Other Parts Discussed in Thread: CONTROLSUITE
I am trying the example blinky_cpu01.C
When I run the program
I created a new project and copy all files from include and library c code. The only modifications were done to 2837x_FLASH_lnk_cpu1.cmd that i merged with F2837xD_Headers_nonBios_cpu1.cmd (I am running compiler TI v20.2.1.LTS) and it seems to be related to ramfuncs but I don't know how to fix it.
When I debug, the function DELAY_US(1000) takes me to interrupt void ILLEGAL_ISR(void).
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE1 for data allocation */
/* BEGIN is used for the "boot to Flash" bootloader mode */
BEGIN : origin = 0x080000, length = 0x000002
RAMM0 : origin = 0x000122, length = 0x0002DE
RAMD0 : origin = 0x00B000, length = 0x000800
RAMLS0 : origin = 0x008000, length = 0x000800
RAMLS1 : origin = 0x008800, length = 0x000800
RAMLS2 : origin = 0x009000, length = 0x000800
RAMLS3 : origin = 0x009800, length = 0x000800
RAMLS4 : origin = 0x00A000, length = 0x000800
RAMGS14 : origin = 0x01A000, length = 0x001000
RAMGS15 : origin = 0x01B000, length = 0x001000
RESET : origin = 0x3FFFC0, length = 0x000002
/* Flash sectors */
FLASHA : origin = 0x080002, length = 0x001FFE /* on-chip Flash */
FLASHB : origin = 0x082000, length = 0x002000 /* on-chip Flash */
FLASHC : origin = 0x084000, length = 0x002000 /* on-chip Flash */
FLASHD : origin = 0x086000, length = 0x002000 /* on-chip Flash */
FLASHE : origin = 0x088000, length = 0x008000 /* on-chip Flash */
FLASHF : origin = 0x090000, length = 0x008000 /* on-chip Flash */
FLASHG : origin = 0x098000, length = 0x008000 /* on-chip Flash */
FLASHH : origin = 0x0A0000, length = 0x008000 /* on-chip Flash */
FLASHI : origin = 0x0A8000, length = 0x008000 /* on-chip Flash */
FLASHJ : origin = 0x0B0000, length = 0x008000 /* on-chip Flash */
FLASHK : origin = 0x0B8000, length = 0x002000 /* on-chip Flash */
FLASHL : origin = 0x0BA000, length = 0x002000 /* on-chip Flash */
FLASHM : origin = 0x0BC000, length = 0x002000 /* on-chip Flash */
FLASHN : origin = 0x0BE000, length = 0x002000 /* on-chip Flash */
PAGE 1: /* Data Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE0 for program allocation */
BOOT_RSVD : origin = 0x000002, length = 0x000120 /* Part of M0, BOOT rom will use this for stack */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAMD1 : origin = 0x00B800, length = 0x000800
RAMLS5 : origin = 0x00A800, length = 0x000800
RAMGS0 : origin = 0x00C000, length = 0x001000
RAMGS1 : origin = 0x00D000, length = 0x001000
RAMGS2 : origin = 0x00E000, length = 0x001000
RAMGS3 : origin = 0x00F000, length = 0x001000
RAMGS4 : origin = 0x010000, length = 0x001000
RAMGS5 : origin = 0x011000, length = 0x001000
RAMGS6 : origin = 0x012000, length = 0x001000
RAMGS7 : origin = 0x013000, length = 0x001000
RAMGS8 : origin = 0x014000, length = 0x001000
RAMGS9 : origin = 0x015000, length = 0x001000
RAMGS10 : origin = 0x016000, length = 0x001000
RAMGS11 : origin = 0x017000, length = 0x001000
RAMGS12 : origin = 0x018000, length = 0x001000
RAMGS13 : origin = 0x019000, length = 0x001000
CPU2TOCPU1RAM : origin = 0x03F800, length = 0x000400
CPU1TOCPU2RAM : origin = 0x03FC00, length = 0x000400
ADCA_RESULT : origin = 0x000B00, length = 0x000020
ADCB_RESULT : origin = 0x000B20, length = 0x000020
ADCC_RESULT : origin = 0x000B40, length = 0x000020
ADCD_RESULT : origin = 0x000B60, length = 0x000020
ADCA : origin = 0x007400, length = 0x000080
ADCB : origin = 0x007480, length = 0x000080
ADCC : origin = 0x007500, length = 0x000080
ADCD : origin = 0x007580, length = 0x000080
ANALOG_SUBSYS : origin = 0x05D180, length = 0x000080
CLA1 : origin = 0x001400, length = 0x000040 /* CLA registers */
CLB_XBAR : origin = 0x007A40, length = 0x000040
CMPSS1 : origin = 0x005C80, length = 0x000020
CMPSS2 : origin = 0x005CA0, length = 0x000020
CMPSS3 : origin = 0x005CC0, length = 0x000020
CMPSS4 : origin = 0x005CE0, length = 0x000020
CMPSS5 : origin = 0x005D00, length = 0x000020
CMPSS6 : origin = 0x005D20, length = 0x000020
CMPSS7 : origin = 0x005D40, length = 0x000020
CMPSS8 : origin = 0x005D60, length = 0x000020
CPU_TIMER0 : origin = 0x000C00, length = 0x000008 /* CPU Timer0 registers */
CPU_TIMER1 : origin = 0x000C08, length = 0x000008 /* CPU Timer1 registers */
CPU_TIMER2 : origin = 0x000C10, length = 0x000008 /* CPU Timer2 registers */
DACA : origin = 0x005C00, length = 0x000010
DACB : origin = 0x005C10, length = 0x000010
DACC : origin = 0x005C20, length = 0x000010
DMA : origin = 0x001000, length = 0x000200
DMACLASRCSEL : origin = 0x007980, length = 0x000040
ECAP1 : origin = 0x005000, length = 0x000020 /* Enhanced Capture 1 registers */
ECAP2 : origin = 0x005020, length = 0x000020 /* Enhanced Capture 2 registers */
ECAP3 : origin = 0x005040, length = 0x000020 /* Enhanced Capture 3 registers */
ECAP4 : origin = 0x005060, length = 0x000020 /* Enhanced Capture 4 registers */
ECAP5 : origin = 0x005080, length = 0x000020 /* Enhanced Capture 5 registers */
ECAP6 : origin = 0x0050A0, length = 0x000020 /* Enhanced Capture 6 registers */
EMIF1 : origin = 0x047000, length = 0x000800
EMIF2 : origin = 0x047800, length = 0x000800
EQEP1 : origin = 0x005100, length = 0x000040 /* Enhanced QEP 1 registers */
EQEP2 : origin = 0x005140, length = 0x000040 /* Enhanced QEP 2 registers */
EQEP3 : origin = 0x005180, length = 0x000040 /* Enhanced QEP 3 registers */
EPWM1 : origin = 0x004000, length = 0x000100 /* Enhanced PWM 1 registers */
EPWM2 : origin = 0x004100, length = 0x000100 /* Enhanced PWM 2 registers */
EPWM3 : origin = 0x004200, length = 0x000100 /* Enhanced PWM 3 registers */
EPWM4 : origin = 0x004300, length = 0x000100 /* Enhanced PWM 4 registers */
EPWM5 : origin = 0x004400, length = 0x000100 /* Enhanced PWM 5 registers */
EPWM6 : origin = 0x004500, length = 0x000100 /* Enhanced PWM 6 registers */
EPWM7 : origin = 0x004600, length = 0x000100 /* Enhanced PWM 7 registers */
EPWM8 : origin = 0x004700, length = 0x000100 /* Enhanced PWM 8 registers */
EPWM9 : origin = 0x004800, length = 0x000100 /* Enhanced PWM 9 registers */
EPWM10 : origin = 0x004900, length = 0x000100 /* Enhanced PWM 10 registers */
EPWM11 : origin = 0x004A00, length = 0x000100 /* Enhanced PWM 11 registers */
EPWM12 : origin = 0x004B00, length = 0x000100 /* Enhanced PWM 12 registers */
EPWM_XBAR : origin = 0x007A00, length = 0x000040
FLASH0_CTRL : origin = 0x05F800, length = 0x000300
FLASH0_ECC : origin = 0x05FB00, length = 0x000040
GPIOCTRL : origin = 0x007C00, length = 0x000180 /* GPIO control registers */
GPIODAT : origin = 0x007F00, length = 0x000030 /* GPIO data registers */
OUTPUT_XBAR : origin = 0x007A80, length = 0x000040
I2CA : origin = 0x007300, length = 0x000040 /* I2C-A registers */
I2CB : origin = 0x007340, length = 0x000040 /* I2C-B registers */
IPC : origin = 0x050000, length = 0x000024
FLASHPUMPSEMAPHORE : origin = 0x050024, length = 0x000002
ROMPREFETCH : origin = 0x05E608, length = 0x000002
MEMCFG : origin = 0x05F400, length = 0x000080 /* Mem Config registers */
EMIF1CONFIG : origin = 0x05F480, length = 0x000020 /* Emif-1 Config registers */
EMIF2CONFIG : origin = 0x05F4A0, length = 0x000020 /* Emif-2 Config registers */
ACCESSPROTECTION : origin = 0x05F4C0, length = 0x000040 /* Access Protection registers */
MEMORYERROR : origin = 0x05F500, length = 0x000040 /* Access Protection registers */
ROMWAITSTATE : origin = 0x05F540, length = 0x000002 /* ROM Config registers */
MCBSPA : origin = 0x006000, length = 0x000040 /* McBSP-A registers */
MCBSPB : origin = 0x006040, length = 0x000040 /* McBSP-A registers */
NMIINTRUPT : origin = 0x007060, length = 0x000010 /* NMI Watchdog Interrupt Registers */
PIE_CTRL : origin = 0x000CE0, length = 0x000020 /* PIE control registers */
PIE_VECT : origin = 0x000D00, length = 0x000200 /* PIE Vector Table */
SCIA : origin = 0x007200, length = 0x000010 /* SCI-A registers */
SCIB : origin = 0x007210, length = 0x000010 /* SCI-B registers */
SCIC : origin = 0x007220, length = 0x000010 /* SCI-C registers */
SCID : origin = 0x007230, length = 0x000010 /* SCI-D registers */
SDFM1 : origin = 0x005E00, length = 0x000080 /* Sigma delta 1 registers */
SDFM2 : origin = 0x005E80, length = 0x000080 /* Sigma delta 2 registers */
SPIA : origin = 0x006100, length = 0x000010
SPIB : origin = 0x006110, length = 0x000010
SPIC : origin = 0x006120, length = 0x000010
SPID : origin = 0x006130, length = 0x000010
UPP : origin = 0x006200, length = 0x000100 /* uPP registers */
DEV_CFG : origin = 0x05D000, length = 0x000180
CLK_CFG : origin = 0x05D200, length = 0x000100
CPU_SYS : origin = 0x05D300, length = 0x000100
INPUT_XBAR : origin = 0x007900, length = 0x000020
XBAR : origin = 0x007920, length = 0x000020
SYNC_SOC : origin = 0x007940, length = 0x000010
WD : origin = 0x007000, length = 0x000040
XINT : origin = 0x007070, length = 0x000010
DCSM_Z1 : origin = 0x05F000, length = 0x000030 /* Zone 1 Dual code security module registers */
DCSM_Z2 : origin = 0x05F040, length = 0x000030 /* Zone 2 Dual code security module registers */
DCSM_COMMON : origin = 0x05F070, length = 0x000010 /* Common Dual code security module registers */
DCSM_Z1_OTP : origin = 0x078000, length = 0x000020 /* Part of Z1 OTP. LinkPointer/JTAG lock/ Boot Mode */
DCSM_Z2_OTP : origin = 0x078200, length = 0x000020 /* Part of Z2 OTP. LinkPointer/JTAG lock */
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHB PAGE = 0, ALIGN(4)
.pinit : > FLASHB, PAGE = 0, ALIGN(4)
.text : >> FLASHB | FLASHC | FLASHD | FLASHE PAGE = 0, ALIGN(4)
codestart : > BEGIN PAGE = 0, ALIGN(4)
ramfuncs : LOAD = FLASHD,
RUN = RAMLS0 | RAMLS1 | RAMLS2 |RAMLS3,
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
RUN_SIZE(_RamfuncsRunSize),
RUN_END(_RamfuncsRunEnd),
PAGE = 0, ALIGN(4)
/* Allocate uninitalized data sections: */
.stack : > RAMM1 PAGE = 1
.ebss : >> RAMLS5 | RAMGS0 | RAMGS1 PAGE = 1
.esysmem : > RAMLS5 PAGE = 1
/* Initalized sections go in Flash */
.econst : >> FLASHF | FLASHG | FLASHH PAGE = 0, ALIGN(4)
.switch : > FLASHB PAGE = 0, ALIGN(4)
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
Filter_RegsFile : > RAMGS0, PAGE = 1
SHARERAMGS0 : > RAMGS0, PAGE = 1
SHARERAMGS1 : > RAMGS1, PAGE = 1
/* The following section definitions are required when using the IPC API Drivers */
GROUP : > CPU1TOCPU2RAM, PAGE = 1
PUTBUFFER
PUTWRITEIDX
GETREADIDX
GROUP : > CPU2TOCPU1RAM, PAGE = 1
GETBUFFER : TYPE = DSECT
GETWRITEIDX : TYPE = DSECT
PUTREADIDX : TYPE = DSECT
/*** PIE Vect Table and Boot ROM Variables Structures ***/
UNION run = PIE_VECT, PAGE = 1
PieVectTableFile
GROUP
EmuKeyVar
EmuBModeVar
FlashCallbackVar
FlashScalingVar
AdcaResultFile : > ADCA_RESULT, PAGE = 1
AdcbResultFile : > ADCB_RESULT, PAGE = 1
AdccResultFile : > ADCC_RESULT, PAGE = 1
AdcdResultFile : > ADCD_RESULT, PAGE = 1
AdcaRegsFile : > ADCA, PAGE = 1
AdcbRegsFile : > ADCB, PAGE = 1
AdccRegsFile : > ADCC, PAGE = 1
AdcdRegsFile : > ADCD, PAGE = 1
AnalogSubsysRegsFile : > ANALOG_SUBSYS, PAGE = 1
Cla1RegsFile : > CLA1, PAGE = 1
Cla1SoftIntRegsFile : > PIE_CTRL, PAGE = 1, type=DSECT
ClbXbarRegsFile : > CLB_XBAR PAGE = 1
Cmpss1RegsFile : > CMPSS1, PAGE = 1
Cmpss2RegsFile : > CMPSS2, PAGE = 1
Cmpss3RegsFile : > CMPSS3, PAGE = 1
Cmpss4RegsFile : > CMPSS4, PAGE = 1
Cmpss5RegsFile : > CMPSS5, PAGE = 1
Cmpss6RegsFile : > CMPSS6, PAGE = 1
Cmpss7RegsFile : > CMPSS7, PAGE = 1
Cmpss8RegsFile : > CMPSS8, PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1
CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1
DacaRegsFile : > DACA PAGE = 1
DacbRegsFile : > DACB PAGE = 1
DaccRegsFile : > DACC PAGE = 1
DcsmZ1RegsFile : > DCSM_Z1, PAGE = 1
DcsmZ2RegsFile : > DCSM_Z2, PAGE = 1
DcsmCommonRegsFile : > DCSM_COMMON, PAGE = 1
/*** Warning: Only remove "Type = NOLOAD" to program OTP Locations ***/
DcsmZ1OtpFile : > DCSM_Z1_OTP, PAGE = 1, type = NOLOAD
DcsmZ2OtpFile : > DCSM_Z2_OTP, PAGE = 1, type = NOLOAD
DmaRegsFile : > DMA PAGE = 1
DmaClaSrcSelRegsFile : > DMACLASRCSEL PAGE = 1
ECap1RegsFile : > ECAP1, PAGE = 1
ECap2RegsFile : > ECAP2, PAGE = 1
ECap3RegsFile : > ECAP3, PAGE = 1
ECap4RegsFile : > ECAP4, PAGE = 1
ECap5RegsFile : > ECAP5, PAGE = 1
ECap6RegsFile : > ECAP6, PAGE = 1
Emif1RegsFile : > EMIF1 PAGE = 1
Emif2RegsFile : > EMIF2 PAGE = 1
EPwm1RegsFile : > EPWM1, PAGE = 1
EPwm2RegsFile : > EPWM2, PAGE = 1
EPwm3RegsFile : > EPWM3, PAGE = 1
EPwm4RegsFile : > EPWM4, PAGE = 1
EPwm5RegsFile : > EPWM5, PAGE = 1
EPwm6RegsFile : > EPWM6, PAGE = 1
EPwm7RegsFile : > EPWM7, PAGE = 1
EPwm8RegsFile : > EPWM8, PAGE = 1
EPwm9RegsFile : > EPWM9, PAGE = 1
EPwm10RegsFile : > EPWM10, PAGE = 1
EPwm11RegsFile : > EPWM11, PAGE = 1
EPwm12RegsFile : > EPWM12, PAGE = 1
EPwmXbarRegsFile : > EPWM_XBAR PAGE = 1
EQep1RegsFile : > EQEP1, PAGE = 1
EQep2RegsFile : > EQEP2, PAGE = 1
EQep3RegsFile : > EQEP3, PAGE = 1
Flash0CtrlRegsFile : > FLASH0_CTRL PAGE = 1
Flash0EccRegsFile : > FLASH0_ECC PAGE = 1
GpioCtrlRegsFile : > GPIOCTRL, PAGE = 1
GpioDataRegsFile : > GPIODAT, PAGE = 1
OutputXbarRegsFile : > OUTPUT_XBAR PAGE = 1
I2caRegsFile : > I2CA, PAGE = 1
I2cbRegsFile : > I2CB, PAGE = 1
InputXbarRegsFile : > INPUT_XBAR PAGE = 1
XbarRegsFile : > XBAR PAGE = 1
IpcRegsFile : > IPC, PAGE = 1
FlashPumpSemaphoreRegsFile : > FLASHPUMPSEMAPHORE, PAGE = 1
RomPrefetchRegsFile : > ROMPREFETCH, PAGE = 1
MemCfgRegsFile : > MEMCFG, PAGE = 1
Emif1ConfigRegsFile : > EMIF1CONFIG, PAGE = 1
Emif2ConfigRegsFile : > EMIF2CONFIG, PAGE = 1
AccessProtectionRegsFile : > ACCESSPROTECTION, PAGE = 1
MemoryErrorRegsFile : > MEMORYERROR, PAGE = 1
RomWaitStateRegsFile : > ROMWAITSTATE, PAGE = 1
McbspaRegsFile : > MCBSPA, PAGE = 1
McbspbRegsFile : > MCBSPB, PAGE = 1
UppRegsFile : > UPP, PAGE = 1
NmiIntruptRegsFile : > NMIINTRUPT, PAGE = 1
PieCtrlRegsFile : > PIE_CTRL, PAGE = 1
SciaRegsFile : > SCIA, PAGE = 1
ScibRegsFile : > SCIB, PAGE = 1
ScicRegsFile : > SCIC, PAGE = 1
ScidRegsFile : > SCID, PAGE = 1
Sdfm1RegsFile : > SDFM1, PAGE = 1
Sdfm2RegsFile : > SDFM2, PAGE = 1
SpiaRegsFile : > SPIA, PAGE = 1
SpibRegsFile : > SPIB, PAGE = 1
SpicRegsFile : > SPIC, PAGE = 1
SpidRegsFile : > SPID, PAGE = 1
DevCfgRegsFile : > DEV_CFG, PAGE = 1
ClkCfgRegsFile : > CLK_CFG, PAGE = 1
CpuSysRegsFile : > CPU_SYS, PAGE = 1
SyncSocRegsFile : > SYNC_SOC, PAGE = 1
WdRegsFile : > WD, PAGE = 1
XintRegsFile : > XINT PAGE = 1
MemCfgRegs : > MEMCFG PAGE = 1
// End of file.
