Other Parts Discussed in Thread: C2000WARE, TMDSCNCD28069ISO
Bilal,
This generation of controlCARDs do not have the emulation(XDS100) built into them, and therefore rely on the XDS100 on the docking station or an external JTAG plugged into the 14-pin header.
Unfortunately the on-board JTAG is NOT isolated, so there likely will be issues with connecting the grounds across the controlled system and the PC.
Your best option would be to buy an external emulator like https://www.ti.com/tool/TMDSEMU110-U and then buy an isolator like https://www.blackhawk-dsp.com/products/jtag-isolation/iso14-pin
In some of the newer control CARDs we have the JTAG emulator built on the control CARD with isolation, you could look at this if you want to try and create the circuit yourself. A good example in C2000Ware install dir is C:\ti\c2000\C2000Ware_1_00_06_00\boards\controlCARDs\TMDSCNCD28069ISO
Let me know if you have further questions.
Matthew
