TMS320F28377D: CLA Use; structure variable defines; CMD
Part Number: TMS320F28377D
Hi everyone,
I'm using CLA module recently and learn it through the example which is "C:\ti\c2000\C2000Ware_5_03_00_00\device_support\f2837xd\examples\dual\cla_asin".
#include "cla_asin_shared.h"
typedef struct
   float Delt;
   float P_Factor;
   float I_Factor;
}st_ClaPidData;
 st_ClaPidData st_ClaPid_DC;
float fDebug;
// function definitions
//Task 1 : Calculate asin(X)
// Description:
//             Step(1): Calculate absolute of the input X
//             Step(2):   Use the upper 6-bits of input "X" value as an
//                          index into the table to obtain the coefficients
//                          for a second order equation:
//                        _FPUasinTable:
//                             CoeffA0[0]
//                             CoeffA1[0]
//                             CoeffA2[0]
//                             CoeffA0[63]
//                             CoeffA1[63]
//                             CoeffA2[63]
//             Step(3):   Calculate the angle using the following equation:
//                        arctan(Ratio) = A0 + A1*Ratio + A2*Ratio*Ratio
//                        arctan(Ratio) = A0 + Ratio(A1 + A2*Ratio)
//             Step(4):   The final angle is determined as follows:
//                        if( X < 0 )
//                            Angle = -Angle
__interrupt void Cla1Task1 ( void )
    //Local Variables
    int xTblIdx; //integer valued Table index
    float A0,A1,A2; //Table coefficients
    float *entry;
    float result;
    //Preprocessing
    __mdebugstop();
    xTblIdx = fVal * TABLE_SIZE_M_1; //convert table index to u16-bits
    xTblIdx = xTblIdx * 3; //Table is ordered as 3 32-bit coefficients, the
                           //index points to these triplets, hence the *3*sizeof(float)
    entry = &CLAasinTable[xTblIdx];
    A0 = *entry++;
    A1 = *entry++;
    A2 = *entry;
    result = A0 + fVal*(A1 + A2*fVal);
    __mdebugstop();
    //Post processing
    if(fVal < 0)
        result = - result;
    fResult = result;
As you can see, two variables are defined in the "cla_asin.cla" file.  After compiling, the float variable "fDebug" was assigned an address in the ".map file", but the structure variable "st_ClaPid_DC" can not be found in the ".map file"
So, is there something to be paid attention in using structure variable? For the CLA file, they are all global variable, should be allocated to local RAM which is defined in CMD file.
             TMS320C2000 Linker PC v20.2.2
>> Linked Mon Oct 28 10:24:24 2024
OUTPUT FILE NAME:   <cla_asin_dc_cpu02.out>
ENTRY POINT SYMBOL: "_c_int00"  address: 00082a6d
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
PAGE 0:
  RAMM0                 00000123   000002dd  00000000  000002dd  RWIX
  RAMLS0                00008000   00000800  00000180  00000680  RWIX
  RAMLS1                00008800   00000800  0000010e  000006f2  RWIX
  RAMLS4_5              0000a000   00001000  000000c8  00000f38  RWIX
  RAMD0                 0000b000   00000800  00000004  000007fc  RWIX
  RAMGS14               0001a000   00001000  00000000  00001000  RWIX
  RAMGS15               0001b000   00000ff8  00000000  00000ff8  RWIX
  BEGIN                 00080000   00000002  00000002  00000000  RWIX
  FLASHA                00080002   00001ffe  00000000  00001ffe  RWIX
  FLASHB                00082000   00002000  00000fa8  00001058  RWIX
  FLASHC                00084000   00002000  00000000  00002000  RWIX
  FLASHD                00086000   00002000  000000cc  00001f34  RWIX
  FLASHE                00088000   00008000  00000000  00008000  RWIX
  FLASHF                00090000   00008000  00000000  00008000  RWIX
  FLASHG                00098000   00008000  00000000  00008000  RWIX
  FLASHH                000a0000   00008000  00000000  00008000  RWIX
  FLASHI                000a8000   00008000  00000000  00008000  RWIX
  FLASHJ                000b0000   00008000  00000000  00008000  RWIX
  FLASHK                000b8000   00002000  00000000  00002000  RWIX
  FLASHL                000ba000   00002000  00000000  00002000  RWIX
  FLASHM                000bc000   00002000  00000000  00002000  RWIX
  FLASHN                000be000   00001ff0  00000000  00001ff0  RWIX
  RESET                 003fffc0   00000002  00000000  00000002  RWIX
PAGE 1:
  BOOT_RSVD             00000002   00000121  00000000  00000121  RWIX
  RAMM1                 00000400   000003f8  00000100  000002f8  RWIX
  ADCARESULT            00000b00   00000018  00000018  00000000  RWIX
  ADCBRESULT            00000b20   00000018  00000018  00000000  RWIX
  ADCCRESULT            00000b40   00000018  00000018  00000000  RWIX
  ADCDRESULT            00000b60   00000018  00000018  00000000  RWIX
  CPUTIMER0             00000c00   00000008  00000008  00000000  RWIX
  CPUTIMER1             00000c08   00000008  00000008  00000000  RWIX
  CPUTIMER2             00000c10   00000008  00000008  00000000  RWIX
  PIECTRL               00000ce0   0000001a  0000001a  00000000  RWIX
  PIEVECTTABLE          00000d00   00000200  000001c0  00000040  RWIX
  DMA                   00001000   00000200  000000e0  00000120  RWIX
  CLA1                  00001400   00000080  0000003e  00000042  RWIX
  CLA1_MSGRAMLOW        00001480   00000080  00000002  0000007e  RWIX
  CLA1_MSGRAMHIGH       00001500   00000080  00000002  0000007e  RWIX
  EMIF2_CS2n            00002000   00001000  00000000  00001000  RWIX
  CLB1LOGICCFG          00003000   00000052  0000003e  00000014  RWIX
  CLB1LOGICCTRL         00003100   00000040  00000040  00000000  RWIX
  CLB1DATAEXCH          00003200   00000200  00000108  000000f8  RWIX
  CLB2LOGICCFG          00003400   00000052  0000003e  00000014  RWIX
  CLB2LOGICCTRL         00003500   00000040  00000040  00000000  RWIX
  CLB2DATAEXCH          00003600   00000200  00000108  000000f8  RWIX
  CLB3LOGICCFG          00003800   00000052  0000003e  00000014  RWIX
  CLB3LOGICCTRL         00003900   00000040  00000040  00000000  RWIX
  CLB3DATAEXCH          00003a00   00000200  00000108  000000f8  RWIX
  CLB4LOGICCFG          00003c00   00000052  0000003e  00000014  RWIX
  CLB4LOGICCTRL         00003d00   00000040  00000040  00000000  RWIX
  CLB4DATAEXCH          00003e00   00000200  00000108  000000f8  RWIX
  EPWM1                 00004000   00000100  00000100  00000000  RWIX
  EPWM2                 00004100   00000100  00000100  00000000  RWIX
  EPWM3                 00004200   00000100  00000100  00000000  RWIX
  EPWM4                 00004300   00000100  00000100  00000000  RWIX
  EPWM5                 00004400   00000100  00000100  00000000  RWIX
  EPWM6                 00004500   00000100  00000100  00000000  RWIX
  EPWM7                 00004600   00000100  00000100  00000000  RWIX
  EPWM8                 00004700   00000100  00000100  00000000  RWIX
  EPWM9                 00004800   00000100  00000100  00000000  RWIX
  EPWM10                00004900   00000100  00000100  00000000  RWIX
  EPWM11                00004a00   00000100  00000100  00000000  RWIX
  EPWM12                00004b00   00000100  00000100  00000000  RWIX
  ECAP1                 00005000   00000020  0000001a  00000006  RWIX
  ECAP2                 00005020   00000020  0000001a  00000006  RWIX
  ECAP3                 00005040   00000020  0000001a  00000006  RWIX
  ECAP4                 00005060   00000020  0000001a  00000006  RWIX
  ECAP5                 00005080   00000020  0000001a  00000006  RWIX
  ECAP6                 000050a0   00000020  0000001a  00000006  RWIX
  EQEP1                 00005100   00000022  00000022  00000000  RWIX
  EQEP2                 00005140   00000022  00000022  00000000  RWIX
  EQEP3                 00005180   00000022  00000022  00000000  RWIX
  DACA                  00005c00   00000008  00000007  00000001  RWIX
  DACB                  00005c10   00000008  00000007  00000001  RWIX
  DACC                  00005c20   00000008  00000007  00000001  RWIX
  CMPSS1                00005c80   00000020  0000001b  00000005  RWIX
  CMPSS2                00005ca0   00000020  0000001b  00000005  RWIX
  CMPSS3                00005cc0   00000020  0000001b  00000005  RWIX
  CMPSS4                00005ce0   00000020  0000001b  00000005  RWIX
  CMPSS5                00005d00   00000020  0000001b  00000005  RWIX
  CMPSS6                00005d20   00000020  0000001b  00000005  RWIX
  CMPSS7                00005d40   00000020  0000001b  00000005  RWIX
  CMPSS8                00005d60   00000020  0000001b  00000005  RWIX
  SDFM1                 00005e00   00000080  00000048  00000038  RWIX
  SDFM2                 00005e80   00000080  00000048  00000038  RWIX
  MCBSPA                00006000   00000024  00000024  00000000  RWIX
  MCBSPB                00006040   00000024  00000024  00000000  RWIX
  SPIA                  00006100   00000010  00000010  00000000  RWIX
  SPIB                  00006110   00000010  00000010  00000000  RWIX
  SPIC                  00006120   00000010  00000010  00000000  RWIX
  WD                    00007000   0000002b  0000002b  00000000  RWIX
  NMIINTRUPT            00007060   00000007  00000007  00000000  RWIX
  XINT                  00007070   0000000b  0000000b  00000000  RWIX
  SCIA                  00007200   00000010  00000010  00000000  RWIX
  SCIB                  00007210   00000010  00000010  00000000  RWIX
  SCIC                  00007220   00000010  00000010  00000000  RWIX
  SCID                  00007230   00000010  00000010  00000000  RWIX
  I2CA                  00007300   00000022  00000022  00000000  RWIX
  I2CB                  00007340   00000022  00000022  00000000  RWIX
  ADCA                  00007400   00000080  0000007c  00000004  RWIX
  ADCB                  00007480   00000080  0000007c  00000004  RWIX
  ADCC                  00007500   00000080  0000007c  00000004  RWIX
  ADCD                  00007580   00000080  0000007c  00000004  RWIX
  DMACLASRCSEL          00007980   0000001a  0000001a  00000000  RWIX
  GPIODATA              00007f00   00000030  00000030  00000000  RWIX
  RAMLS2                00009000   00000800  00000110  000006f0  RWIX
  RAMLS3                00009800   00000800  00000000  00000800  RWIX
  RAMGS0                0000c000   00001000  00000000  00001000  RWIX
  RAMGS1                0000d000   00001000  00000000  00001000  RWIX
  RAMGS2                0000e000   00001000  00000000  00001000  RWIX
  RAMGS3                0000f000   00001000  00000000  00001000  RWIX
  RAMGS4                00010000   00001000  00000000  00001000  RWIX
  RAMGS5                00011000   00001000  00000000  00001000  RWIX
  RAMGS6                00012000   00001000  00000000  00001000  RWIX
  RAMGS7                00013000   00001000  00000000  00001000  RWIX
  RAMGS8                00014000   00001000  00000000  00001000  RWIX
  RAMGS9                00015000   00001000  00000000  00001000  RWIX
  RAMGS10               00016000   00001000  00000000  00001000  RWIX
  RAMGS11               00017000   00001000  00000000  00001000  RWIX
  RAMGS12               00018000   00001000  00000000  00001000  RWIX
  RAMGS13               00019000   00001000  00000000  00001000  RWIX
  EMIF1                 00047000   00000070  00000028  00000048  RWIX
  CANA                  00048000   00000200  00000164  0000009c  RWIX
  CANB                  0004a000   00000200  00000164  0000009c  RWIX
  IPC                   00050000   00000024  00000024  00000000  RWIX
  FLASHPUMPSEMAPHORE    00050024   00000002  00000002  00000000  RWIX
  CLKCFG                0005d200   00000032  00000032  00000000  RWIX
  CPUSYS                0005d300   00000082  00000082  00000000  RWIX
  ROMPREFETCH           0005e608   00000002  00000002  00000000  RWIX
  DCSMZ1                0005f000   00000024  00000022  00000002  RWIX
  DCSMZ2                0005f040   00000024  00000022  00000002  RWIX
  DCSMCOMMON            0005f070   00000008  00000006  00000002  RWIX
  MEMCFG                0005f400   00000080  00000076  0000000a  RWIX
  EMIF1CONFIG           0005f480   00000020  0000000a  00000016  RWIX
  ACCESSPROTECTION      0005f4c0   00000040  0000002e  00000012  RWIX
  MEMORYERROR           0005f500   00000040  0000003a  00000006  RWIX
  FLASH0CTRL            0005f800   00000182  00000182  00000000  RWIX
  FLASH0ECC             0005fb00   00000028  00000028  00000000  RWIX
  UID                   000703c0   00000010  00000010  00000000  RWIX
  EMIF1_CS2n            00100000   00200000  00000000  00200000  RWIX
  EMIF1_CS3n            00300000   00080000  00000000  00080000  RWIX
  EMIF1_CS4n            00380000   00060000  00000000  00060000  RWIX
  EMIF1_CS0n            80000000   10000000  00000000  10000000  RWIX
  EMIF2_CS0n            90000000   10000000  00000000  10000000  RWIX
SECTION ALLOCATION MAP
 output                                  attributes/
section   page    origin      length       input sections
CLADataLS0
*          0    00008000    00000180     UNINITIALIZED
                  00008000    00000180     cla_asin_cpu02.obj (CLADataLS0)
codestart
*          0    00080000    00000002
                  00080000    00000002     F2837xD_CodeStartBranch.obj (codestart)
.text      0    00082000    00000bc0
                  00082000    00000585     F2837xD_DefaultISR.obj (.text:retain)
                  00082585    0000024a     F2837xD_SysCtrl.obj (.text)
                  000827cf    000000ed     cla_asin_cpu02.obj (.text)
                  000828bc    000000ad     F2837xD_Ipc.obj (.text)
                  00082969    00000088     rts2800_fpu32.lib : fs_div28.asm.obj (.text)
                  000829f1    0000007c     cla_asin_cpu02.obj (.text:retain)
                  00082a6d    00000056     rts2800_fpu32.lib : boot28.asm.obj (.text)
                  00082ac3    00000029                       : exit.c.obj (.text)
                  00082aec    00000028     F2837xD_PieCtrl.obj (.text)
                  00082b14    00000026     F2837xD_PieVect.obj (.text)
                  00082b3a    00000024     rts2800_fpu32.lib : cpy_tbl.c.obj (.text)
                  00082b5e    0000001d                       : memcpy.c.obj (.text)
                  00082b7b    00000018                       : ll_aox28.asm.obj (.text)
                  00082b93    00000012                       : args_main.c.obj (.text)
                  00082ba5    00000009                       : _lock.c.obj (.text)
                  00082bae    00000008     F2837xD_CodeStartBranch.obj (.text)
                  00082bb6    00000007     rts2800_fpu32.lib : memset.c.obj (.text)
                  00082bbd    00000002                       : pre_init.c.obj (.text)
                  00082bbf    00000001                       : startup.c.obj (.text)
.cinit     0    00082bc0    00000228
                  00082bc0    0000018b     cla_asin_cpu02.obj (.cinit)
                  00082d4b    00000083     cla_asin_cpu02.obj (.cinit:_asin_expected)
                  00082dce    0000000e     rts2800_fpu32.lib : exit.c.obj (.cinit)
                  00082ddc    00000005                       : _lock.c.obj (.cinit:__lock)
                  00082de1    00000005                       : _lock.c.obj (.cinit:__unlock)
                  00082de6    00000002     --HOLE-- [fill = 0]
.TI.ramfunc
*          0    000860c8    00000004     RUN ADDR = 0000b000
                  000860c8    00000004     F2837xD_usDelay.obj (.TI.ramfunc)
.stack     1    00000400    00000100     UNINITIALIZED
                  00000400    00000100     --HOLE--
.pinit     0    00082000    00000000     UNINITIALIZED
.ebss      1    00009000    00000110     UNINITIALIZED
                  00009000    00000080     cla_asin_cpu02.obj (.ebss:_asin_expected)
                  00009080    00000080     cla_asin_cpu02.obj (.ebss:_y)
                  00009100    00000006     cla_asin_cpu02.obj (.ebss)
                  00009106    00000006     rts2800_fpu32.lib : exit.c.obj (.ebss)
                  0000910c    00000002                       : _lock.c.obj (.ebss:__lock)
                  0000910e    00000002                       : _lock.c.obj (.ebss:__unlock)
.econst    0    00082de8    000001c0
                  00082de8    000001c0     F2837xD_PieVect.obj (.econst:_PieVectTableInit)
.reset     0    003fffc0    00000002     DSECT
                  003fffc0    00000002     rts2800_fpu32.lib : boot28.asm.obj (.reset)
.const_cla
*          0    00008800    00000000     UNINITIALIZED
Cla1Prog   0    00086000    000000c8     RUN ADDR = 0000a000
                  00086000    00000090     asin.obj (Cla1Prog:_Cla1Task1)
                  00086090    00000008     asin.obj (Cla1Prog:_Cla1Task2)
                  00086098    00000008     asin.obj (Cla1Prog:_Cla1Task3)
                  000860a0    00000008     asin.obj (Cla1Prog:_Cla1Task4)
                  000860a8    00000008     asin.obj (Cla1Prog:_Cla1Task5)
                  000860b0    00000008     asin.obj (Cla1Prog:_Cla1Task6)
                  000860b8    00000008     asin.obj (Cla1Prog:_Cla1Task7)
                  000860c0    00000008     asin.obj (Cla1Prog:_Cla1Task8)
AdcaResultRegsFile
*          1    00000b00    00000018     UNINITIALIZED
                  00000b00    00000018     F2837xD_GlobalVariableDefs.obj (AdcaResultRegsFile)
AdcbResultRegsFile
*          1    00000b20    00000018     UNINITIALIZED
                  00000b20    00000018     F2837xD_GlobalVariableDefs.obj (AdcbResultRegsFile)
AdccResultRegsFile
*          1    00000b40    00000018     UNINITIALIZED
                  00000b40    00000018     F2837xD_GlobalVariableDefs.obj (AdccResultRegsFile)
AdcdResultRegsFile
*          1    00000b60    00000018     UNINITIALIZED
                  00000b60    00000018     F2837xD_GlobalVariableDefs.obj (AdcdResultRegsFile)
CpuTimer0RegsFile
*          1    00000c00    00000008     UNINITIALIZED
                  00000c00    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
*          1    00000c08    00000008     UNINITIALIZED
                  00000c08    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
*          1    00000c10    00000008     UNINITIALIZED
                  00000c10    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieCtrlRegsFile
*          1    00000ce0    0000001a     UNINITIALIZED
                  00000ce0    0000001a     F2837xD_GlobalVariableDefs.obj (PieCtrlRegsFile)
DmaRegsFile
*          1    00001000    000000e0     UNINITIALIZED
                  00001000    000000e0     F2837xD_GlobalVariableDefs.obj (DmaRegsFile)
Cla1RegsFile
*          1    00001400    0000003e     UNINITIALIZED
                  00001400    0000003e     F2837xD_GlobalVariableDefs.obj (Cla1RegsFile)
Cla1ToCpuMsgRAM
*          1    00001480    00000002     UNINITIALIZED
                  00001480    00000002     cla_asin_cpu02.obj (Cla1ToCpuMsgRAM)
CpuToCla1MsgRAM
*          1    00001500    00000002     UNINITIALIZED
                  00001500    00000002     cla_asin_cpu02.obj (CpuToCla1MsgRAM)
CLAscratch
*          0    00008800    00000100     UNINITIALIZED
                  00008800    00000100     --HOLE--
.scratchpad
*          0    00008900    0000000c     UNINITIALIZED
                  00008900    0000000c     asin.obj (.scratchpad:Cla1Prog:_Cla1Task1)
.bss_cla   0    0000890c    00000002     UNINITIALIZED
                  0000890c    00000002     asin.obj (.bss_cla)
PieVectTableFile
*          1    00000d00    000001c0     UNINITIALIZED
                  00000d00    000001c0     F2837xD_GlobalVariableDefs.obj (PieVectTableFile)
EmuKeyVar
*          1    00000d00    00000000     UNINITIALIZED
EmuBModeVar
EmuBootPinsVar
FlashCallbackVar
FlashScalingVar
Clb1LogicCfgRegsFile
*          1    00003000    0000003e     UNINITIALIZED
                  00003000    0000003e     F2837xD_GlobalVariableDefs.obj (Clb1LogicCfgRegsFile)
Clb1LogicCtrlRegsFile
*          1    00003100    00000040     UNINITIALIZED
                  00003100    00000040     F2837xD_GlobalVariableDefs.obj (Clb1LogicCtrlRegsFile)
Clb1DataExchRegsFile
*          1    00003200    00000108     UNINITIALIZED
                  00003200    00000108     F2837xD_GlobalVariableDefs.obj (Clb1DataExchRegsFile)
Clb2LogicCfgRegsFile
*          1    00003400    0000003e     UNINITIALIZED
                  00003400    0000003e     F2837xD_GlobalVariableDefs.obj (Clb2LogicCfgRegsFile)
Clb2LogicCtrlRegsFile
*          1    00003500    00000040     UNINITIALIZED
                  00003500    00000040     F2837xD_GlobalVariableDefs.obj (Clb2LogicCtrlRegsFile)
Clb2DataExchRegsFile
*          1    00003600    00000108     UNINITIALIZED
                  00003600    00000108     F2837xD_GlobalVariableDefs.obj (Clb2DataExchRegsFile)
Clb3LogicCfgRegsFile
*          1    00003800    0000003e     UNINITIALIZED
                  00003800    0000003e     F2837xD_GlobalVariableDefs.obj (Clb3LogicCfgRegsFile)
Clb3LogicCtrlRegsFile
*          1    00003900    00000040     UNINITIALIZED
                  00003900    00000040     F2837xD_GlobalVariableDefs.obj (Clb3LogicCtrlRegsFile)
Clb3DataExchRegsFile
*          1    00003a00    00000108     UNINITIALIZED
                  00003a00    00000108     F2837xD_GlobalVariableDefs.obj (Clb3DataExchRegsFile)
Clb4LogicCfgRegsFile
*          1    00003c00    0000003e     UNINITIALIZED
                  00003c00    0000003e     F2837xD_GlobalVariableDefs.obj (Clb4LogicCfgRegsFile)
Clb4LogicCtrlRegsFile
*          1    00003d00    00000040     UNINITIALIZED
                  00003d00    00000040     F2837xD_GlobalVariableDefs.obj (Clb4LogicCtrlRegsFile)
Clb4DataExchRegsFile
*          1    00003e00    00000108     UNINITIALIZED
                  00003e00    00000108     F2837xD_GlobalVariableDefs.obj (Clb4DataExchRegsFile)
EPwm1RegsFile
*          1    00004000    00000100     UNINITIALIZED
                  00004000    00000100     F2837xD_GlobalVariableDefs.obj (EPwm1RegsFile)
EPwm2RegsFile
*          1    00004100    00000100     UNINITIALIZED
                  00004100    00000100     F2837xD_GlobalVariableDefs.obj (EPwm2RegsFile)
EPwm3RegsFile
*          1    00004200    00000100     UNINITIALIZED
                  00004200    00000100     F2837xD_GlobalVariableDefs.obj (EPwm3RegsFile)
EPwm4RegsFile
*          1    00004300    00000100     UNINITIALIZED
                  00004300    00000100     F2837xD_GlobalVariableDefs.obj (EPwm4RegsFile)
EPwm5RegsFile
*          1    00004400    00000100     UNINITIALIZED
                  00004400    00000100     F2837xD_GlobalVariableDefs.obj (EPwm5RegsFile)
EPwm6RegsFile
*          1    00004500    00000100     UNINITIALIZED
                  00004500    00000100     F2837xD_GlobalVariableDefs.obj (EPwm6RegsFile)
EPwm7RegsFile
*          1    00004600    00000100     UNINITIALIZED
                  00004600    00000100     F2837xD_GlobalVariableDefs.obj (EPwm7RegsFile)
EPwm8RegsFile
*          1    00004700    00000100     UNINITIALIZED
                  00004700    00000100     F2837xD_GlobalVariableDefs.obj (EPwm8RegsFile)
EPwm9RegsFile
*          1    00004800    00000100     UNINITIALIZED
                  00004800    00000100     F2837xD_GlobalVariableDefs.obj (EPwm9RegsFile)
EPwm10RegsFile
*          1    00004900    00000100     UNINITIALIZED
                  00004900    00000100     F2837xD_GlobalVariableDefs.obj (EPwm10RegsFile)
EPwm11RegsFile
*          1    00004a00    00000100     UNINITIALIZED
                  00004a00    00000100     F2837xD_GlobalVariableDefs.obj (EPwm11RegsFile)
EPwm12RegsFile
*          1    00004b00    00000100     UNINITIALIZED
                  00004b00    00000100     F2837xD_GlobalVariableDefs.obj (EPwm12RegsFile)
ECap1RegsFile
*          1    00005000    0000001a     UNINITIALIZED
                  00005000    0000001a     F2837xD_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
*          1    00005020    0000001a     UNINITIALIZED
                  00005020    0000001a     F2837xD_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
*          1    00005040    0000001a     UNINITIALIZED
                  00005040    0000001a     F2837xD_GlobalVariableDefs.obj (ECap3RegsFile)
ECap4RegsFile
*          1    00005060    0000001a     UNINITIALIZED
                  00005060    0000001a     F2837xD_GlobalVariableDefs.obj (ECap4RegsFile)
ECap5RegsFile
*          1    00005080    0000001a     UNINITIALIZED
                  00005080    0000001a     F2837xD_GlobalVariableDefs.obj (ECap5RegsFile)
ECap6RegsFile
*          1    000050a0    0000001a     UNINITIALIZED
                  000050a0    0000001a     F2837xD_GlobalVariableDefs.obj (ECap6RegsFile)
EQep1RegsFile
*          1    00005100    00000022     UNINITIALIZED
                  00005100    00000022     F2837xD_GlobalVariableDefs.obj (EQep1RegsFile)
EQep2RegsFile
*          1    00005140    00000022     UNINITIALIZED
                  00005140    00000022     F2837xD_GlobalVariableDefs.obj (EQep2RegsFile)
EQep3RegsFile
*          1    00005180    00000022     UNINITIALIZED
                  00005180    00000022     F2837xD_GlobalVariableDefs.obj (EQep3RegsFile)
DacaRegsFile
*          1    00005c00    00000007     UNINITIALIZED
                  00005c00    00000007     F2837xD_GlobalVariableDefs.obj (DacaRegsFile)
DacbRegsFile
*          1    00005c10    00000007     UNINITIALIZED
                  00005c10    00000007     F2837xD_GlobalVariableDefs.obj (DacbRegsFile)
DaccRegsFile
*          1    00005c20    00000007     UNINITIALIZED
                  00005c20    00000007     F2837xD_GlobalVariableDefs.obj (DaccRegsFile)
Cmpss1RegsFile
*          1    00005c80    0000001b     UNINITIALIZED
                  00005c80    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss1RegsFile)
Cmpss2RegsFile
*          1    00005ca0    0000001b     UNINITIALIZED
                  00005ca0    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss2RegsFile)
Cmpss3RegsFile
*          1    00005cc0    0000001b     UNINITIALIZED
                  00005cc0    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss3RegsFile)
Cmpss4RegsFile
*          1    00005ce0    0000001b     UNINITIALIZED
                  00005ce0    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss4RegsFile)
Cmpss5RegsFile
*          1    00005d00    0000001b     UNINITIALIZED
                  00005d00    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss5RegsFile)
Cmpss6RegsFile
*          1    00005d20    0000001b     UNINITIALIZED
                  00005d20    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss6RegsFile)
Cmpss7RegsFile
*          1    00005d40    0000001b     UNINITIALIZED
                  00005d40    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss7RegsFile)
Cmpss8RegsFile
*          1    00005d60    0000001b     UNINITIALIZED
                  00005d60    0000001b     F2837xD_GlobalVariableDefs.obj (Cmpss8RegsFile)
Sdfm1RegsFile
*          1    00005e00    00000048     UNINITIALIZED
                  00005e00    00000048     F2837xD_GlobalVariableDefs.obj (Sdfm1RegsFile)
Sdfm2RegsFile
*          1    00005e80    00000048     UNINITIALIZED
                  00005e80    00000048     F2837xD_GlobalVariableDefs.obj (Sdfm2RegsFile)
McbspaRegsFile
*          1    00006000    00000024     UNINITIALIZED
                  00006000    00000024     F2837xD_GlobalVariableDefs.obj (McbspaRegsFile)
McbspbRegsFile
*          1    00006040    00000024     UNINITIALIZED
                  00006040    00000024     F2837xD_GlobalVariableDefs.obj (McbspbRegsFile)
SpiaRegsFile
*          1    00006100    00000010     UNINITIALIZED
                  00006100    00000010     F2837xD_GlobalVariableDefs.obj (SpiaRegsFile)
SpibRegsFile
*          1    00006110    00000010     UNINITIALIZED
                  00006110    00000010     F2837xD_GlobalVariableDefs.obj (SpibRegsFile)
SpicRegsFile
*          1    00006120    00000010     UNINITIALIZED
                  00006120    00000010     F2837xD_GlobalVariableDefs.obj (SpicRegsFile)
WdRegsFile
*          1    00007000    0000002b     UNINITIALIZED
                  00007000    0000002b     F2837xD_GlobalVariableDefs.obj (WdRegsFile)
NmiIntruptRegsFile
*          1    00007060    00000007     UNINITIALIZED
                  00007060    00000007     F2837xD_GlobalVariableDefs.obj (NmiIntruptRegsFile)
XintRegsFile
*          1    00007070    0000000b     UNINITIALIZED
                  00007070    0000000b     F2837xD_GlobalVariableDefs.obj (XintRegsFile)
SciaRegsFile
*          1    00007200    00000010     UNINITIALIZED
                  00007200    00000010     F2837xD_GlobalVariableDefs.obj (SciaRegsFile)
ScibRegsFile
*          1    00007210    00000010     UNINITIALIZED
                  00007210    00000010     F2837xD_GlobalVariableDefs.obj (ScibRegsFile)
ScicRegsFile
*          1    00007220    00000010     UNINITIALIZED
                  00007220    00000010     F2837xD_GlobalVariableDefs.obj (ScicRegsFile)
ScidRegsFile
*          1    00007230    00000010     UNINITIALIZED
                  00007230    00000010     F2837xD_GlobalVariableDefs.obj (ScidRegsFile)
I2caRegsFile
*          1    00007300    00000022     UNINITIALIZED
                  00007300    00000022     F2837xD_GlobalVariableDefs.obj (I2caRegsFile)
I2cbRegsFile
*          1    00007340    00000022     UNINITIALIZED
                  00007340    00000022     F2837xD_GlobalVariableDefs.obj (I2cbRegsFile)
AdcaRegsFile
*          1    00007400    0000007c     UNINITIALIZED
                  00007400    0000007c     F2837xD_GlobalVariableDefs.obj (AdcaRegsFile)
AdcbRegsFile
*          1    00007480    0000007c     UNINITIALIZED
                  00007480    0000007c     F2837xD_GlobalVariableDefs.obj (AdcbRegsFile)
AdccRegsFile
*          1    00007500    0000007c     UNINITIALIZED
                  00007500    0000007c     F2837xD_GlobalVariableDefs.obj (AdccRegsFile)
AdcdRegsFile
*          1    00007580    0000007c     UNINITIALIZED
                  00007580    0000007c     F2837xD_GlobalVariableDefs.obj (AdcdRegsFile)
DmaClaSrcSelRegsFile
*          1    00007980    0000001a     UNINITIALIZED
                  00007980    0000001a     F2837xD_GlobalVariableDefs.obj (DmaClaSrcSelRegsFile)
GpioDataRegsFile
*          1    00007f00    00000030     UNINITIALIZED
                  00007f00    00000030     F2837xD_GlobalVariableDefs.obj (GpioDataRegsFile)
Emif1RegsFile
*          1    00047000    00000028     UNINITIALIZED
                  00047000    00000028     F2837xD_GlobalVariableDefs.obj (Emif1RegsFile)
CanaRegsFile
*          1    00048000    00000164     UNINITIALIZED
                  00048000    00000164     F2837xD_GlobalVariableDefs.obj (CanaRegsFile)
CanbRegsFile
*          1    0004a000    00000164     UNINITIALIZED
                  0004a000    00000164     F2837xD_GlobalVariableDefs.obj (CanbRegsFile)
IpcRegsFile
*          1    00050000    00000024     UNINITIALIZED
                  00050000    00000024     F2837xD_GlobalVariableDefs.obj (IpcRegsFile)
FlashPumpSemaphoreRegsFile
*          1    00050024    00000002     UNINITIALIZED
                  00050024    00000002     F2837xD_GlobalVariableDefs.obj (FlashPumpSemaphoreRegsFile)
ClkCfgRegsFile
*          1    0005d200    00000032     UNINITIALIZED
                  0005d200    00000032     F2837xD_GlobalVariableDefs.obj (ClkCfgRegsFile)
CpuSysRegsFile
*          1    0005d300    00000082     UNINITIALIZED
                  0005d300    00000082     F2837xD_GlobalVariableDefs.obj (CpuSysRegsFile)
DcsmZ1RegsFile
*          1    0005f000    00000022     UNINITIALIZED
                  0005f000    00000022     F2837xD_GlobalVariableDefs.obj (DcsmZ1RegsFile)
DcsmZ2RegsFile
*          1    0005f040    00000022     UNINITIALIZED
                  0005f040    00000022     F2837xD_GlobalVariableDefs.obj (DcsmZ2RegsFile)
DcsmCommonRegsFile
*          1    0005f070    00000006     UNINITIALIZED
                  0005f070    00000006     F2837xD_GlobalVariableDefs.obj (DcsmCommonRegsFile)
MemCfgRegsFile
*          1    0005f400    00000076     UNINITIALIZED
                  0005f400    00000076     F2837xD_GlobalVariableDefs.obj (MemCfgRegsFile)
Emif1ConfigRegsFile
*          1    0005f480    0000000a     UNINITIALIZED
                  0005f480    0000000a     F2837xD_GlobalVariableDefs.obj (Emif1ConfigRegsFile)
AccessProtectionRegsFile
*          1    0005f4c0    0000002e     UNINITIALIZED
                  0005f4c0    0000002e     F2837xD_GlobalVariableDefs.obj (AccessProtectionRegsFile)
MemoryErrorRegsFile
*          1    0005f500    0000003a     UNINITIALIZED
                  0005f500    0000003a     F2837xD_GlobalVariableDefs.obj (MemoryErrorRegsFile)
Flash0CtrlRegsFile
*          1    0005f800    00000182     UNINITIALIZED
                  0005f800    00000182     F2837xD_GlobalVariableDefs.obj (Flash0CtrlRegsFile)
Flash0EccRegsFile
*          1    0005fb00    00000028     UNINITIALIZED
                  0005fb00    00000028     F2837xD_GlobalVariableDefs.obj (Flash0EccRegsFile)
RomPrefetchRegsFile
*          1    0005e608    00000002     UNINITIALIZED
                  0005e608    00000002     F2837xD_GlobalVariableDefs.obj (RomPrefetchRegsFile)
UidRegsFile
*          1    000703c0    00000010     UNINITIALIZED
                  000703c0    00000010     F2837xD_GlobalVariableDefs.obj (UidRegsFile)
MODULE SUMMARY
       Module                           code   initialized data   uninitialized data
       F2837xD_GlobalVariableDefs.obj   0      0                  8754
       cla_asin_cpu02.obj               361    526                650
       F2837xD_DefaultISR.obj           1413   0                  0
       F2837xD_SysCtrl.obj              586    0                  0
       F2837xD_PieVect.obj              38     448                0
       asin.obj                         400    0                  14
       F2837xD_Ipc.obj                  173    0                  0
       F2837xD_PieCtrl.obj              40     0                  0
       F2837xD_CodeStartBranch.obj      10     0                  0
       F2837xD_usDelay.obj              8      0                  0
       Total:                           3029   974                9418
    C:/ti/ccs1020/ccs/tools/compiler/ti-cgt-c2000_20.2.2.LTS/lib/rts2800_fpu32.lib
       fs_div28.asm.obj                 136    0                  0
       boot28.asm.obj                   86     0                  0
       exit.c.obj                       41     14                 6
       cpy_tbl.c.obj                    36     0                  0
       memcpy.c.obj                     29     0                  0
       ll_aox28.asm.obj                 24     0                  0
       _lock.c.obj                      9      10                 4
       args_main.c.obj                  18     0                  0
       memset.c.obj                     7      0                  0
       pre_init.c.obj                   2      0                  0
       startup.c.obj                    1      0                  0
       Total:                           389    24                 10
       Stack:                           0      0                  256
       Grand Total:                     3418   998                9684
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address     data page           name
00000400      10 (00000400)     __stack
00000b00      2c (00000b00)     _AdcaResultRegs
00000b20      2c (00000b00)     _AdcbResultRegs
00000b40      2d (00000b40)     _AdccResultRegs
00000b60      2d (00000b40)     _AdcdResultRegs
00000c00      30 (00000c00)     _CpuTimer0Regs
00000c08      30 (00000c00)     _CpuTimer1Regs
00000c10      30 (00000c00)     _CpuTimer2Regs
00000ce0      33 (00000cc0)     _PieCtrlRegs
00000d00      34 (00000d00)     _PieVectTable
00001000      40 (00001000)     _DmaRegs
00001400      50 (00001400)     _Cla1Regs
00001480      52 (00001480)     _fResult
00001500      54 (00001500)     _fVal
00003000      c0 (00003000)     _Clb1LogicCfgRegs
00003100      c4 (00003100)     _Clb1LogicCtrlRegs
00003200      c8 (00003200)     _Clb1DataExchRegs
00003400      d0 (00003400)     _Clb2LogicCfgRegs
00003500      d4 (00003500)     _Clb2LogicCtrlRegs
00003600      d8 (00003600)     _Clb2DataExchRegs
00003800      e0 (00003800)     _Clb3LogicCfgRegs
00003900      e4 (00003900)     _Clb3LogicCtrlRegs
00003a00      e8 (00003a00)     _Clb3DataExchRegs
00003c00      f0 (00003c00)     _Clb4LogicCfgRegs
00003d00      f4 (00003d00)     _Clb4LogicCtrlRegs
00003e00      f8 (00003e00)     _Clb4DataExchRegs
00004000     100 (00004000)     _EPwm1Regs
00004100     104 (00004100)     _EPwm2Regs
00004200     108 (00004200)     _EPwm3Regs
00004300     10c (00004300)     _EPwm4Regs
00004400     110 (00004400)     _EPwm5Regs
00004500     114 (00004500)     _EPwm6Regs
00004600     118 (00004600)     _EPwm7Regs
00004700     11c (00004700)     _EPwm8Regs
00004800     120 (00004800)     _EPwm9Regs
00004900     124 (00004900)     _EPwm10Regs
00004a00     128 (00004a00)     _EPwm11Regs
00004b00     12c (00004b00)     _EPwm12Regs
00005000     140 (00005000)     _ECap1Regs
00005020     140 (00005000)     _ECap2Regs
00005040     141 (00005040)     _ECap3Regs
00005060     141 (00005040)     _ECap4Regs
00005080     142 (00005080)     _ECap5Regs
000050a0     142 (00005080)     _ECap6Regs
00005100     144 (00005100)     _EQep1Regs
00005140     145 (00005140)     _EQep2Regs
00005180     146 (00005180)     _EQep3Regs
00005c00     170 (00005c00)     _DacaRegs
00005c10     170 (00005c00)     _DacbRegs
00005c20     170 (00005c00)     _DaccRegs
00005c80     172 (00005c80)     _Cmpss1Regs
00005ca0     172 (00005c80)     _Cmpss2Regs
00005cc0     173 (00005cc0)     _Cmpss3Regs
00005ce0     173 (00005cc0)     _Cmpss4Regs
00005d00     174 (00005d00)     _Cmpss5Regs
00005d20     174 (00005d00)     _Cmpss6Regs
00005d40     175 (00005d40)     _Cmpss7Regs
00005d60     175 (00005d40)     _Cmpss8Regs
00005e00     178 (00005e00)     _Sdfm1Regs
00005e80     17a (00005e80)     _Sdfm2Regs
00006000     180 (00006000)     _McbspaRegs
00006040     181 (00006040)     _McbspbRegs
00006100     184 (00006100)     _SpiaRegs
00006110     184 (00006100)     _SpibRegs
00006120     184 (00006100)     _SpicRegs
00007000     1c0 (00007000)     _WdRegs
00007060     1c1 (00007040)     _NmiIntruptRegs
00007070     1c1 (00007040)     _XintRegs
00007200     1c8 (00007200)     _SciaRegs
00007210     1c8 (00007200)     _ScibRegs
00007220     1c8 (00007200)     _ScicRegs
00007230     1c8 (00007200)     _ScidRegs
00007300     1cc (00007300)     _I2caRegs
00007340     1cd (00007340)     _I2cbRegs
00007400     1d0 (00007400)     _AdcaRegs
00007480     1d2 (00007480)     _AdcbRegs
00007500     1d4 (00007500)     _AdccRegs
00007580     1d6 (00007580)     _AdcdRegs
00007980     1e6 (00007980)     _DmaClaSrcSelRegs
00007f00     1fc (00007f00)     _GpioDataRegs
00008000     200 (00008000)     _CLAasinTable
0000890c     224 (00008900)     _fDebug
00009000     240 (00009000)     _asin_expected
00009080     242 (00009080)     _y
00009100     244 (00009100)     _pass
00009101     244 (00009100)     _fail
00009102     244 (00009100)     _fVal23
00009104     244 (00009100)     _fVal22
00009106     244 (00009100)     ___TI_enable_exit_profile_output
00009108     244 (00009100)     ___TI_cleanup_ptr
0000910a     244 (00009100)     ___TI_dtors_ptr
0000910c     244 (00009100)     __lock
0000910e     244 (00009100)     __unlock
00047000    11c0 (00047000)     _Emif1Regs
00048000    1200 (00048000)     _CanaRegs
0004a000    1280 (0004a000)     _CanbRegs
00050000    1400 (00050000)     _IpcRegs
00050024    1400 (00050000)     _FlashPumpSemaphoreRegs
0005d200    1748 (0005d200)     _ClkCfgRegs
0005d300    174c (0005d300)     _CpuSysRegs
0005e608    1798 (0005e600)     _RomPrefetchRegs
0005f000    17c0 (0005f000)     _DcsmZ1Regs
0005f040    17c1 (0005f040)     _DcsmZ2Regs
0005f070    17c1 (0005f040)     _DcsmCommonRegs
0005f400    17d0 (0005f400)     _MemCfgRegs
0005f480    17d2 (0005f480)     _Emif1ConfigRegs
0005f4c0    17d3 (0005f4c0)     _AccessProtectionRegs
0005f500    17d4 (0005f500)     _MemoryErrorRegs
0005f800    17e0 (0005f800)     _Flash0CtrlRegs
0005fb00    17ec (0005fb00)     _Flash0EccRegs
000703c0    1c0f (000703c0)     _UidRegs
00082de8    20b7 (00082dc0)     _PieVectTableInit
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page  address   name
0     00082000  .text
0     00082ac3  C$$EXIT
abs   00000100  CLA_SCRATCHPAD_SIZE
0     00082969  FS$$DIV
0     00082b7b  LL$$AND
0     00082b83  LL$$OR
0     00082b8b  LL$$XOR
0     000820be  _ADCA1_ISR
0     0008233e  _ADCA2_ISR
0     00082348  _ADCA3_ISR
0     00082352  _ADCA4_ISR
0     00082334  _ADCA_EVT_ISR
0     000820c8  _ADCB1_ISR
0     00082366  _ADCB2_ISR
0     00082370  _ADCB3_ISR
0     0008237a  _ADCB4_ISR
0     0008235c  _ADCB_EVT_ISR
0     000820d2  _ADCC1_ISR
0     000824ce  _ADCC2_ISR
0     000824d8  _ADCC3_ISR
0     000824e2  _ADCC4_ISR
0     000824c4  _ADCC_EVT_ISR
0     000820f0  _ADCD1_ISR
0     000824f6  _ADCD2_ISR
0     00082500  _ADCD3_ISR
0     0008250a  _ADCD4_ISR
0     000824ec  _ADCD_EVT_ISR
0     00082546  _AUX_PLL_SLIP_ISR
1     0005f4c0  _AccessProtectionRegs
0     0008292c  _AckIpcFlag
1     00007400  _AdcaRegs
1     00000b00  _AdcaResultRegs
1     00007480  _AdcbRegs
1     00000b20  _AdcbResultRegs
1     00007500  _AdccRegs
1     00000b40  _AdccResultRegs
1     00007580  _AdcdRegs
1     00000b60  _AdcdResultRegs
0     000827ab  _AuxAuxClkSel
0     00082795  _AuxIntOsc2Sel
0     0008279f  _AuxXtalOscSel
0     0008230c  _CANA0_ISR
0     00082316  _CANA1_ISR
0     00082320  _CANB0_ISR
0     0008232a  _CANB1_ISR
0     00082384  _CLA1_1_ISR
0     0008238e  _CLA1_2_ISR
0     00082398  _CLA1_3_ISR
0     000823a2  _CLA1_4_ISR
0     000823ac  _CLA1_5_ISR
0     000823b6  _CLA1_6_ISR
0     000823c0  _CLA1_7_ISR
0     000823ca  _CLA1_8_ISR
0     00082550  _CLA_OVERFLOW_ISR
0     0008255a  _CLA_UNDERFLOW_ISR
0     00082844  _CLA_configClaMemory
0     0008287b  _CLA_initCpu2Cla1
0     000827e5  _CLA_runTest
0     00008000  _CLAasinTable
1     00048000  _CanaRegs
1     0004a000  _CanbRegs
0     00082936  _CancelIpcFlag
abs   00000000  _Cla1ConstLoadSize
0     00008800  _Cla1ConstLoadStart
0     00008800  _Cla1ConstRunStart
1     00001400  _Cla1Regs
0     0000a000  _Cla1Task1
0     0000a090  _Cla1Task2
0     0000a098  _Cla1Task3
0     0000a0a0  _Cla1Task4
0     0000a0a8  _Cla1Task5
0     0000a0b0  _Cla1Task6
0     0000a0b8  _Cla1Task7
0     0000a0c0  _Cla1Task8
0     000860c8  _Cla1funcsLoadEnd
abs   000000c8  _Cla1funcsLoadSize
0     00086000  _Cla1funcsLoadStart
0     0000a000  _Cla1funcsRunStart
1     00003200  _Clb1DataExchRegs
1     00003000  _Clb1LogicCfgRegs
1     00003100  _Clb1LogicCtrlRegs
1     00003600  _Clb2DataExchRegs
1     00003400  _Clb2LogicCfgRegs
1     00003500  _Clb2LogicCtrlRegs
1     00003a00  _Clb3DataExchRegs
1     00003800  _Clb3LogicCfgRegs
1     00003900  _Clb3LogicCtrlRegs
1     00003e00  _Clb4DataExchRegs
1     00003c00  _Clb4LogicCfgRegs
1     00003d00  _Clb4LogicCtrlRegs
1     0005d200  _ClkCfgRegs
1     00005c80  _Cmpss1Regs
1     00005ca0  _Cmpss2Regs
1     00005cc0  _Cmpss3Regs
1     00005ce0  _Cmpss4Regs
1     00005d00  _Cmpss5Regs
1     00005d20  _Cmpss6Regs
1     00005d40  _Cmpss7Regs
1     00005d60  _Cmpss8Regs
1     0005d300  _CpuSysRegs
1     00000c00  _CpuTimer0Regs
1     00000c08  _CpuTimer1Regs
1     00000c10  _CpuTimer2Regs
0     00082740  _CsmUnlock
0     00082014  _DATALOG_ISR
0     00082258  _DMA_CH1_ISR
0     00082262  _DMA_CH2_ISR
0     0008226c  _DMA_CH3_ISR
0     00082276  _DMA_CH4_ISR
0     00082280  _DMA_CH5_ISR
0     0008228a  _DMA_CH6_ISR
1     00005c00  _DacaRegs
1     00005c10  _DacbRegs
1     00005c20  _DaccRegs
1     0005f070  _DcsmCommonRegs
1     0005f000  _DcsmZ1Regs
1     0005f040  _DcsmZ2Regs
0     00082643  _DisableDog
0     00082604  _DisablePeripheralClocks
1     00007980  _DmaClaSrcSelRegs
1     00001000  _DmaRegs
0     000821ae  _ECAP1_ISR
0     000821b8  _ECAP2_ISR
0     000821c2  _ECAP3_ISR
0     000821cc  _ECAP4_ISR
0     000821d6  _ECAP5_ISR
0     000821e0  _ECAP6_ISR
1     00005000  _ECap1Regs
1     00005020  _ECap2Regs
1     00005040  _ECap3Regs
1     00005060  _ECap4Regs
1     00005080  _ECap5Regs
1     000050a0  _ECap6Regs
0     00082514  _EMIF_ERROR_ISR
0     0008256e  _EMPTY_ISR
0     00082028  _EMU_ISR
0     0008246a  _EPWM10_ISR
0     00082442  _EPWM10_TZ_ISR
0     00082474  _EPWM11_ISR
0     0008244c  _EPWM11_TZ_ISR
0     0008247e  _EPWM12_ISR
0     00082456  _EPWM12_TZ_ISR
0     0008215e  _EPWM1_ISR
0     0008210e  _EPWM1_TZ_ISR
0     00082168  _EPWM2_ISR
0     00082118  _EPWM2_TZ_ISR
0     00082172  _EPWM3_ISR
0     00082122  _EPWM3_TZ_ISR
0     0008217c  _EPWM4_ISR
0     0008212c  _EPWM4_TZ_ISR
0     00082186  _EPWM5_ISR
0     00082136  _EPWM5_TZ_ISR
0     00082190  _EPWM6_ISR
0     00082140  _EPWM6_TZ_ISR
0     0008219a  _EPWM7_ISR
0     0008214a  _EPWM7_TZ_ISR
0     000821a4  _EPWM8_ISR
0     00082154  _EPWM8_TZ_ISR
0     00082460  _EPWM9_ISR
0     00082438  _EPWM9_TZ_ISR
1     00004900  _EPwm10Regs
1     00004a00  _EPwm11Regs
1     00004b00  _EPwm12Regs
1     00004000  _EPwm1Regs
1     00004100  _EPwm2Regs
1     00004200  _EPwm3Regs
1     00004300  _EPwm4Regs
1     00004400  _EPwm5Regs
1     00004500  _EPwm6Regs
1     00004600  _EPwm7Regs
1     00004700  _EPwm8Regs
1     00004800  _EPwm9Regs
0     000821ea  _EQEP1_ISR
0     000821f4  _EQEP2_ISR
0     000821fe  _EQEP3_ISR
1     00005100  _EQep1Regs
1     00005140  _EQep2Regs
1     00005180  _EQep3Regs
1     0005f480  _Emif1ConfigRegs
1     00047000  _Emif1Regs
0     00082b0b  _EnableInterrupts
0     0000b000  _F28x_usDelay
0     00082528  _FLASH_CORRECTABLE_ERROR_ISR
0     000823fc  _FPU_OVERFLOW_ISR
0     00082406  _FPU_UNDERFLOW_ISR
0     00082905  _FillIpcSendData
1     0005f800  _Flash0CtrlRegs
1     0005fb00  _Flash0EccRegs
1     00050024  _FlashPumpSemaphoreRegs
1     00007f00  _GpioDataRegs
0     000827c9  _HALT
0     000827cc  _HIB
0     0008229e  _I2CA_FIFO_ISR
0     00082294  _I2CA_ISR
0     000822b2  _I2CB_FIFO_ISR
0     000822a8  _I2CB_ISR
1     00007300  _I2caRegs
1     00007340  _I2cbRegs
0     000827b5  _IDLE
0     0008203c  _ILLEGAL_ISR
0     00082410  _IPC0_ISR
0     0008241a  _IPC1_ISR
0     00082424  _IPC2_ISR
0     0008242e  _IPC3_ISR
0     00082651  _InitAuxPll
0     000828bc  _InitIpc
0     0008258a  _InitPeripheralClocks
0     00082aec  _InitPieCtrl
0     00082b14  _InitPieVectTable
0     00082585  _InitSysCtrl
1     00050000  _IpcRegs
0     0008295a  _IpcSync
0     00082230  _MCBSPA_RX_ISR
0     0008223a  _MCBSPA_TX_ISR
0     00082244  _MCBSPB_RX_ISR
0     0008224e  _MCBSPB_TX_ISR
1     00006000  _McbspaRegs
1     00006040  _McbspbRegs
1     0005f400  _MemCfgRegs
1     0005f500  _MemoryErrorRegs
0     00082032  _NMI_ISR
0     0008257b  _NOTUSED_ISR
1     00007060  _NmiIntruptRegs
0     00082564  _PIE_RESERVED_ISR
1     00000ce0  _PieCtrlRegs
1     00000d00  _PieVectTable
0     00082de8  _PieVectTableInit
0     00082532  _RAM_ACCESS_VIOLATION_ISR
0     0008251e  _RAM_CORRECTABLE_ERROR_ISR
0     0008201e  _RTOS_ISR
0     000860cc  _RamfuncsLoadEnd
abs   00000004  _RamfuncsLoadSize
0     000860c8  _RamfuncsLoadStart
0     0000b004  _RamfuncsRunEnd
abs   00000004  _RamfuncsRunSize
0     0000b000  _RamfuncsRunStart
0     000828ca  _ReadIpcTimer
0     000828f5  _RecvIpcData
0     0008262b  _ReleaseFlashPump
1     0005e608  _RomPrefetchRegs
0     000822e4  _SCIA_RX_ISR
0     000822ee  _SCIA_TX_ISR
0     000822f8  _SCIB_RX_ISR
0     00082302  _SCIB_TX_ISR
0     000822bc  _SCIC_RX_ISR
0     000822c6  _SCIC_TX_ISR
0     000822d0  _SCID_RX_ISR
0     000822da  _SCID_TX_ISR
0     00082488  _SD1_ISR
0     00082492  _SD2_ISR
0     00082208  _SPIA_RX_ISR
0     00082212  _SPIA_TX_ISR
0     0008221c  _SPIB_RX_ISR
0     00082226  _SPIB_TX_ISR
0     0008249c  _SPIC_RX_ISR
0     000824a6  _SPIC_TX_ISR
0     000827be  _STANDBY
0     0008253c  _SYS_PLL_SLIP_ISR
1     00007200  _SciaRegs
1     00007210  _ScibRegs
1     00007220  _ScicRegs
1     00007230  _ScidRegs
1     00005e00  _Sdfm1Regs
1     00005e80  _Sdfm2Regs
0     0008261c  _SeizeFlashPump
0     00082911  _SendIpcCommand
0     000828de  _SendIpcData
0     00082922  _SendIpcFlag
0     00082635  _ServiceDog
1     00006100  _SpiaRegs
1     00006110  _SpibRegs
1     00006120  _SpicRegs
0     00082761  _SysIntOsc1Sel
0     00082771  _SysIntOsc2Sel
0     00082785  _SysXtalOscSel
0     000820fa  _TIMER0_ISR
0     00082000  _TIMER1_ISR
0     0008200a  _TIMER2_ISR
0     000824b0  _UPPA_ISR
0     000824ba  _USBA_ISR
0     000820a0  _USER10_ISR
0     000820aa  _USER11_ISR
0     000820b4  _USER12_ISR
0     00082046  _USER1_ISR
0     00082050  _USER2_ISR
0     0008205a  _USER3_ISR
0     00082064  _USER4_ISR
0     0008206e  _USER5_ISR
0     00082078  _USER6_ISR
0     00082082  _USER7_ISR
0     0008208c  _USER8_ISR
0     00082096  _USER9_ISR
1     000703c0  _UidRegs
0     000823f2  _VCU_ISR
0     00082104  _WAKE_ISR
0     0008294d  _WaitForIpcAck
0     00082940  _WaitForIpcFlag
1     00007000  _WdRegs
0     000820dc  _XINT1_ISR
0     000820e6  _XINT2_ISR
0     000823d4  _XINT3_ISR
0     000823de  _XINT4_ISR
0     000823e8  _XINT5_ISR
1     00007070  _XintRegs
1     00000500  __STACK_END
abs   00000100  __STACK_SIZE
1     00009108  ___TI_cleanup_ptr
1     0000910a  ___TI_dtors_ptr
1     00009106  ___TI_enable_exit_profile_output
abs   ffffffff  ___TI_pprof_out_hndl
abs   ffffffff  ___TI_prof_data_size
abs   ffffffff  ___TI_prof_data_start
abs   ffffffff  ___binit__
abs   ffffffff  ___c_args__
0     00082bc0  ___cinit__
0     00082bc0  ___etext__
abs   ffffffff  ___pinit__
0     00082000  ___text__
0     00082b93  __args_main
1     0000910c  __lock
0     00082bad  __nop
0     00082ba9  __register_lock
0     00082ba5  __register_unlock
1     00000400  __stack
0     00082bbf  __system_post_cinit
0     00082bbd  __system_pre_init
1     0000910e  __unlock
0     00082ac3  _abort
1     00009000  _asin_expected
0     00082a6d  _c_int00
0     000829f1  _cla1Isr1
0     00082a02  _cla1Isr2
0     00082a11  _cla1Isr3
0     00082a20  _cla1Isr4
0     00082a2f  _cla1Isr5
0     00082a3e  _cla1Isr6
0     00082a4d  _cla1Isr7
0     00082a5c  _cla1Isr8
0     00082b3a  _copy_in
0     00082ac5  _exit
0     0000890c  _fDebug
1     00001480  _fResult
1     00001500  _fVal
1     00009104  _fVal22
1     00009102  _fVal23
1     00009101  _fail
0     000827cf  _main
0     00082b5e  _memcpy
0     00082bb6  _memset
1     00009100  _pass
1     00009080  _y
abs   ffffffff  binit
0     00082bc0  cinit
0     00080000  code_start
0     00082bc0  etext
abs   ffffffff  pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
page  address   name
0     0000890c  _fDebug
0     00082000  .text
0     00082028  _EMU_ISR
0     00082032  _NMI_ISR
0     000823f2  _VCU_ISR
0     00082488  _SD1_ISR
0     00082492  _SD2_ISR
0     000827b5  _IDLE
0     000827be  _STANDBY
0     000827c9  _HALT
0     000827cc  _HIB
0     000827cf  _main
0     000828bc  _InitIpc
0     0008295a  _IpcSync
0     00082969  FS$$DIV
0     00082a6d  _c_int00
0     00082ac3  C$$EXIT
0     00082ac3  _abort
0     00082ac5  _exit
0     00082b3a  _copy_in
0     00082b5e  _memcpy
0     00082b7b  LL$$AND
0     00082b83  LL$$OR
0     00082b8b  LL$$XOR
0     00082bad  __nop
0     00082bb6  _memset
0     00082bc0  cinit
0     00082bc0  etext
1     00000400  __stack
1     00001000  _DmaRegs
1     00001480  _fResult
1     00001500  _fVal
1     00007000  _WdRegs
1     00009080  _y
1     00009100  _pass
1     00009101  _fail
1     00009102  _fVal23
1     00009104  _fVal22
1     0000910c  __lock
1     0000910e  __unlock
1     00050000  _IpcRegs
1     000703c0  _UidRegs
abs   ffffffff  binit
abs   ffffffff  pinit
[356 symbols]
looking forward to your reply. Thanks.
