I am working with LAUNCHXL-F28379D. I have imported i2c_eeprom example code from C2000Ware and run it with the ready available module with EEPROM AT24C32 and RTC DS1307 present on the same module. The code is not working. I have tried to observe the SDA and SCL on oscilloscope but nothing has been observed. I am also tried the same with pull up resistors but again nothing has been observed. I have not made any changes in the example code. I am not getting why this is happened. After doing this I should at least get SCL signal on oscilloscope but this is not happening. Can you please tell me what is the actual problem and what should I do.
Thanks in advance!
Nisha
