Part Number: TMS320F28027
Other Parts Discussed in Thread: CONTROLSUITE, C2000WARE
Hi all,
I am trying to import the built-in CCS example (blinking LED). However, I got following error as shown below. By the way, I did not change anything for the example
**** Build of configuration Debug for project Example_2802xGpioToggle ****
"D:\\ti\\ccs\\ccs\\utils\\bin\\gmake" -k all
Building file: "../Example_2802xGpioToggle.c"
Invoking: C2000 Compiler
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="Example_2802xGpioToggle.d_raw" "../Example_2802xGpioToggle.c"
remark: --output_all_syms is deprecated and will be removed in a subsequent
release. This is now the default behavior of the compiler.
subdir_rules.mk:9: recipe for target 'Example_2802xGpioToggle.obj' failed
error: --cdebug_asm_data is no longer supported
gmake: *** [Example_2802xGpioToggle.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/source/F2802x_GlobalVariableDefs.c"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="F2802x_GlobalVariableDefs.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/source/F2802x_GlobalVariableDefs.c"
subdir_rules.mk:16: recipe for target 'F2802x_GlobalVariableDefs.obj' failed
gmake: *** [F2802x_GlobalVariableDefs.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_codestartbranch.asm"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_codestartbranch.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_codestartbranch.asm"
subdir_rules.mk:23: recipe for target 'f2802x_codestartbranch.obj' failed
gmake: *** [f2802x_codestartbranch.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_defaultisr.c"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_defaultisr.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_defaultisr.c"
subdir_rules.mk:30: recipe for target 'f2802x_defaultisr.obj' failed
gmake: *** [f2802x_defaultisr.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_piectrl.c"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_piectrl.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_piectrl.c"
subdir_rules.mk:37: recipe for target 'f2802x_piectrl.obj' failed
gmake: *** [f2802x_piectrl.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_pievect.c"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_pievect.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_pievect.c"
subdir_rules.mk:44: recipe for target 'f2802x_pievect.obj' failed
gmake: *** [f2802x_pievect.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_sysctrl.c"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_sysctrl.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_sysctrl.c"
subdir_rules.mk:51: recipe for target 'f2802x_sysctrl.obj' failed
gmake: *** [f2802x_sysctrl.obj] Error 1
Building file: "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_usdelay.asm"
"D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/bin/cl2000" -v28 -ml -mt --include_path="D:/ti/ccs/ccs/tools/compiler/ti-cgt-c2000_18.12.2.LTS/include" --include_path="/packages/ti/xdais" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_headers/include" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230" --include_path="D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/include" --include_path="D:/ti/controlSUITE/libs/math/IQmath/v15c/include" --define=_DEBUG --define=LARGE_MODEL -g --diag_suppress=232 --diag_suppress=10063 --diag_warning=225 --issue_remarks --verbose_diagnostics --quiet --abi=coffabi --cdebug_asm_data --output_all_syms --preproc_with_compile --preproc_dependency="f2802x_usdelay.d_raw" "D:/ti/controlSUITE/device_support/f2802x/v230/f2802x_common/source/f2802x_usdelay.asm"
subdir_rules.mk:58: recipe for target 'f2802x_usdelay.obj' failed
gmake: *** [f2802x_usdelay.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
