Dear all,
I have configured three level inverter PWM in my system and I am getting some error initially and when there is no COMPARE event at that time 1B AND 2B are HIGH unintentionally because they are complementally .
I have attached the image for PWM given to one leg for your ref.
ch-1 , ch-2 , ch-3 ,ch-4. are the scope Channel number and scope image with T3 AND T4 ARE HIGH when T1 AND T2 are low. this occurs only during initialization and then its all ok.
i have attached code and of initialization and EnablePWM function .this enablepwm is only call once during start-up at every staring event only.
please suggest me how can i make T3 And T4 both Low .
void InitPwm1(void)
EALLOW;
EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD;
EPwm1Regs.TBCTR = 0x0000;
EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP;// Clear counter
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
#ifdef SLAVE_MODE
EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE;
#else
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;
#endif
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm1Regs.CMPC = 0;
#ifdef SLAVE_MODE
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
#else
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
#endif
//SyncSocRegs.SYNCSELECT.bit.SYNCOUT = 0;
SyncSocRegs.SYNCSELECT.bit.EPWM7SYNCIN = 0; //
SyncSocRegs.SYNCSELECT.bit.EPWM4SYNCIN = 0;
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm1Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm1Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
/// EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// SyncSocRegs.SYNCSELECT.bit.EPWM4SYNCIN = 0;
#ifdef EPWM7_SOCA
EPwm1Regs.ETSEL.bit.SOCAEN=1;
EPwm1Regs.ETSEL.bit.SOCASEL= SOC_EVENT_TIME;
EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
#ifdef EPWM1INTENABLE
EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRDZERO; // Select INT on Zero event
EPwm1Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 3rd event*/
#endif
EPwm1Regs.TBPHS.bit.TBPHS = 0;
//EPwm1Regs.CMPA.bit.CMPA = EPWM1_TIMER_TBPRD>>1;
//EPwm1Regs.CMPB.bit.CMPB = EPWM1_TIMER_TBPRD>>1;
EDIS;
void InitPwm2(void)
EALLOW;
EPwm2Regs.TBPRD = EPWM1_TIMER_TBPRD_TOP; // Set timer period 801 TBCLKs
EPwm2Regs.TBPHS.bit.TBPHS = EPWM1_TIMER_TBPRD;
EPwm2Regs.TBCTL.bit.PHSDIR = TB_UP;
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm2Regs.TBCTL.bit.SYNCOSEL=TB_SYNC_IN;
EPwm2Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm2Regs.DBCTL.bit.OUT_MODE= DB_FULL_ENABLE;
EPwm2Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm2Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; // Load on Zero
// EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD;
#ifdef EPWM8_SOCA
EPwm2Regs.ETSEL.bit.SOCAEN=1;
EPwm2Regs.ETSEL.bit.SOCASEL=SOC_EVENT_TIME;
EPwm2Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
EDIS;
void InitPwm3(void)
EALLOW;
EPwm3Regs.TBPRD = EPWM1_TIMER_TBPRD_TOP; // Set timer period 801 TBCLKs
EPwm3Regs.TBCTL.bit.PHSDIR= TB_UP;
EPwm3Regs.TBCTR = 0x0000; // Clear counter
EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm3Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm3Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm3Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm3Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm3Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD;
// EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD;
#ifdef EPWM9_SOCA
EPwm3Regs.ETSEL.bit.SOCAEN=1;
EPwm3Regs.ETSEL.bit.SOCASEL=SOC_EVENT_TIME;
EPwm3Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
// EPwm3Regs.ETSEL.bit.SOCAEN=1;
// EPwm3Regs.ETSEL.bit.SOCASEL=ET_CTR_ZERO;
// EPwm3Regs.ETPS.bit.SOCAPRD = ET_1ST;
/* EPwm3Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm3Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm3Regs.ETPS.bit.INTPRD = ET_3RD; // Generate INT on 3rd event*/
EPwm3Regs.TBPHS.bit.TBPHS = EPWM1_TIMER_TBPRD;
EDIS;
void InitPwm7(void)
EALLOW;
// EPwm7Regs.TBPRD = EPWM1_TIMER_TBPRD_TOP; // Set timer period 801 TBCLKs
EPwm7Regs.TBPRD = EPWM1_TIMER_TBPRD;
EPwm7Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm7Regs.TBCTL.bit.PHSDIR= TB_UP;
EPwm7Regs.TBCTR = 0x0000; // Clear counter
EPwm7Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm7Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm7Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm7Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm7Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm7Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm7Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm7Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm7Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm7Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm7Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm7Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
// EPwm7Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
#ifdef EPWM9_SOCA
EPwm7Regs.ETSEL.bit.SOCAEN=1;
EPwm7Regs.ETSEL.bit.SOCASEL=SOC_EVENT_TIME;
EPwm7Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
// EPwm7Regs.ETSEL.bit.SOCAEN=1;
// EPwm7Regs.ETSEL.bit.SOCASEL=ET_CTR_ZERO;
// EPwm7Regs.ETPS.bit.SOCAPRD = ET_1ST;
/* EPwm7Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm7Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm7Regs.ETPS.bit.INTPRD = ET_3RD; // Generate INT on 3rd event*/
EPwm7Regs.TBPHS.bit.TBPHS =0;
// EPwm7Regs.CMPA.bit.CMPA = EPwm3_TIMER_TBPRD>>1;
//EPwm7Regs.CMPB.bit.CMPB = EPwm3_TIMER_TBPRD>>1;
EDIS;
void InitPwm8(void)
EALLOW;
EPwm8Regs.TBPRD = EPWM1_TIMER_TBPRD_TOP; // Set timer period 801 TBCLKs
EPwm8Regs.TBCTL.bit.PHSDIR= TB_UP;
EPwm8Regs.TBCTR = 0x0000; // Clear counter
// EPwm8Regs.CMPA.bit.CMPA = 0;
EPwm8Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm8Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm8Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm8Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm8Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm8Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm8Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm8Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm8Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm8Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm8Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm8Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm8Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; // Load on Zero
// EPwm8Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD;
#ifdef EPWM9_SOCA
EPwm8Regs.ETSEL.bit.SOCAEN=1;
EPwm8Regs.ETSEL.bit.SOCASEL=SOC_EVENT_TIME;
EPwm8Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
// EPwm8Regs.ETSEL.bit.SOCAEN=1;
// EPwm8Regs.ETSEL.bit.SOCASEL=ET_CTR_ZERO;
// EPwm8Regs.ETPS.bit.SOCAPRD = ET_1ST;
/* EPwm8Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm8Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm8Regs.ETPS.bit.INTPRD = ET_3RD; // Generate INT on 3rd event*/
EPwm8Regs.TBPHS.bit.TBPHS = EPWM1_TIMER_TBPRD;
// EPwm8Regs.CMPA.bit.CMPA = EPwm3_TIMER_TBPRD>>1;
//EPwm8Regs.CMPB.bit.CMPB = EPwm3_TIMER_TBPRD>>1;
EDIS;
void InitPwm9(void)
EALLOW;
// EPwm9Regs.TBPRD = EPWM1_TIMER_TBPRD_TOP; // Set timer period 801 TBCLKs
EPwm9Regs.TBPRD = EPWM1_TIMER_TBPRD;
// Phase is 0
EPwm9Regs.TBCTL.bit.PHSDIR= TB_UP;
EPwm9Regs.TBCTR = 0x0000; // Clear counter
EPwm9Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm9Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm9Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm9Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm9Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm9Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm9Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// EPwm9Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm9Regs.DBFED.bit.DBFED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm9Regs.DBRED.bit.DBRED= FED_TIME*PWM_BASE_FREQUENCY;
EPwm9Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
// EPwm9Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm9Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
// EPwm9Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
#ifdef EPWM9_SOCA
EPwm9Regs.ETSEL.bit.SOCAEN=1;
EPwm9Regs.ETSEL.bit.SOCASEL=SOC_EVENT_TIME;
EPwm9Regs.ETPS.bit.SOCAPRD = ET_1ST;
#endif
// EPwm9Regs.ETSEL.bit.SOCAEN=1;
// EPwm9Regs.ETSEL.bit.SOCASEL=ET_CTR_ZERO;
// EPwm9Regs.ETPS.bit.SOCAPRD = ET_1ST;
/* EPwm9Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm9Regs.ETSEL.bit.INTEN = 1; // Enable INT
EPwm9Regs.ETPS.bit.INTPRD = ET_3RD; // Generate INT on 3rd event*/
EPwm9Regs.TBPHS.bit.TBPHS =0;
// EPwm9Regs.CMPA.bit.CMPA = EPwm3_TIMER_TBPRD>>1;
//EPwm9Regs.CMPB.bit.CMPB = EPwm3_TIMER_TBPRD>>1;
EDIS;
void EnablePwm(void)
fmR=0.0;
fmY=0.0;
fmB=0.0;
Idout = 0.1;
flag.bit.InvStatus=1;
//flag.bit.OpenLoopInverter=1;
InvParaInitialisation();
g_uiSoftStartDone=0;
inverterStartupCall();
if(flag.bit.MPS_Operating_Mode==UF_MODE)
//flag.bit.UF_ssDone=0;
g_structVr.term.Ref = config.IntrnlParams.VRampRate/config.CalibData.VaRms;
g_structVy.term.Ref = config.IntrnlParams.VRampRate/config.CalibData.VbRms;
g_structVb.term.Ref = config.IntrnlParams.VRampRate/config.CalibData.VcRms;
//starting uf mode voltage from 50Hz. change to intial value if needed to start from any other value
//finalW = (config.UserParams.Fout*twoPI);
flag.bit.Fre_ssDone =0;
EALLOW;
EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
// EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET;
// EPwm1Regs.AQCTLA.bit.PRD = AQ_CLEAR;
// //EPwm1Regs.AQCTLB.bit.CAU = AQ_CLEAR;
// //EPwm1Regs.AQCTLB.bit.CAD = AQ_SET;
// EPwm2Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
// EPwm2Regs.AQCTLA.bit.PRD = AQ_SET;
// EPwm3Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
// EPwm3Regs.AQCTLA.bit.PRD = AQ_SET;
// EPwm7Regs.AQCTLA.bit.ZRO = AQ_SET;
// EPwm7Regs.AQCTLA.bit.PRD = AQ_CLEAR;
// EPwm8Regs.AQCTLA.bit.ZRO = AQ_CLEAR; // Set PWM1A on event A, up
// EPwm8Regs.AQCTLA.bit.PRD = AQ_SET; // Clear PWM1A on event A,
// EPwm9Regs.AQCTLA.bit.ZRO = AQ_SET; // Clear Pwm3A on event A,
// EPwm9Regs.AQCTLA.bit.PRD = AQ_CLEAR; // Set Pwm3A on event A, up
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm1Regs.AQCTLA.bit.CAD = AQ_SET;
EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm2Regs.AQCTLA.bit.CAD = AQ_SET;
EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm3Regs.AQCTLA.bit.CAD = AQ_SET;
EPwm7Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm7Regs.AQCTLA.bit.CAD = AQ_SET;
EPwm8Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on event A, up
EPwm8Regs.AQCTLA.bit.CAD = AQ_SET; // Clear PWM1A on event A,
EPwm9Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Clear Pwm3A on event A,
EPwm9Regs.AQCTLA.bit.CAD = AQ_SET; // Set Pwm3A on event A, up
// GpioDataRegs.GPADAT.bit.GPIO15=0;
// GpioDataRegs.GPADAT.bit.GPIO17=0;
TzEnable();
EDIS;
