Lab21: how to control motor after HFI start
Other Parts Discussed in Thread: MOTORWARE
Having trouble making sense of Lab 21. The documentation for it is quite poor, and not much discussion on it in the forums exists.  Attached are the user files, i haven't made any changes to the lab itself. Note I am using very low induction motor (Scorpion S-4025-12).  I got through labs 2d, 5a, and 5b, as well as 20 with no issues.
-1st problem is that updating any of the  IPD_HFI variables during runtime in the expressions does not affect the motor control at all, so tuning is very very slow. I have to stop debug, change the variables in the user file, and run again to see if it works better. I think i got the variables to be where they work, at least reasonably for now. Still some occasional jitter on start.
-the name of the variables are different in the lab pdf and in the actual lab's code. Minor, but annoying.
- Now, MOST IMPORTANT, my  understaning is that this lab is supposed to allow me to transition from getting the motor to move from zero with relatively heavy load using HFI, to transition to either speed loop control or torque control FAST. But there is no explanation on how to take over control of the motor once gThrottle_Result has been used to start the motor. Changing the gMotorVars.SpeedRef_krpm value has no effect, regardless the value of gThrottle_Result or the motion of the motor. Is it just a matter of AFSEL_FREQ_LOW_PU ? I've tried a few different values but no success yet. Or is it that the transition to FAST is happening fine, i am just not in control of speed? The motor is spinning at full speed allowed by the voltage (4.5 krpm).
thanks
/* --COPYRIGHT--,BSD
 * Copyright (c) 2012, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
//! \file   solutions/instaspin_foc/src/proj_lab05b.c
//! \brief Adjusting the speed current controller
//! (C) Copyright 2011, Texas Instruments, Inc.
//! \defgroup PROJ_LAB05b PROJ_LAB05b
//! \defgroup PROJ_LAB05b_OVERVIEW Project Overview
//! Adjusting the supplied speed controller
// the includes
// system includes
#include <math.h>
#include "main.h"
#include "sw/modules/ipd/src/32b/ipd_hfi.h"
#include "sw/modules/afsel/src/32b/afsel.h"
#include "sw/modules/fstart/src/32b/fstart.h"
#ifdef FLASH
#pragma CODE_SECTION(mainISR,"ramfuncs");
#endif
// Include header files used in the main function
// the defines
#define LED_BLINK_FREQ_Hz   5
// the globals
uint_least16_t gCounter_updateGlobals = 0;
bool Flag_Latch_softwareUpdate = true;
MATH_vec3 gAdcBiasI;
MATH_vec3 gAdcBiasV;
CTRL_Handle ctrlHandle;
CLARKE_Handle   clarkeHandle_I;               //!< the handle for the current Clarke transform
CLARKE_Obj      clarke_I;                     //!< the current Clarke transform object
CLARKE_Handle   clarkeHandle_V;               //!< the handle for the voltage Clarke transform
CLARKE_Obj      clarke_V;                     //!< the voltage Clarke transform object
EST_Handle      estHandle;                    //!< the handle for the estimator
IPARK_Handle    iparkHandle;                  //!< the handle for the inverse Park transform
IPARK_Obj       ipark;                        //!< the inverse Park transform object
PARK_Handle     parkHandle;                   //!< the handle for the Park object
PARK_Obj        park;                         //!< the Park transform object
SVGEN_Handle    svgenHandle;                  //!< the handle for the space vector generator
SVGEN_Obj       svgen;                        //!< the space vector generator object
IPD_HFI_Handle  ipdHandle;                    //!< the handle for the ipd algorithm
AFSEL_Handle afselHandle;                     //!< the handle for the afselect general algorithm
FStart_Handle   fstartHandle;                 //!< the handle for the flying start algorithm
TRAJ_Handle     trajHandle_Iq;                //!< the trajectory handle for the Iq current reference
TRAJ_Obj        traj_Iq;                      //!< the trajectory for Iq current reference
HAL_Handle halHandle;
USER_Params gUserParams;
HAL_PwmData_t gPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};
HAL_AdcData_t gAdcData;
_iq gMaxCurrentSlope = _IQ(0.0);
#ifdef FAST_ROM_V1p6
CTRL_Obj *controller_obj;
#else
CTRL_Obj ctrl;				//v1p7 format
#endif
uint16_t gLEDcnt = 0;
volatile MOTOR_Vars_t gMotorVars = MOTOR_Vars_INIT;
#ifdef FLASH
// Used for running BackGround in flash, and ISR in RAM
extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart;
#endif
#ifdef DRV8301_SPI
// Watch window interface to the 8301 SPI
DRV_SPI_8301_Vars_t gDrvSpi8301Vars;
#endif
_iq gFlux_pu_to_Wb_sf;
_iq gFlux_pu_to_VpHz_sf;
_iq gTorque_Ls_Id_Iq_pu_to_Nm_sf;
_iq gTorque_Flux_Iq_pu_to_Nm_sf;
_iq gUi = _IQ(0.0);
_iq gThrottle_Result = _IQ(0.0);
bool flag_update_ipd = false;
// the functions
void main(void)
  uint_least8_t estNumber = 0;
  uint_least8_t ctrlNumber = 0;
#endif
  // Only used if running from FLASH
  // Note that the variable FLASH is defined by the project
  #ifdef FLASH
  // Copy time critical code and Flash setup code to RAM
  // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
  // symbols are created by the linker. Refer to the linker files.
  memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,(uint16_t *)&RamfuncsRunStart);
  #endif
  // initialize the hardware abstraction layer
  halHandle = HAL_init(&hal,sizeof(hal));
  // check for errors in user parameters
  USER_checkForErrors(&gUserParams);
  // store user parameter error in global variable
  gMotorVars.UserErrorCode = USER_getErrorCode(&gUserParams);
  // do not allow code execution if there is a user parameter error
  if(gMotorVars.UserErrorCode != USER_ErrorCode_NoError)
      for(;;)
          gMotorVars.Flag_enableSys = false;
  // initialize the user parameters
  USER_setParams(&gUserParams);
  // set the hardware abstraction layer parameters
  HAL_setParams(halHandle,&gUserParams);
  // initialize the controller
  ctrlHandle = CTRL_initCtrl(ctrlNumber, estNumber);  		//v1p6 format (06xF and 06xM devices)
  controller_obj = (CTRL_Obj *)ctrlHandle;
#else
  ctrlHandle = CTRL_initCtrl(estNumber,&ctrl,sizeof(ctrl));	//v1p7 format default
#endif
    CTRL_Version version;
    // get the version number
    CTRL_getVersion(ctrlHandle,&version);
    gMotorVars.CtrlVersion = version;
  // set the default controller parameters
  CTRL_setParams(ctrlHandle,&gUserParams);
  // initialize the Clarke modules
  clarkeHandle_I = CLARKE_init(&clarke_I,sizeof(clarke_I));
  clarkeHandle_V = CLARKE_init(&clarke_V,sizeof(clarke_V));
  // set the number of current sensors
  setupClarke_I(clarkeHandle_I,gUserParams.numCurrentSensors);
  // set the number of voltage sensors
  setupClarke_V(clarkeHandle_V,gUserParams.numVoltageSensors);
  estHandle = controller_obj->estHandle;
#else
  estHandle = ctrl.estHandle;
#endif
  // initialize the inverse Park module
  iparkHandle = IPARK_init(&ipark,sizeof(ipark));
  // initialize the Park module
  parkHandle = PARK_init(&park,sizeof(park));
  // initialize the space vector generator module
  svgenHandle = SVGEN_init(&svgen,sizeof(svgen));
  trajHandle_Iq = TRAJ_init(&traj_Iq,sizeof(traj_Iq));
  TRAJ_setMaxValue(trajHandle_Iq,_IQ(1.0));
  TRAJ_setMinValue(trajHandle_Iq,_IQ(0.0));
  TRAJ_setIntValue(trajHandle_Iq,_IQ(0.0));
  TRAJ_setMaxDelta(trajHandle_Iq,_IQ((float)(1.0/0.5/15.0e3)));
  // initialize the IPD module library file
  ipdHandle = IPD_HFI_init();
  // Set the IPD_HFI parameters
  IPD_HFI_setParams(ipdHandle,
                    USER_ISR_FREQ_Hz,                         // estimation frequency, Hz
                    IPD_HFI_EXC_FREQ_HZ,                      // excitation frequency, Hz
                    IPD_HFI_LP_SPD_FILT_HZ,                   // lowpass filter cutoff frequency, Hz
                    IPD_HFI_HP_IQ_FILT_HZ,                    // highpass filter cutoff frequency, Hz
                    gUserParams.iqFullScaleFreq_Hz,           // IQ full scale frequency, Hz
                    IPD_HFI_KSPD,                             // the speed gain value
                    IPD_HFI_EXC_MAG_COARSE_PU,                // coarse IPD excitation magnitude, pu
                    IPD_HFI_EXC_MAG_FINE_PU,                  // fine IPD excitation magnitude, pu
                    IPD_HFI_EXC_TIME_COARSE_S,                // coarse wait time, sec max 0.64
                    IPD_HFI_EXC_TIME_FINE_S);                 // fine wait time, sec max 0.4
  // Initialize the global motor variables
  gMotorVars.ipd_excFreq_Hz = IPD_HFI_EXC_FREQ_HZ;
  gMotorVars.ipd_Kspd = _IQ(IPD_HFI_KSPD);
  gMotorVars.ipd_excMag_coarse_pu = _IQ(IPD_HFI_EXC_MAG_COARSE_PU);
  gMotorVars.ipd_excMag_fine_pu = _IQ(IPD_HFI_EXC_MAG_FINE_PU);
  gMotorVars.ipd_waitTime_coarse_sec = IPD_HFI_EXC_TIME_COARSE_S;
  gMotorVars.ipd_waitTime_fine_sec = IPD_HFI_EXC_TIME_FINE_S;
  afselHandle = AFSEL_init();
  // Set the AFSEL parameters
  AFSEL_setParams(afselHandle,
                  AFSEL_MAX_IQ_REF_HFI,
                  AFSEL_MAX_IQ_REF_EST,
                  AFSEL_IQ_SLOPE_HFI,
                  AFSEL_IQ_SLOPE_EST,
                  AFSEL_FREQ_LOW_PU,
                  AFSEL_FREQ_HIGH_PU,
                  ipdHandle,
                  estHandle);
//  gFlux_pu_VpHz_sf = USER_computeFlux_pu_to_VpHz_sf();
  // initialize the Flying Start module
  fstartHandle = FStart_init();
    float_t maxFlux_VpHz = (USER_MOTOR_RATED_FLUX*((USER_MOTOR_TYPE==MOTOR_Type_Induction)?0.05:0.7));
    FStart_setParams(fstartHandle,
                     USER_IQ_FULL_SCALE_VOLTAGE_V,
                     USER_IQ_FULL_SCALE_FREQ_Hz,
                     USER_EST_FREQ_Hz,
                     maxFlux_VpHz);
  // disable the forced angle flag
  gMotorVars.Flag_enableForceAngle = false;
  // setup faults
  HAL_setupFaults(halHandle);
  // initialize the interrupt vector table
  HAL_initIntVectorTable(halHandle);
  // enable the ADC interrupts
  HAL_enableAdcInts(halHandle);
  // enable global interrupts
  HAL_enableGlobalInts(halHandle);
  // enable debug interrupts
  HAL_enableDebugInt(halHandle);
  // disable the PWM
  HAL_disablePwm(halHandle);
#ifdef DRV8301_SPI
  // turn on the DRV8301 if present
  HAL_enableDrv(halHandle);
  // initialize the DRV8301 interface
  HAL_setupDrvSpi(halHandle,&gDrvSpi8301Vars);
#endif
  // enable DC bus compensation
  CTRL_setFlag_enableDcBusComp(ctrlHandle, true);
  // compute scaling factors for flux and torque calculations
  gFlux_pu_to_Wb_sf = USER_computeFlux_pu_to_Wb_sf();
  gFlux_pu_to_VpHz_sf = USER_computeFlux_pu_to_VpHz_sf();
  gTorque_Ls_Id_Iq_pu_to_Nm_sf = USER_computeTorque_Ls_Id_Iq_pu_to_Nm_sf();
  gTorque_Flux_Iq_pu_to_Nm_sf = USER_computeTorque_Flux_Iq_pu_to_Nm_sf();
  for(;;)
    // Waiting for enable system flag to be set
    while(!(gMotorVars.Flag_enableSys));
    // Enable the Library internal PI.  Iq is referenced by the speed PI now
    CTRL_setFlag_enableSpeedCtrl(ctrlHandle, true);
    // loop while the enable system flag is true
    while(gMotorVars.Flag_enableSys)
      CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle;
      // increment counters
      gCounter_updateGlobals++;
      // enable/disable the use of motor parameters being loaded from user.h
      CTRL_setFlag_enableUserMotorParams(ctrlHandle,gMotorVars.Flag_enableUserParams);
      // enable/disable Rs recalibration during motor startup
      EST_setFlag_enableRsRecalc(obj->estHandle,gMotorVars.Flag_enableRsRecalc);
      // enable/disable automatic calculation of bias values
      CTRL_setFlag_enableOffset(ctrlHandle,gMotorVars.Flag_enableOffsetcalc);
      if(CTRL_isError(ctrlHandle))
        // set the enable controller flag to false
        CTRL_setFlag_enableCtrl(ctrlHandle,false);
        // set the enable system flag to false
        // IPD disable
        IPD_HFI_disable(ipdHandle);
        // disable the PWM
      else
        // update the controller state
        bool flag_ctrlStateChanged = CTRL_updateState(ctrlHandle);
        // enable or disable the control
        CTRL_setFlag_enableCtrl(ctrlHandle, gMotorVars.Flag_Run_Identify);
        if(flag_ctrlStateChanged)
          CTRL_State_e ctrlState = CTRL_getState(ctrlHandle);
          if(ctrlState == CTRL_State_OffLine)
            // enable the PWM
            HAL_enablePwm(halHandle);
          else if(ctrlState == CTRL_State_OnLine)
            if(gMotorVars.Flag_enableOffsetcalc == true)
              uint_least16_t cnt;
              // update the ADC bias values
              HAL_updateAdcBias(halHandle);
              // record the current bias
              for(cnt=0;cnt<3;cnt++)
                gAdcBiasI.value[cnt] = HAL_getBias(halHandle,HAL_SensorType_Current,cnt);
              // record the voltage bias
                gAdcBiasV.value[cnt] = HAL_getBias(halHandle,HAL_SensorType_Voltage,cnt);
              gMotorVars.Flag_enableOffsetcalc = false;
            else
              uint_least16_t cnt;
              // set the current bias
                HAL_setBias(halHandle,HAL_SensorType_Current,cnt,gAdcBiasI.value[cnt]);
              // set the voltage bias
                HAL_setBias(halHandle,HAL_SensorType_Voltage,cnt,gAdcBiasV.value[cnt]);
            IPD_HFI_enable(ipdHandle);
            AFSEL_enable(afselHandle);
            // enable the PWM
          else if(ctrlState == CTRL_State_Idle)
            // disable the PWM
            // IPD disable
            AFSEL_disable(afselHandle);
            gMotorVars.Flag_Run_Identify = false;
          if((CTRL_getFlag_enableUserMotorParams(ctrlHandle) == true) &&
            (ctrlState > CTRL_State_Idle) &&
            (gMotorVars.CtrlVersion.minor == 6))
            // call this function to fix 1p6
            USER_softwareUpdate1p6(ctrlHandle);
      if(EST_isMotorIdentified(obj->estHandle))
        // set the current ramp
        EST_setMaxCurrentSlope_pu(obj->estHandle,gMaxCurrentSlope);
        gMotorVars.Flag_MotorIdentified = true;
        // set the speed reference
        CTRL_setSpd_ref_krpm(ctrlHandle,gMotorVars.SpeedRef_krpm);
        // set the speed acceleration
        CTRL_setMaxAccel_pu(ctrlHandle,_IQmpy(MAX_ACCEL_KRPMPS_SF,gMotorVars.MaxAccel_krpmps));
        if(Flag_Latch_softwareUpdate)
          Flag_Latch_softwareUpdate = false;
          USER_calcPIgains(ctrlHandle);
          // initialize the watch window kp and ki current values with pre-calculated values
          gMotorVars.Kp_Idq = CTRL_getKp(ctrlHandle,CTRL_Type_PID_Id);
          gMotorVars.Ki_Idq = CTRL_getKi(ctrlHandle,CTRL_Type_PID_Id);
          // initialize the watch window kp and ki values with pre-calculated values
          gMotorVars.Kp_spd = CTRL_getKp(ctrlHandle,CTRL_Type_PID_spd);
          gMotorVars.Ki_spd = CTRL_getKi(ctrlHandle,CTRL_Type_PID_spd);
      else
        // the estimator sets the maximum current slope during identification
        gMaxCurrentSlope = EST_getMaxCurrentSlope_pu(obj->estHandle);
      // when appropriate, update the global variables
      if(gCounter_updateGlobals >= NUM_MAIN_TICKS_FOR_GLOBAL_VARIABLE_UPDATE)
        // reset the counter
        updateGlobalVariables_motor(ctrlHandle);
        // Update the IPD parameters in real time when flag_update_ipd is true
        if(flag_update_ipd)
            uint_least32_t period = (uint_least32_t)(USER_ISR_FREQ_Hz / (2.0 * gMotorVars.ipd_excFreq_Hz));
            uint_least32_t Periods[IPD_HFI_TRAJ_State_NumStates] = {0,0};
            Periods[IPD_HFI_TRAJ_State_Coarse] = period;
            Periods[IPD_HFI_TRAJ_State_Fine] = period;
            IPD_HFI_setTrajPeriods(ipdHandle,Periods);
          IPD_HFI_setKspd_pu(ipdHandle, _IQmpy(gMotorVars.ipd_Kspd,_IQ(1.0/MATH_TWO_PI)));
            _iq Mags[4] = {0,0,0,0};
            Mags[IPD_HFI_TRAJ_State_Coarse] = gMotorVars.ipd_excMag_coarse_pu;
            Mags[IPD_HFI_TRAJ_State_Fine] = gMotorVars.ipd_excMag_fine_pu;
            IPD_HFI_setTrajMags(ipdHandle,Mags);
            uint_least32_t coarse_s = (uint_least32_t)(gMotorVars.ipd_waitTime_coarse_sec * USER_ISR_FREQ_Hz);
            uint_least32_t fine_s = (uint_least32_t)(gMotorVars.ipd_waitTime_fine_sec * USER_ISR_FREQ_Hz);
            uint_least32_t WaitTimes[5] = {0,0,0,0,0};
            WaitTimes[IPD_HFI_State_Coarse] = coarse_s;
            WaitTimes[IPD_HFI_State_Fine] = fine_s;
            IPD_HFI_setWaitTimes(ipdHandle,WaitTimes);
      // update Kp and Ki gains
      updateKpKiGains(ctrlHandle);
      // calculate the throttle position and output as a torque command
        _iq IqSlope = AFSEL_getIqSlope(afselHandle);
        _iq IqMax = AFSEL_getIqMax(afselHandle);
        gUi = FStart_run(fstartHandle,
                         EST_getFm_pu(estHandle),
                         EST_getFlux_pu(estHandle));
        // set slope for Iq reference
        TRAJ_setMaxDelta(trajHandle_Iq, IqSlope);
        // set maximum Iq reference
        TRAJ_setMaxValue(trajHandle_Iq, IqMax);
        // set target Iq reference
        TRAJ_setTargetValue(trajHandle_Iq, gThrottle_Result);
      // enable/disable the forced angle
      EST_setFlag_enableForceAngle(obj->estHandle,gMotorVars.Flag_enableForceAngle);
      // update the afsel state
      AFSEL_updateState(afselHandle);
      // update the IPD state
      IPD_HFI_updateState(ipdHandle);
      // enable or disable power warp
      CTRL_setFlag_enablePowerWarp(ctrlHandle,gMotorVars.Flag_enablePowerWarp);
#ifdef DRV8301_SPI
      HAL_writeDrvData(halHandle,&gDrvSpi8301Vars);
      HAL_readDrvData(halHandle,&gDrvSpi8301Vars);
#endif
    } // end of while(gFlag_enableSys) loop
    // disable the PWM
    // IPD disable
    // reset the IPD estimator
    IPD_HFI_setAngle_pu(ipdHandle,_IQ(0.0));
    IPD_HFI_setId_sum(ipdHandle,_IQ(0.0));
    // set the default controller parameters (Reset the control to re-identify the motor)
  } // end of for(;;) loop
} // end of main() function
interrupt void mainISR(void)
  _iq angle_pu,angle_hfi_pu,angle_est_pu;
  _iq speed_pu,speed_hfi_pu,speed_est_pu;
  _iq speed_ref_pu = TRAJ_getIntValue(((CTRL_Obj *)ctrlHandle)->trajHandle_spd);
  _iq speed_outMax_pu = TRAJ_getIntValue(((CTRL_Obj *)ctrlHandle)->trajHandle_spdMax);
  MATH_vec2 Iab_pu;
  MATH_vec2 Vab_pu;
  MATH_vec2 Vdq_out_pu;
  MATH_vec2 Vab_out_pu;
  MATH_vec2 phasor;
  // toggle status LED
  if(gLEDcnt++ > (uint_least32_t)(USER_ISR_FREQ_Hz / LED_BLINK_FREQ_Hz))
    HAL_toggleLed(halHandle,(GPIO_Number_e)HAL_Gpio_LED2);
    gLEDcnt = 0;
  // acknowledge the ADC interrupt
  HAL_acqAdcInt(halHandle,ADC_IntNumber_1);
  // convert the ADC data
  HAL_readAdcData(halHandle,&gAdcData);
    uint_least16_t count_isr = CTRL_getCount_isr(ctrlHandle);
    uint_least16_t numIsrTicksPerCtrlTick = CTRL_getNumIsrTicksPerCtrlTick(ctrlHandle);
    // if needed, run the controller
    if(count_isr >= numIsrTicksPerCtrlTick)
      bool flag_enableSpeedCtrl;
      bool flag_enableCurrentCtrl;
      MATH_vec2 Idq_offset_pu;
      MATH_vec2 Vdq_offset_pu;
      // reset the isr count
      CTRL_resetCounter_isr(ctrlHandle);
      // run Clarke transform on current
      CLARKE_run(clarkeHandle_I,&gAdcData.I,&Iab_pu);
      // run Clarke transform on voltage
      CLARKE_run(clarkeHandle_V,&gAdcData.V,&Vab_pu);
        // run the estimator
        EST_run(estHandle, \
                &Iab_pu, \
                &Vab_pu, \
                gAdcData.dcBus, \
                speed_ref_pu);
      // run IPD-HFI
      if(IPD_HFI_isEnabled(ipdHandle))
        // run the IPD algorithm
        IPD_HFI_run(ipdHandle,&Iab_pu);
        // set the Vdq bias
        Vdq_offset_pu.value[0] = IPD_HFI_getVdValue(ipdHandle);
        Vdq_offset_pu.value[1] = _IQ(0.0);
        // get the reference angle and frequency values
        angle_pu = IPD_HFI_getAngle_pu(ipdHandle);
        speed_pu = IPD_HFI_getSpeed_lp_pu(ipdHandle);
      else
        // zero the Vdq bias
        Vdq_offset_pu.value[0] = _IQ(0.0);
        // get the estimator angle and frequency values
        angle_pu = EST_getAngle_pu(estHandle);
        speed_pu = EST_getFm_pu(estHandle);
      if(AFSEL_isEnabled(afselHandle))
        angle_hfi_pu = IPD_HFI_getAngle_pu(ipdHandle);
        speed_hfi_pu = IPD_HFI_getSpeed_lp_pu(ipdHandle);
        angle_est_pu = EST_getAngle_pu(estHandle);
        speed_est_pu = EST_getFm_pu(estHandle);
        // setup the angle/frequency selector
        AFSEL_setup(afselHandle,
                    angle_hfi_pu,
                    speed_hfi_pu,
                    angle_est_pu,
                    speed_est_pu);
        // run the angle/frequency selector
        AFSEL_run(afselHandle);
        // get the angle and frequency
        angle_pu = AFSEL_getAngle_pu(afselHandle);
        speed_pu = AFSEL_getFreq_pu(afselHandle);
      // compute the sin/cos phasor
      CTRL_computePhasor(angle_pu,&phasor);
      // set the phasor in the Park transform
      PARK_setPhasor(parkHandle,&phasor);
      // run the Park transform
      PARK_run(parkHandle,&Iab_pu,CTRL_getIdq_in_addr(ctrlHandle));
      // run the Iq current trajectory
      TRAJ_run(trajHandle_Iq);
      // set the offset based on the Id trajectory
      Idq_offset_pu.value[0] = TRAJ_getIntValue(((CTRL_Obj *)ctrlHandle)->trajHandle_Id);
      Idq_offset_pu.value[1] = TRAJ_getIntValue(trajHandle_Iq);;
      flag_enableSpeedCtrl = EST_doSpeedCtrl(estHandle) & gMotorVars.Flag_enableSpeedCtrl;
      flag_enableCurrentCtrl = EST_doCurrentCtrl(estHandle);
      CTRL_setup_user(ctrlHandle,
                      angle_pu,
                      speed_ref_pu,
                      speed_pu,
                      speed_outMax_pu,
                      &Idq_offset_pu,
                      &Vdq_offset_pu,
                      flag_enableSpeedCtrl,
                      flag_enableCurrentCtrl);
      // run the appropriate controller
        // run the online controller
        CTRL_runPiOnly(ctrlHandle);
        // get the controller output
        CTRL_getVdq_out_pu(ctrlHandle,&Vdq_out_pu);
        // set the phasor in the inverse Park transform
        IPARK_setPhasor(iparkHandle,&phasor);
        // run the inverse Park module
        IPARK_run(iparkHandle,&Vdq_out_pu,&Vab_out_pu);
        // run the space Vector Generator (SVGEN) module
        SVGEN_run(svgenHandle,&Vab_out_pu,&(gPwmData.Tabc));
      else if(ctrlState == CTRL_State_OffLine)
        // run the offline controller
        CTRL_runOffLine(ctrlHandle,halHandle,&gAdcData,&gPwmData);
    else
      // increment the isr count
      CTRL_incrCounter_isr(ctrlHandle);
  // write the PWM compare values
  HAL_writePwmData(halHandle,&gPwmData);
  return;
} // end of mainISR() function
void setupClarke_I(CLARKE_Handle handle,const uint_least8_t numCurrentSensors)
  _iq alpha_sf,beta_sf;
  // initialize the Clarke transform module for current
  if(numCurrentSensors == 3)
      alpha_sf = _IQ(MATH_ONE_OVER_THREE);
      beta_sf = _IQ(MATH_ONE_OVER_SQRT_THREE);
  else if(numCurrentSensors == 2)
      alpha_sf = _IQ(1.0);
  else
      alpha_sf = _IQ(0.0);
      beta_sf = _IQ(0.0);
  // set the parameters
  CLARKE_setScaleFactors(handle,alpha_sf,beta_sf);
  CLARKE_setNumSensors(handle,numCurrentSensors);
  return;
} // end of setupClarke_I() function
void setupClarke_V(CLARKE_Handle handle,const uint_least8_t numVoltageSensors)
  // initialize the Clarke transform module for voltage
  if(numVoltageSensors == 3)
 else
      beta_sf = _IQ(0.0);
  CLARKE_setNumSensors(handle,numVoltageSensors);
  return;
} // end of setupClarke_V() function
void updateGlobalVariables_motor(CTRL_Handle handle)
  CTRL_Obj *obj = (CTRL_Obj *)handle;
  // get the speed estimate
  gMotorVars.Speed_krpm = EST_getSpeed_krpm(obj->estHandle);
  // get the real time speed reference coming out of the speed trajectory generator
  gMotorVars.SpeedTraj_krpm = _IQmpy(CTRL_getSpd_int_ref_pu(handle),EST_get_pu_to_krpm_sf(obj->estHandle));
  // get the torque estimate
  gMotorVars.Torque_Nm = USER_computeTorque_Nm(handle, gTorque_Flux_Iq_pu_to_Nm_sf, gTorque_Ls_Id_Iq_pu_to_Nm_sf);
  // get the magnetizing current
  gMotorVars.MagnCurr_A = EST_getIdRated(obj->estHandle);
  // get the rotor resistance
  gMotorVars.Rr_Ohm = EST_getRr_Ohm(obj->estHandle);
  // get the stator resistance
  gMotorVars.Rs_Ohm = EST_getRs_Ohm(obj->estHandle);
  // get the stator inductance in the direct coordinate direction
  gMotorVars.Lsd_H = EST_getLs_d_H(obj->estHandle);
  // get the stator inductance in the quadrature coordinate direction
  gMotorVars.Lsq_H = EST_getLs_q_H(obj->estHandle);
  // get the flux in V/Hz in floating point
  gMotorVars.Flux_VpHz = EST_getFlux_VpHz(obj->estHandle);
  // get the flux in Wb in fixed point
  gMotorVars.Flux_Wb = USER_computeFlux(handle, gFlux_pu_to_Wb_sf);
  // get the controller state
  gMotorVars.CtrlState = CTRL_getState(handle);
  // get the estimator state
  gMotorVars.EstState = EST_getState(obj->estHandle);
  // Get the DC buss voltage
  gMotorVars.VdcBus_kV = _IQmpy(gAdcData.dcBus,_IQ(USER_IQ_FULL_SCALE_VOLTAGE_V/1000.0));
  return;
} // end of updateGlobalVariables_motor() function
void updateKpKiGains(CTRL_Handle handle)
  if((gMotorVars.CtrlState == CTRL_State_OnLine) && (gMotorVars.Flag_MotorIdentified == true) && (Flag_Latch_softwareUpdate == false))
      // set the kp and ki speed values from the watch window
      CTRL_setKp(handle,CTRL_Type_PID_spd,gMotorVars.Kp_spd);
      CTRL_setKi(handle,CTRL_Type_PID_spd,gMotorVars.Ki_spd);
      // set the kp and ki current values for Id and Iq from the watch window
      CTRL_setKp(handle,CTRL_Type_PID_Id,gMotorVars.Kp_Idq);
      CTRL_setKi(handle,CTRL_Type_PID_Id,gMotorVars.Ki_Idq);
      CTRL_setKp(handle,CTRL_Type_PID_Iq,gMotorVars.Kp_Idq);
      CTRL_setKi(handle,CTRL_Type_PID_Iq,gMotorVars.Ki_Idq);
  return;
} // end of updateKpKiGains() function
//@} //defgroup
// end of file
2352.user.h2337.user_j1.h6052.user_j5.h
    this motor does not have any saliency, the HFI technique will not be successful
    project_lab21 is just torque mode only (used for things like e-Bikes).
    21.       Initial & Slow Speed Position Detection (IPD_HFI) with transition (AFSEL) to FAST: Torque Control Mode [F2806x only for first release]
    22.       Coming Soon: IPD_HFI with Speed Control Mode [and F2802x support]
  • oh I see, I though since the magnets on these are spaced apart, the motor was salient. I suppose there isn't much point in doing this lab then. So given the motor, is Force Angle start the only method available to me for a torqued loaded start?
    On another note, speed control has barely any torque and so it seems pretty useless to me, is there some variable that can increase the torque of a speed controller? Meaning have it chew up as much amp as needed (with some safety cap) to get to its target speed?
  • while magnets being spaced out can effect saliency, I know you won't find any of these hobby motors with enough for the HFI. It takes a very specialized motor design to make this effective.
    yes, ForceAngle Enabled/Disabled would be your only valid way.
    When in speed control mode are able to request a torque up to
    USER_MOTOR_MAX_CURRENT
    if you aren't producing enough torque I first suggest you increase this value. This is the peak of the sinewave for the current.
    For most hobby motors it will be hard to produce high torque at lower speeds because the flux of the machine is so low that the FAST estimation of angle is not accurate enough to guarantee orthogonal orientation of the stator flux.
    any update on the last point (22)?
    thank you very much
    lorenzo
  • Lorenzo,
    I should remove that point.
    The IPD_HFI has proved extremely challenging to get working unless the customer has some significant expertise and knows the inductance/saliency and saturation effects of their motor very well.  Because it is not "instant" we have decided to stop investing in solutions that use IPD_HFI.  We are leaving the existing project as-is for customers who want to give it a try.
  • Chris,
    thank you very much for your fast answer.
    do you have an high level description of the hfi module? such a schematics?
    have a great weekend
    lorenzo
  • www.ti.com/.../instaspin-zero-and-slow-speed.shtml
    which is similar to the write-up in proj_lab21
    C:\ti\motorware\motorware_1_01_00_16\sw\modules\ipd\src\32b\ipd_hfi.h
    gives all the interface APIs
    there isn't anything more than that
  • Thank you Sir, please do me a favor... have a great weekend!
    Lorenzo
  • Hi Chris,
    May I run the lab21 on the HVKit? What's the lab procedure? Do I just need to set "gMotorVars.Flag_enableSys" and “gMotorVars.Flag_Run_Identify" equal to 1?
    What is the result, if the lab operation successfully? Can I see the rotor position vary when I spin the rotor?
    Thanks!
  • Hi lui kawasumi ,
    Did you run the lab21 successfully? Which platform did you base on? Thanks!
  • lab21 does not have project support for the HVKIT
    you could port this over yourself, but we have never done so
  • Hi Chris,
        Thanks for your reply. I transfer the project lab21 to Lab5b by using Lab21's "user.h"  file and other Library files. I can compile and run the project normally.
    But when I set "gMotorVars.Flag_enableSys" and “gMotorVars.Flag_Run_Identify" equal to 1, I just hear some noise, not any other reaction.
       I read the rotor position from the variable "angle_pu"   in the debug window, it doesn't work normally.
       Could you give me some advices about the lab procedure and the correct result?
       Thank you!
    Eli
