Hello Team TI,
I am using following code for SOC of ADC channel 2,
void ConfigureEPWM(void) { EALLOW; // Assumes ePWM clock is already enabled EPwm2Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm2Regs.ETSEL.bit.SOCASEL = 3; // Select SOC on up-count EPwm2Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm2Regs.TBPRD = 19; // Set period to 2.5 MHz EPwm2Regs.TBCTL.bit.CTRMODE = 0 ; // freeze counter EDIS; }
and then
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 7;
It is workin fine. However, when I use
{ EALLOW; // Assumes ePWM clock is already enabled EPwm3Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm3Regs.ETSEL.bit.SOCASEL = 3; // Select SOC on up-count EPwm3Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm3Regs.TBPRD = 19; // Set period to 2.5 MHz EPwm3Regs.TBCTL.bit.CTRMODE = 0 ; // freeze counter EDIS; }
and then,
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 8;
and it is not working fine. Can anyone please suggest why is it so?
