Other Parts Discussed in Thread: TMS320F28388D, C2000WARE
Hi Experts
Our customer is developing their system with F28388D. Although customer is evaluating PWM signals, customer observed strange waveform. I attached this one(TMS320F28388D_PWM_Issue_2020_1026.pdf). Operating frequency is 100kHz. Customer is using driverlib on C2000Ware during PWM configuration. Customer was looking into this issue on E2E and notice the similar issue was reported as following thread, however, they cannot find any solution on this thread.
https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/376207?F28069-ePWM-phase-shift-problem
I attached customer's source code(
* drv_epwm.c
* Created on: 2019/09/12
#include "F28x_Project.h"
#include <SFO_V8.h>
#include <stdint.h>
#include <stdbool.h>
#include <sysctl.h>
#include <epwm.h>
#include <inc/hw_epwm.h>
#include <inc/hw_memmap.h>
#include <driver/drv_epwm_c2.h>
#include <driver/drv_hrpwm_c2.h>
void InitEPwm1(void);
void InitEPwm2(void);
void InitEPwm3(void);
void InitEPwm4(void);
void InitEPwm5(void);
void InitEPwm6(void);
void InitEPwm12(void); //For measurement 0f CLA internal calculation performance
//For High resolution PWM calibration
int MEP_ScaleFactor; //Global variable used by the SFO library
//Result can be used for all HRPWM channels
//This variable is also copied to HRMSTEP
//register by SFO(0) function.
// Used by SFO library (ePWM[0] is a dummy value that isn't used)
volatile uint32_t ePWM[PWM_CH_MAX + 1] = {0, EPWM1_BASE, EPWM2_BASE, EPWM3_BASE, EPWM4_BASE};
// EPWM�̏�����
// ���� �Ȃ�
// �߂�l �Ȃ�
void init_EPwm(void){
InitEPwm1(); //PWM for high-voltage class D amplifier
InitEPwm2(); //PWM for high-voltage class D amplifier
InitEPwm3(); //PWM for high voltage DCDC converter
InitEPwm4(); //PWM for high voltage DCDC converter
InitEPwm12(); //For measurement 0f CLA internal calculation performance
SFO();
// ������\PWM�̃L�����u���[�V����
// ��莞�ԊԊu�ŕK�����s����B
// ���� �Ȃ�
// �߂�l �Ȃ�
void HrPwmCal(void){
SFO();//PWM Calibration
// EPWM1�̏�����
// ����D���A���v�pPWM�o�� �p���X����
// ���� �Ȃ�
// �߂�l �Ȃ�
void InitEPwm1(void){
EALLOW;
//Stop PWM Timer PWM���W�X�^�ݒ莞�N���b�N������K����~����
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
//Time-Base(TB) Module configuration
//�ݒ�l�l���f����
EPWM_setPeriodLoadMode(EPWM1_BASE, EPWM_PERIOD_DIRECT_LOAD);
//�^�C�}�J�E���g�A�b�v
EPWM_setTimeBaseCounterMode(EPWM1_BASE, EPWM_COUNTER_MODE_UP);
//PWM�����̐ݒ�
EPWM_setTimeBasePeriod(EPWM1_BASE, EPWM1_PERIOD - 1);
//�ʑ��V�t�g���[�h���Ȃ� EPWM��œ��삳���邽��
EPWM_disablePhaseShiftLoad(EPWM1_BASE);
//�ʑ��̐ݒ� Master��0��
EPWM_setPhaseShift(EPWM1_BASE, 0);
//�J�E���^�l�̃N���A
EPWM_setTimeBaseCounter(EPWM1_BASE, 0);
//�����M����o�͂���
EPWM_enableSyncOutPulseSource(EPWM1_BASE, EPWM_SYNC_OUT_PULSE_ON_CNTR_ZERO); //Counter zero event generates EPWM sync-out pulse
//Configuration for PWM Clock Division
EPWM_setClockPrescaler(EPWM1_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
//Counter Compare (CC) Module�̐ݒ� �f���[�e�B��̐ݒ�
//�f���[�e�B��ݒ�AAPI����Ȃ����K�ȃf���[�e�B�䂪�ݒ�ł��Ȃ�
//�b��Ń��W�X�^���ڐݒ�
//CMPA duty ratio setting is "fixed 50%"
EPwm1Regs.CMPA.all = (unsigned long)(65536.0 * ((float)EPwm1Regs.TBPRD * EPWM1_PULSEWIDTH_A));
//EPWM_setCounterCompareValue(EPWM1_BASE, EPWM_COUNTER_COMPARE_A, (unsigned long)(65536.0 * ((float)EPwm1Regs.TBPRD * EPWM1_PULSEWIDTH_A)));
//CMPB duty ratio setting is "fixed 50%"
EPwm1Regs.CMPB.all = (unsigned long)(65536.0 * ((float)EPwm1Regs.TBPRD * EPWM1_PULSEWIDTH_B));
//EPWM_setCounterCompareValue(EPWM1_BASE, EPWM_COUNTER_COMPARE_B, (unsigned long)(65536.0 * ((float)EPwm1Regs.TBPRD * EPWM1_PULSEWIDTH_B)));
//CMPA : Enable shadow Register
EPWM_setCounterCompareShadowLoadMode(EPWM1_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
//CMPB : Enable shadow Register
EPWM_setCounterCompareShadowLoadMode(EPWM1_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
//Action Qualifier(AQ) Module�̐ݒ�
EPWM_setActionQualifierAction(EPWM1_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM1_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(EPWM1_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM1_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
//Dead Band Generator(DB) Module�̐ݒ�
//Configure deadband delay mode
EPWM_setDeadBandDelayMode(EPWM1_BASE, EPWM_DB_RED, true); //�����オ��G�b�W�ɒx����t������
EPWM_setDeadBandDelayMode(EPWM1_BASE, EPWM_DB_FED, true); //����������G�b�W�ɒx����t������
//Configure deadband delay polarity
EPWM_setDeadBandDelayPolarity(EPWM1_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH); //�]
EPWM_setDeadBandDelayPolarity(EPWM1_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW); //���]
//Configure inputs for RED & FED delay
EPWM_setRisingEdgeDeadBandDelayInput(EPWM1_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDeadBandDelayInput(EPWM1_BASE, EPWM_DB_INPUT_EPWMA);
//Configure RED & FED delay values
EPWM_setFallingEdgeDelayCount(EPWM1_BASE, EPWM1_RISE_DB);
EPWM_setRisingEdgeDelayCount(EPWM1_BASE, EPWM1_FALL_DB);
//HRPWM Module�̐ݒ�
//Sets the high resolution comparator load mode.
//Load from shadow register to active register with TBCTR = 0
HRPWM_setCounterCompareShadowLoadEvent(EPWM1_BASE, HRPWM_CHANNEL_A,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setCounterCompareShadowLoadEvent(EPWM1_BASE, HRPWM_CHANNEL_B,HRPWM_LOAD_ON_CNTR_ZERO);
//Configure MEP edge & control mode for channel A & B. MEP Edge control is on falling edge. Control mode is duty control.
//��������[�h��K�p����ꏊ(�p���X���ɑ��ĂȂ̂��A�ʑ��ɑ��ĂȂ̂���ݒ肷��)
HRPWM_setMEPEdgeSelect(EPWM1_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM1_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_PHASE_CTRL);
HRPWM_setMEPEdgeSelect(EPWM1_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM1_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_PHASE_CTRL);
//Enable auto-conversion logic.
//�����ϊ��@�\��L��(��{�I�ɗL���ݒ�)
HRPWM_enableAutoConversion(EPWM1_BASE);
//Enable HRPWM phase synchronization on software sync.
//Required for up-down count HR control..
//HRPWM_enablePhaseShiftLoad(EPWM1_BASE);
//ET Module �̐ݒ�
//EPWM���ADC�̃g���K������܂�
//ADC �ϊ��J�nA�iEPWMxSOCA�j�p���X�̃C�l�[�u��
EPWM_enableADCTrigger(EPWM1_BASE, EPWM_SOC_A);
//�ǂ̃^�C�~���O�ŕϊ��J�nA�p���X��o���� �^�C�}�J�E���^��0�ɂȂ�����
EPWM_setADCTriggerSource(EPWM1_BASE, EPWM_SOC_A, EPWM_SOC_TBCTR_ZERO);
//Sets the ePWM SOC event counts. ����
EPWM_setADCTriggerEventPrescale(EPWM1_BASE, EPWM_SOC_A, 1);
//Clear SOC flag.
EPWM_clearADCTriggerFlag(EPWM1_BASE, EPWM_SOC_A);
//Timer Starting
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
EDIS;
// EPWM2�̏�����
// ���� �Ȃ�
// �߂�l �Ȃ�
void InitEPwm2(void){
EALLOW;
//Time-Base(TB) Module�̐ݒ�
//�ݒ�l�l���f����
EPWM_setPeriodLoadMode(EPWM2_BASE, EPWM_PERIOD_DIRECT_LOAD);
EPWM_setTimeBaseCounterMode(EPWM2_BASE, EPWM_COUNTER_MODE_UP);
//PWM�����̐ݒ�
EPWM_setTimeBasePeriod(EPWM2_BASE, EPWM2_PERIOD - 1);
//�ʑ��V�t�g���[�h���� EPWM1�Ɠ��������邽��
EPWM_enablePhaseShiftLoad(EPWM2_BASE);
EPWM_setPhaseShift(EPWM2_BASE, 0);
//�J�E���^�l�̃N���A
EPWM_setTimeBaseCounter(EPWM2_BASE, 0);
//�����M�����͑I�� PWM1�Ɠ���
EPWM_setSyncInPulseSource(EPWM2_BASE, EPWM_SYNC_IN_PULSE_SRC_SYNCOUT_EPWM1);
//PWM�N���b�N�̕����ݒ�
EPWM_setClockPrescaler(EPWM2_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
//CMPA�f�B�[�e�B��̐ݒ� 50%�Œ�
EPwm2Regs.CMPA.all = (unsigned long)(65536.0 * ((float)EPwm2Regs.TBPRD * EPWM2_PULSEWIDTH_A));
//CMPB�f�B�[�e�B��̐ݒ� 50%�Œ�
EPwm2Regs.CMPB.all = (unsigned long)(65536.0 * ((float)EPwm2Regs.TBPRD * EPWM2_PULSEWIDTH_B));
//CMPA �V���h�E���W�X�^��L���ɂ���
EPWM_setCounterCompareShadowLoadMode(EPWM2_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
//CMPB �V���h�E���W�X�^��L���ɂ���
EPWM_setCounterCompareShadowLoadMode(EPWM2_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setActionQualifierAction(EPWM2_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM2_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(EPWM2_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM2_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setDeadBandDelayMode(EPWM2_BASE, EPWM_DB_RED, true); //�����オ��G�b�W�ɒx����t������
EPWM_setDeadBandDelayMode(EPWM2_BASE, EPWM_DB_FED, true); //����������G�b�W�ɒx����t������
EPWM_setDeadBandDelayPolarity(EPWM2_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH); //�]
EPWM_setDeadBandDelayPolarity(EPWM2_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW); //���]
EPWM_setRisingEdgeDeadBandDelayInput(EPWM2_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDeadBandDelayInput(EPWM2_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDelayCount(EPWM2_BASE, EPWM2_RISE_DB);
EPWM_setRisingEdgeDelayCount(EPWM2_BASE, EPWM2_FALL_DB);
//HRPWM Module�̐ݒ�
//�V���h�E���W�X�^����A�N�e�B�u���W�X�^��TBCTR=0���[�h
HRPWM_setCounterCompareShadowLoadEvent(EPWM2_BASE, HRPWM_CHANNEL_A,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setCounterCompareShadowLoadEvent(EPWM2_BASE, HRPWM_CHANNEL_B,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setMEPEdgeSelect(EPWM2_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM2_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_PHASE_CTRL);
HRPWM_setMEPEdgeSelect(EPWM2_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM2_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_PHASE_CTRL);
HRPWM_enableAutoConversion(EPWM2_BASE);
//�^�C�}�[�X�^�[�g
EDIS;
// EPWM3�̏�����
// ����DCDC�R���o�[�^�pPWM�o�� �t�F�[�Y�V�t�gPWM
// ���� �Ȃ�
// �߂�l �Ȃ�
void InitEPwm3(void){
EALLOW;
//�ݒ�l�l���f����
EPWM_setPeriodLoadMode(EPWM3_BASE, EPWM_PERIOD_DIRECT_LOAD);
EPWM_setTimeBaseCounterMode(EPWM3_BASE, EPWM_COUNTER_MODE_UP);
//PWM�����̐ݒ�
EPWM_setTimeBasePeriod(EPWM3_BASE, EPWM3_PERIOD - 1);
EPWM_enablePhaseShiftLoad(EPWM3_BASE);
EPWM_setPhaseShift(EPWM3_BASE, 0);
//EPwm2Regs.TBPHS.all = (unsigned long)(65536.0 * ((float)EPwm2Regs.TBPRD * 0.25));
//�J�E���^�l�̃N���A
EPWM_setTimeBaseCounter(EPWM3_BASE, 0);
EPWM_setSyncInPulseSource(EPWM3_BASE, EPWM_SYNC_IN_PULSE_SRC_SYNCOUT_EPWM1);
EPWM_setClockPrescaler(EPWM3_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
EPwm3Regs.CMPA.all = (unsigned long)(65536.0 * ((float)EPwm3Regs.TBPRD * EPWM3_PULSEWIDTH_A));
EPwm3Regs.CMPB.all = (unsigned long)(65536.0 * ((float)EPwm3Regs.TBPRD * EPWM3_PULSEWIDTH_B));
EPWM_setCounterCompareShadowLoadMode(EPWM3_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setCounterCompareShadowLoadMode(EPWM3_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setActionQualifierAction(EPWM3_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM3_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(EPWM3_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM3_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setDeadBandDelayMode(EPWM3_BASE, EPWM_DB_RED, true); //�����オ��G�b�W�ɒx����t������
EPWM_setDeadBandDelayMode(EPWM3_BASE, EPWM_DB_FED, true); //����������G�b�W�ɒx����t������
EPWM_setDeadBandDelayPolarity(EPWM3_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH); //�]
EPWM_setDeadBandDelayPolarity(EPWM3_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW); //���]
EPWM_setRisingEdgeDeadBandDelayInput(EPWM3_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDeadBandDelayInput(EPWM3_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDelayCount(EPWM3_BASE, EPWM3_RISE_DB);
EPWM_setRisingEdgeDelayCount(EPWM3_BASE, EPWM3_FALL_DB);
//HRPWM Module�̐ݒ�
HRPWM_setCounterCompareShadowLoadEvent(EPWM3_BASE, HRPWM_CHANNEL_A,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setCounterCompareShadowLoadEvent(EPWM3_BASE, HRPWM_CHANNEL_B,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setMEPEdgeSelect(EPWM3_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM3_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_PHASE_CTRL);
HRPWM_setMEPEdgeSelect(EPWM3_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM3_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_PHASE_CTRL);
HRPWM_enableAutoConversion(EPWM3_BASE);
//�^�C�}�[�X�^�[�g
EDIS;
// EPWM4�̏�����
// ���� �Ȃ�
// �߂�l �Ȃ�
void InitEPwm4(void){
EALLOW;
//�ݒ�l�l���f����
EPWM_setPeriodLoadMode(EPWM4_BASE, EPWM_PERIOD_DIRECT_LOAD);
EPWM_setTimeBaseCounterMode(EPWM4_BASE, EPWM_COUNTER_MODE_UP);
//PWM�����̐ݒ�
EPWM_setTimeBasePeriod(EPWM4_BASE, EPWM4_PERIOD - 1);
EPWM_enablePhaseShiftLoad(EPWM4_BASE);
EPWM_setPhaseShift(EPWM4_BASE, 0);
//�J�E���^�l�̃N���A
EPWM_setTimeBaseCounter(EPWM4_BASE, 0);
EPWM_setSyncInPulseSource(EPWM4_BASE, EPWM_SYNC_IN_PULSE_SRC_SYNCOUT_EPWM1);
EPWM_setClockPrescaler(EPWM4_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
EPwm4Regs.CMPA.all = (unsigned long)(65536.0 * ((float)EPwm4Regs.TBPRD * EPWM4_PULSEWIDTH_A));
EPwm4Regs.CMPB.all = (unsigned long)(65536.0 * ((float)EPwm4Regs.TBPRD * EPWM4_PULSEWIDTH_B));
EPWM_setCounterCompareShadowLoadMode(EPWM4_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setCounterCompareShadowLoadMode(EPWM4_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
EPWM_setActionQualifierAction(EPWM4_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM4_BASE,EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setActionQualifierAction(EPWM4_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_setActionQualifierAction(EPWM4_BASE,EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_setDeadBandDelayMode(EPWM4_BASE, EPWM_DB_RED, true); //�����オ��G�b�W�ɒx����t������
EPWM_setDeadBandDelayMode(EPWM4_BASE, EPWM_DB_FED, true); //����������G�b�W�ɒx����t������
EPWM_setDeadBandDelayPolarity(EPWM4_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH); //�]
EPWM_setDeadBandDelayPolarity(EPWM4_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW); //���]
EPWM_setRisingEdgeDeadBandDelayInput(EPWM4_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDeadBandDelayInput(EPWM4_BASE, EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDelayCount(EPWM4_BASE, EPWM4_RISE_DB);
EPWM_setRisingEdgeDelayCount(EPWM4_BASE, EPWM4_FALL_DB);
//HRPWM Module�̐ݒ�
HRPWM_setCounterCompareShadowLoadEvent(EPWM4_BASE, HRPWM_CHANNEL_A,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setCounterCompareShadowLoadEvent(EPWM4_BASE, HRPWM_CHANNEL_B,HRPWM_LOAD_ON_CNTR_ZERO);
HRPWM_setMEPEdgeSelect(EPWM4_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM4_BASE, HRPWM_CHANNEL_A, HRPWM_MEP_PHASE_CTRL);
HRPWM_setMEPEdgeSelect(EPWM4_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_CTRL_RISING_AND_FALLING_EDGE);
HRPWM_setMEPControlMode(EPWM4_BASE, HRPWM_CHANNEL_B, HRPWM_MEP_PHASE_CTRL);
HRPWM_enableAutoConversion(EPWM4_BASE);
//�^�C�}�[�X�^�[�g
EDIS;
// CLA��������x����p
void InitEPwm12(void){
EALLOW;
//Setup TBCLK
EPWM_setPeriodLoadMode(EPWM12_BASE, EPWM_PERIOD_DIRECT_LOAD);
//PWM�����̐ݒ�
EPWM_setTimeBasePeriod(EPWM12_BASE, 0xffff);
EPWM_setPhaseShift(EPWM12_BASE, 0);
//�J�E���^�l�̃N���A
EPWM_setTimeBaseCounter(EPWM12_BASE, 0);
EPWM_setTimeBaseCounterMode(EPWM12_BASE, EPWM_COUNTER_MODE_UP);
EPWM_enablePhaseShiftLoad(EPWM12_BASE);
EPWM_setSyncInPulseSource(EPWM12_BASE, EPWM_SYNC_IN_PULSE_SRC_SYNCOUT_EPWM1);
EPWM_setClockPrescaler(EPWM12_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
//�^�C�}�[�X�^�[�g
EDIS;
Miyazaki
