Part Number: LAUNCHXL-F28P55X
Other Parts Discussed in Thread: BOOSTXL-3PHGANINV, LVSERVOMTR, C2000WARE, C2000WARE-MOTORCONTROL-SDK
Your time is valuable, and I appreciate your support.
As suggested, I checked the link www.ti.com/.../overview.html and went through "Getting started with C2000 Software" under the section "Design & development resources". Then I followed the steps suggested in the page and could be able to start an empty project.
As I mentioned earlier test set up is as given below:
1. Controller Board: [LAUNCHXL-F28P55X (TMS320F28P55x LaunchPad developm.)]
2. Inverter Board: [BOOSTXL-3PHGANINV (48-V/10-A three-phase GaN inverter)].
3. Supported Motor: Low Voltage Servo Motor - Low voltage servo (encoder) motor and wiring harness
[LVSERVOMTR, P/N: M-2310P-LN-04K, Teknic M-2310P-LN-04K]
As part of motor control learning purpose, I searched the examples that can be used with LAUNCHXL-F28P55X + BOOSTXL-3PHGANINV + LVSERVOMTR. But I couldn't find the folder "f28p55x" from the directory C:\ti\c2000\C2000Ware_MotorControl_SDK_5_02_00_00\solutions\boostxl_3phganinv\
The folder "boostxl_3phganinv" contains these items only: docs, f2837x, f28002x, f28004x, hardware.
1) Could you please suggest the link to examples for using with the above combination?
2) Does the tool support any Simulation? This is for exploring the tool features without connecting the hardware.
Thanks and regards,
Prasanth
