Part Number: TMS320F280039
Please expect a delay in response as the expert is currently out of office.
Aishwarya
Please have a look at the non syscfg based Flash Boot example present in a different device in the location - C2000ware-release\driverlib\f28p65x\examples\c28x\boot.
We have added the detailed steps to run the example, please try out similar steps from your side for the f28003x device.
Aswin
Thanks for your reply.
But the Flash Boot example not include the configuration of DCSM, I want to know how to simplify the steps of flash.
Because the address of Z1 OTP is start from 0x78000, so the Hex file which content the CMAC tag not include the DCSM configuration. Only the .out file include the Z1 OTP configuration.I need flash the .out file to enable the secure boot first, then flash the Hex file to add the CMAC tag.This operation of flash is complicated, is there any other way to simplify the steps?
Unfortunately the .hex file cannot be used to program OTP. You will need to program the OTP separately with a .out file.
I suggest programming the .out file first to program OTP and then program the hex file.
Thank you,
Luke
