LAUNCHXL-F28379D: Questions regarding importing a project and SysConfig
Part Number: LAUNCHXL-F28379D
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
Hi Experts,
Good day
I have a few questions regarding importing a project and SysConfig. The board that I am using is Launchpad F28379D the first problem is that when I am trying to import the project I am facing the following cross on the file that I am trying to learn.
I tried to reinstall C2000Ware. However, despite the fact that the files were replaced with new ones. The error is still there, and I cannot import the file.
The second question is related to the first LED blinking example to be set through SysConfig. I went through the instructions line-by-line, but could not manage to run the microcontroller the same way that we had in the reference file. I wanted to take some assistance on that side as well. Step-by-step assistance actually.
Please advise.
Josel
  • Josel,
    This seems to be an academy issue so I will bring in our academy experts. The second project in your screenshot shows a red X. I think that may be because the project already exists in your workspace FILE SYSTEM (you may have forgot to remove from the file system).
    Nima
    Did you install C2000Ware 4.03.00.00 in C:/ti/c2000_backup folder or you renamed the folder after installation?
    Can we start with clean C2000Ware install? I will uninstall old one, manually delete the folder. Reinstall the C2000Ware, and start a fresh workspace in new location.
    Let me know if you see any error.
    Regards, Santosh
