Part Number: TMS320F28027
I am quite new to using the C2000 HEX utility option in CCS to generate a .HEX file for my project. I have been going through the sub section of the C2000 HEX Utility and came across the Boot Table Options.
I wanted to know whether its mandatory to fill the Boot Table Options sections or it should be left blank for generating the .HEX file. If the Boot table options section is left empty after the flash update will the code run from flash?
I will be using this .HEX file to flash update the TMS320F28027 via SCI with another processor.
Kind Regards
Madhav Bhaku
