I’m experiencing unexpected behavior when generating clock signals with the CLB and routing them to GPIOs via the CLB Output Xbars.
The CLB Logic Control Register (CLB_DBG_OUT) reflects this behavior, indicating a correlation between the CLB Output Xbar invert mode and the CLB outputs, which I hadn’t anticipated.
Any insights on this correlation would be greatly appreciated.
Wilko
Hi Wilko,
Can you share the CLB drawing, what you are trying to do here. If possible using Sysconfig tool.
Thanks & Regards,
Uttam
Hi Uttam,
Thank you for your response.
I wanted to let you know that I will be out of the office this week but will follow up with you next week.
Wilko
Hi Uttam,
I’ve identified that the issue appears to have a different source.
After some investigation, I found that I need to flash the CLB multiple times before the OutputXbars display the correct values.
I’m not entirely sure why this is necessary, but fortunately, flashing the CLB a few additional times resolves the issue when the output seems inconsistent.
Thank you anyways.
Wilko
