Part Number: TMS570LC4357
I am trying to calculate the 64-bit CRC over the text section of the map for a TMS570 class processor using code composer in the HL_sys_link.cmd file. None of the examples or tutorials on-line appears to work. I get the following warning:
#10199-D CRC table operator (_code_crc_table) ignored for ".text": CRC table operator cannot be associated with empty output section
When I add objects to text field in the CRC statement it creates the CRC table structure but indicates that the vectors will no longer fit in memory.
Here's the cmd file:
/* sys_link.cmd */
* Copyright (C) 2009-2014 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Linker Settings */
--retain="*(.intvecs)"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* Memory Map */
MEMORY
/* USER CODE BEGIN (2) */
/* USER CODE END */
VECTORS (X) : origin=0x00000000 length=0x00000020
FLASH0 (RX) : origin=0x00000020 length=0x001FFFE0
FLASH1 (RX) : origin=0x00200000 length=0x00200000
STACKS (RW) : origin=0x08000000 length=0x00001500
RAM (RW) : origin=0x08001500 length=0x0007EB00
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* Section Configuration */
SECTIONS
/* USER CODE BEGIN (5) */
/* USER CODE END */
.intvecs : {} > VECTORS
.text : RUN_START( TEXT_SEG_START ), RUN_SIZE( TEXT_SEG_SIZE ) align(8) {} > FLASH0 | FLASH1
.const : RUN_START( CONST_SEG_START ), RUN_SIZE( CONST_SEG_SIZE ) align(8) {} > FLASH0 | FLASH1
.text : {} palign=64, fill=0xffffffff, crc_table(_code_crc_table, algorithm=TMS570_CRC64_ISO)
.cinit align(8) : {} > FLASH0 | FLASH1
.pinit align(8) : {} > FLASH0 | FLASH1
.bss : {} > RAM
.data : {} > RAM
.sysmem : {} > RAM
.TI.crctab : {} palign=8
/* USER CODE BEGIN (6) */
LOG_DATA : START( ulLOGStartAddr ), END( ulLOGEndAddr ) > RAM
.sl_stflash_SRAM : RUN = RAM, LOAD = FLASH0|FLASH1, LOAD_START(ulHighHandlerLoadStart), LOAD_END(ulHighHandlerLoadEnd), LOAD_SIZE(ulHighHandlerSize), RUN_START( ulHighHandlerStartAddr ), RUN_END( ulHighHandlerEndAddr )
/* USER CODE END */
/* USER CODE BEGIN (7) */
/* USER CODE END */
/* Misc */
/* USER CODE BEGIN (8) */
/* USER CODE END */
