1,EPWM8A,EPWM8B,EPWM9A,EPWM9B,EPWM10A,
Can the five ch BST be set to send waves with a difference of 72 degrees?
2,EPWM8A and EPWM8B, that is, BST1 and BST3, have a difference of 144 degrees. How to set?
Hi Delmore,
Can you please provide more context for question 1? Do you have a diagram perhaps of your desired output?
You won't be able to set a phase shift through the conventional way since you want the phase shift between A and B channels of the same EPWM module but you can create a shift in the outputs based on the counter compare values. You could achieve a shift by offsetting CMPB with regards to CMPA.
Marlyn
