Dear e2e team,
I have few questions regarding the Functional Safety certifications for the TMS320F28386D :
1. question about IEC60730 class of C2000Ware library
- Although the TMS320F28386D MCU supports Class B in the IEC60730, the IEC60730 of the C2000Ware library is QM. Please check if this is correct.
2. IEC60730 Certificaition of C2000ware library
- Has the C2000ware library received IEC60730 functional safety certification? Please check if there is a document (certificate with IEC60730, not ISO26262 certification).
- I understand that in the case of the TMS320F2806x MCU's C2000 SafeTI IEC60730 Software libraries, there is a certificate with IEC60730 text received from VDE.
Thanks & Regards,
Pls clarify what fo you mean by C2000Ware library? Which library are you referring to?
Are you referring to https://software-dl.ti.com/C2000/docs/software_guide/c2000ware/diaglib.html
Best Regards
Siddharth
