Part Number: TMDSCNCD28379D
Is there a conflict or arbitration required when accessing different Local Shared RAMs blocks at the same clock or conflict is only when trying to access the same LSxRAM block?
e.g., if CPU1 tries to access LS1RAM and CLA.CPU1 tries to access LS2RAM at the same time, is arbitration required (as with DMA and CPU accessing different GSxRAMs at the same time) ?
While this issue with regards to GSxRAMs is explicitly mentioned in the documentation, I couldn't find an answer to the LSxRAMs case.
Dvir
