; if (exit_active_from_ADC12) __bic_SR_register_on_exit(LPM3_bits); }
