Hi, I have been using this code which gives me memory size error. I have run bigger codes in CCS but this one does not Build. I have changed at the optimization and size settings (setting attached) but they dont help either. Can you please suggest what should be done to make it work?
Thank you. I am attaching the code, screenshot of error and screenshot of optimization and size settings.
//########################################################################### // // FILE: control_cpu01.c // // TITLE: Inverter Control (SVPWM) // //! //! //! //########################################################################### // // Included Files #define MATH_TYPE FLOAT_MATH //IQ_MATH #include "IQmathLib.h" #include <math.h> #include "F28x_Project.h" #include "settings.h" #include "Solar_F.h" // Function Prototypes void InitEPwm(void); void ConfigureADC(void); __interrupt void epwm1_isr(void); __interrupt void adca1_isr(void); Uint16 usRunState; Uint16 usFaultFlag; Uint16 usResumePWM; Uint16 usPwmPeriod; Uint16 EPwm1_DB; Uint16 EPwm2_DB; Uint16 EPwm3_DB; Uint16 usPhase; Uint16 usPwm2Phase; Uint16 usPwm3Phase; Uint16 EPwm1_CMP; Uint16 EPwm2_CMP; Uint16 EPwm3_CMP; float32 fDutyCycle; float32 fDutyCycle1; float32 fDutyCycle2; float32 fDutyCycle3; float32 fTdb; float32 fTdb2; float32 fTdb3; Uint16 TestPwm; float32 fVdcRef; float32 fVinFlt; float32 fVdcPeak; float32 fUma; float32 fUmb; float32 fUmc; float32 fUmz; float32 fUmax; float32 fUmin; float32 fUmaxAbs; float32 fUminAbs; float32 fUmodA; float32 fUmodB; float32 fUmodC; float32 fUmodAlpha; float32 fUmodBeta; Uint16 usCmpValA; Uint16 usCmpValB; Uint16 usCmpValC; float32 fMI240; // ADC values float32 fVa; float32 fVb; float32 fVc; float32 fVab; float32 fVbc; float32 fVca; float32 fVpert; float32 fVout; float32 fVoutFlt; float32 fIdc; float32 fIindA; float32 fIindB; float32 fIindC; float32 fIa; float32 fIb; float32 fIc; float32 fIaNorm; float32 fIbNorm; float32 fIcNorm; float32 fIdcFlt; float32 fWTLpfIind; float32 fIindAFlt; float32 fIindBFlt; float32 fIindCFlt; float32 fCurrentFaultDc; float32 fCurrentFaultA; float32 fCurrentFaultB; float32 fCurrentFaultC; float32 fOver_Current; float32 fOver_Voltage; float32 fVoutFault; float32 fIindFlt; float32 fIrefMag; float32 fIrefLimit; float32 fIset; float32 fSlope; float32 fVerr; float32 fKp2; float32 fKi2; float32 fInt2; float32 fCurrentRef; float32 fIerrA; float32 fIerrB; float32 fIerrC; float32 fIntA; float32 fIntB; float32 fIntC; float32 fCurrCtrlA; float32 fCurrCtrlB; float32 fCurrCtrlC; float32 fIref; float32 fIerr; float32 fInt; float32 fIerr; float32 fCurrCtrl; float32 fSineA; float32 fSineB; float32 fSineC; float32 fSineAB; float32 fSineBC; float32 fSineCA; float32 fThetaA; float32 fThetaB; float32 fThetaC; float32 fThetaAB; float32 fThetaBC; float32 fThetaCA; float32 fPhaseComp; float32 fVaAbs; float32 fVbAbs; float32 fVcAbs; float32 fVabAbs; float32 fVbcAbs; float32 fVcaAbs; float32 fVdc; float32 fScale1; float32 fScale2; float32 fScale3; float32 fScale4; float32 fOffset1; float32 fOffset2; float32 fOffset3; float32 fOffset4; float32 fgainVo; float32 foffsetVo; float32 fgainIdc; float32 foffsetIdc; float32 fgainIindC; float32 foffsetIindC; float32 fgainIindB; float32 foffsetIindB; float32 fgainIindA; float32 foffsetIindA; float32 fIaOffset; float32 fIaOffset2; float32 fIagain1; float32 fIagain2; float32 fIbOffset; float32 fIbOffset2; float32 fIbgain1; float32 fIbgain2; float32 fIcOffset; float32 fIcOffset2; float32 fIcgain1; float32 fIcgain2; float32 fNormalize; float32 fDBCompThres; float32 fDBCompCoeff; float32 fDBCompA; float32 fDBCompB; float32 fDBCompC; float32 fVmagSq; float32 fVmag; float32 fVmagFlt; float32 fVmagFltWt; float32 fIin_ref1; float32 fIin_ref2; float32 fIslope; /*float32 VdTesting; float32 VqTesting;*/ float32 Feedback_vd; float32 Feedback_vq; float32 fid_CurrentRef; float32 fid_ref; float32 fIerr1; float32 fInt1; float32 fCurrCtrl1; float32 fiq_CurrentRef; float32 fiq_ref; float32 fIerr2; float32 fInt2; float32 fCurrCtrl2; float32 fKp; float32 fKi; float32 Min; float32 Max; float32 A; float32 B; float32 C; float32 Vlink_ref; /* float32 un; float32 un_1; float32 un_2; float32 en; float32 en_1; float32 en_2; float32 b2; float32 b1; float32 b0; float32 a2; float32 a1; */ // Variables for viewing signals in CCS graph #define RESULTS_BUFFER_SIZE 128 int16 Adc1[RESULTS_BUFFER_SIZE]; int16 Adc2[RESULTS_BUFFER_SIZE]; int16 Adc3[RESULTS_BUFFER_SIZE]; int16 Adc4[RESULTS_BUFFER_SIZE]; Uint16 resultsIndex; Uint16 saveIndex; volatile Uint16 bufferFull; Uint16 usStartSaveData; Uint16 samplePace; // **************************************************************************** // Variables for MACROS // **************************************************************************** float32 T = 1.0/PWM_FREQUENCY; // Samping period (sec), see parameter.h _iq VdTesting = _IQ(0.93), // Vd reference (pu) VqTesting = _IQ(0.0), // Vq reference (pu) IdRef = _IQ(0.0), // Id reference (pu) IqRef = _IQ(0.0), // Iq reference (pu) SpeedRef = _IQ(1.0), // For Closed Loop tests lsw1Speed = _IQ(0.02); // initial force rotation speed in search of QEP index pulse // Instance a few transform objects (ICLARKE is added into SVGEN module) CLARKE clarke1 = CLARKE_DEFAULTS; ICLARKE_M iclarke1 = ICLARKE_M_DEFAULTS; PARK_M park1 = PARK_M_DEFAULTS; IPARK_M ipark1 = IPARK_M_DEFAULTS; PI_CONTROLLER pi_id = PI_CONTROLLER_DEFAULTS; PI_CONTROLLER pi_iq = PI_CONTROLLER_DEFAULTS; //PHASEVOLTAGE volt1 = PHASEVOLTAGE_DEFAULTS; // Instance a Space Vector PWM modulator. This modulator generates a, b and c // phases based on the d and q stationery reference frame inputs SVGENDPWM_240 svgen1 = SVGENDPWM_240_DEFAULTS; //SVGEN svgen1 = SVGEN_DEFAULTS; // Instance a ramp controller to smoothly ramp the frequency RMPCNTL rc1 = RMPCNTL_DEFAULTS; // Instance a ramp(sawtooth) generator to simulate an Angle RAMPGEN rg1 = RAMPGEN_DEFAULTS; // **************************************************************************** // Variables for Datalog module // **************************************************************************** //float DBUFF_4CH1[100], // DBUFF_4CH2[100], // DBUFF_4CH3[50], // DBUFF_4CH4[50], // DlogCh1, // DlogCh2, // DlogCh3, // DlogCh4; void Shutdown(void); // // Main // void main(void) { InitSysCtrl(); CpuSysRegs.PCLKCR2.bit.EPWM1 = 1; CpuSysRegs.PCLKCR2.bit.EPWM2 = 1; CpuSysRegs.PCLKCR2.bit.EPWM3 = 1; CpuSysRegs.PCLKCR2.bit.EPWM7 = 1; CpuSysRegs.PCLKCR2.bit.EPWM8 = 1; CpuSysRegs.PCLKCR2.bit.EPWM9 = 1; InitEPwm1Gpio(); InitEPwm2Gpio(); InitEPwm3Gpio(); InitEPwm7Gpio(); InitEPwm8Gpio(); InitEPwm9Gpio(); EALLOW; GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 0; // GPIO GpioCtrlRegs.GPADIR.bit.GPIO20 = 1; // output EDIS; DINT; InitPieCtrl(); IER = 0x0000; IFR = 0x0000; InitPieVectTable(); // // Interrupts that are used in this example are re-mapped to // ISR functions found within this file. // EALLOW; // This is needed to write to EALLOW protected registers PieVectTable.EPWM1_INT = &epwm1_isr; // PieCtrlRegs.PIEIER3.bit.INTx7 = 1; PieVectTable.ADCA1_INT = &adca1_isr; //function for ADCA interrupt 1 EDIS; // This is needed to disable write to EALLOW protected registers // Configure the ADC and power it up // Setup the ADC for ePWM triggered conversions // ************ SHOULD BE DONE BEFORE PWM CONFIG ************** ConfigureADC(); // // Step 4. Initialize the Device Peripherals: // EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC =0; EDIS; InitEPwm(); EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC =1; EDIS; // // Step 5. User specific code // Initialize variables // Initialize variables usRunState = 0; usResumePWM = 0; fOver_Current = 40.0; fOver_Voltage = 950.0; fid_ref = 5; fiq_ref = 0; fKp = 0.06;//0.1; fKi = 20; //10; /* en_2 = 0; en_1 = 0; un_2 = 0; un_1 = 0; en = 0; un = 0; b2 = -0.002930185534789; b1 = 0.000503233879362; b0 = 0.003433419414151; a2 = 0.110340072507284; a1 = 0.889659927492716;*/ fVinFlt = 50; fVdcPeak = 100; // fVdcRef = 100; fMI240 = 1.0; fVmagFltWt = TWO_PI * 5000 * SAMPLING_PERIOD; // 20 kHz LPF fPhaseComp = 0.0; fDBCompCoeff = 1.0; fDBCompThres = 5.0; fDBCompA = 1.0; fDBCompB = 1.0; fDBCompC = 1.0; /* // Init PI module for ID loop pi_id.Kp = _IQ(0.2);//_IQ(3.0); pi_id.Ki = _IQ(10.0);//_IQ(T/0.04);//0.0075); pi_id.Umax = _IQ(0.5); pi_id.Umin = _IQ(-0.5); // Init PI module for IQ loop pi_iq.Kp = _IQ(0.2);//_IQ(4.0); pi_iq.Ki = _IQ(10.0);//_IQ(T/0.04);//_IQ(0.015); pi_iq.Umax = _IQ(0.8); pi_iq.Umin = _IQ(-0.8);*/ rg1.StepAngleMax = _IQ(GRID_FREQ * SAMPLING_PERIOD); // SPLL_3ph_SRF_F_init(GRID_FREQ, SAMPLING_PERIOD, &spll1); // Kp = 166.6; // Ki = 27755.55; // T = 1/10e3; // B0 = (2*Kp + Ki*T)/2 // B1 = -(2*Kp - Ki*T)/2 fNormalize = 0.1; // **************************************************** // Initialize DATALOG module // **************************************************** // DLOG_4CH_F_init(&dlog_4ch1); // dlog_4ch1.input_ptr1 = &DlogCh1; //data value // dlog_4ch1.input_ptr2 = &DlogCh2; // dlog_4ch1.input_ptr3 = &DlogCh3; // dlog_4ch1.input_ptr4 = &DlogCh4; // dlog_4ch1.output_ptr1 = &DBUFF_4CH1[0]; // dlog_4ch1.output_ptr2 = &DBUFF_4CH2[0]; // dlog_4ch1.output_ptr3 = &DBUFF_4CH3[0]; // dlog_4ch1.output_ptr4 = &DBUFF_4CH4[0]; // dlog_4ch1.size = 200; // dlog_4ch1.pre_scalar = 5; // dlog_4ch1.trig_value = 0.01; // dlog_4ch1.status = 2; for(resultsIndex = 0; resultsIndex < RESULTS_BUFFER_SIZE; resultsIndex++) { Adc1[resultsIndex] = 0; Adc2[resultsIndex] = 0; Adc3[resultsIndex] = 0; Adc4[resultsIndex] = 0; } resultsIndex = 0; saveIndex = 0; bufferFull = 0; samplePace = 4; // Rounding( F_sample / F_fundamental / BufferSize ) usStartSaveData = 0; fgainVo = 345.423; foffsetVo = 0; fgainIdc = 103.1; fgainIindC = 108.7; fgainIindB = 142.5; fgainIindA = 142.5; foffsetIdc = 1.507; foffsetIindC = 1.507; foffsetIindB = 1.506; foffsetIindA = 1.506; fIaOffset = 2.222; fIagain1 = -2; fIagain2 = 15.5; fIaOffset2 = -0.0118; fIbOffset = 2.222; fIbgain1 = -2; fIbgain2 = 15.5; fIbOffset2 = 0; fIcOffset = 2.222; fIcgain1 = -2; fIcgain2 = 15.5; fIcOffset2 = -0.0118; // // Enable CPU INT3 which is connected to EPWM1-3 INT: // // IER |= M_INT3; IER |= M_INT1; // for ADC isr EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM // // Enable PIE interrupt // // PieCtrlRegs.PIEIER3.bit.INTx1 = 1; // PWM PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // ADC isr // conv_duty(); for(;;) { asm (" NOP"); } } // // epwm1_isr - EPWM1 ISR // __interrupt void epwm1_isr(void) { // GpioDataRegs.GPASET.bit.GPIO8 = 1; // Pin 57 asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); asm (" NOP"); // EPwm2Regs.TBPHS.bit.TBPHS = usPwm2Phase; // EPwm3Regs.TBPHS.bit.TBPHS = usPwm3Phase; // EPwm1Regs.TBPRD = usPwmPeriod; // EPwm2Regs.TBPRD = usPwmPeriod; // EPwm3Regs.TBPRD = usPwmPeriod; // GpioDataRegs.GPACLEAR.bit.GPIO8 = 1; // Clear INT flag for this timer EPwm1Regs.ETCLR.bit.INT = 1; // Acknowledge this interrupt to receive more interrupts from group 3 PieCtrlRegs.PIEACK.all = PIEACK_GROUP3; } // // adca1_isr - Read ADC Buffer in ISR // __interrupt void adca1_isr(void) { GpioDataRegs.GPASET.bit.GPIO20 = 1; //********************************************** // Get ADC Results //********************************************** // fVab = fScale2 * (((float32)AdcaResultRegs.ADCRESULT0) * 0.0007326007326) + fOffset2; // fVa = fScale2 * (((float32)AdcaResultRegs.ADCRESULT6) * 0.0007326007326) + fOffset2; // fVb = fScale3 * (((float32)AdcaResultRegs.ADCRESULT7) * 0.0007326007326) + fOffset3; // fVc = fScale4 * (((float32)AdcaResultRegs.ADCRESULT3) * 0.0007326007326 + fOffset4); // fVc = 0.0 - fVa - fVb; // New PCB fVout = ((float32)AdcaResultRegs.ADCRESULT0 * 0.0007326007326) * fgainVo + foffsetVo; fIdc = ((float32)AdcaResultRegs.ADCRESULT1 * 0.0007326007326 - foffsetIdc) * (-1*fgainIdc); //108.7 1.504 fIindC = ((float32)AdcaResultRegs.ADCRESULT2 * 0.0007326007326 - foffsetIindC) * fgainIindC; //95.54 fIindB = ((float32)AdcaResultRegs.ADCRESULT3 * 0.0007326007326 - foffsetIindB) * fgainIindB; //108.7 fIindA = ((float32)AdcaResultRegs.ADCRESULT4 * 0.0007326007326 - foffsetIindA) * fgainIindA; //108.7 fVpert = ((float32)AdcaResultRegs.ADCRESULT6 * 0.0007326007326); //ADCIN14 goes in Result6 // fVpert = (1.905-(float32)AdcaResultRegs.ADCRESULT6 * 0.0007326007326) * 3.703703; //ADCIN14 goes in Result6 fIa = ((((float32)AdcbResultRegs.ADCRESULT0 * 0.0007326007326 - fIaOffset ) - fIaOffset2) * fIagain1) * fIagain2; fIb = ((((float32)AdcbResultRegs.ADCRESULT1 * 0.0007326007326 - fIbOffset ) - fIbOffset2) * fIbgain1) * fIbgain2; fIc = ((((float32)AdcbResultRegs.ADCRESULT2 * 0.0007326007326 - fIcOffset ) - fIcOffset2) * fIcgain1) * fIcgain2; // fIc = (((float32)AdcbResultRegs.ADCRESULT2 * 0.0007326007326 - fIcOffset ) * fIcgain1) * fIcgain2; EMATH_OneOrderLpf(fIa, fIaNorm, fVmagFltWt); EMATH_OneOrderLpf(fIb, fIbNorm, fVmagFltWt); EMATH_OneOrderLpf(fIc, fIcNorm, fVmagFltWt); //For CSVPWM & DPWM1 // For open loop testing // ------------------------------------------------------------------------------ // Connect inputs of the RMP module and call the ramp control macro // ------------------------------------------------------------------------------ rc1.TargetValue = SpeedRef; RC_MACRO(rc1) // ------------------------------------------------------------------------------ // Connect inputs of the RAMP GEN module and call the ramp generator macro // ------------------------------------------------------------------------------ rg1.Freq = rc1.SetpointValue; RG_MACRO(rg1) // Calculate Duty for Boost converter fThetaA = rg1.Out * TWO_PI; fThetaB = fThetaA + FOUR_PI_DIV3; if( fThetaB > TWO_PI ) { fThetaB = fThetaB - TWO_PI; } fThetaC = fThetaA + TWO_PI_DIV3; if( fThetaC > TWO_PI ) { fThetaC = fThetaC - TWO_PI; } fSineA = sin(fThetaA); fSineB = sin(fThetaB); fSineC = sin(fThetaC); fSineAB = (fSineA - fSineB); fSineBC = (fSineB - fSineC); fSineCA = (fSineC - fSineA); fVabAbs = ABS(fSineAB); fVbcAbs = ABS(fSineBC); fVcaAbs = ABS(fSineCA); fVdc = MAX_THREE(fVabAbs, fVbcAbs, fVcaAbs); UP_DOWN_LIMIT(fVdc, 1.733, 0.1); fMI240 = 1.7320508 / fVdc; UP_DOWN_LIMIT(fMI240, 1.154, 0.5); //Connecting phase currents with Clark Macro clarke1.As = fIa; //fIaNorm; // Phase A curr. clarke1.Bs = fIb; //fIbNorm; // Phase B curr. CLARKE_MACRO(clarke1) // ------------------------------------------------------------------------------ // Connect inputs of the PARK module and call the park trans. macro // ------------------------------------------------------------------------------ park1.Alpha = clarke1.Alpha; park1.Beta = clarke1.Beta; park1.Angle = rg1.Out; park1.Sine = __sinpuf32(park1.Angle); park1.Cosine = __cospuf32(park1.Angle); PARK_M_MACRO(park1) //TI - PI Control pi_id.Ref = fid_ref; pi_id.Fbk = park1.Ds; PI_MACRO(pi_id); pi_iq.Ref = fiq_ref; pi_iq.Fbk = park1.Qs; PI_MACRO(pi_iq); //Close Loop Control of Inverter Side fid_CurrentRef = fid_ref; fIerr1 = fid_CurrentRef - park1.Ds; fInt1 += fIerr1 * fKi * CONTROL_PERIOD; UP_DOWN_LIMIT(fInt1, 1, -1); fCurrCtrl1 = fKp * fIerr1 + fInt1; UP_DOWN_LIMIT(fCurrCtrl1, 1.0, 0.1); Feedback_vd = fCurrCtrl1; fiq_CurrentRef = fiq_ref; fIerr2 = fiq_CurrentRef - park1.Qs; fInt2 += fIerr2 * fKi * CONTROL_PERIOD; UP_DOWN_LIMIT(fInt2, 1, -1); fCurrCtrl2 = fKp * fIerr2 + fInt2; UP_DOWN_LIMIT(fCurrCtrl2, 0.0, 0.0); Feedback_vq = fCurrCtrl2; ipark1.Ds = Feedback_vd; //pi_id.Out; ipark1.Qs = Feedback_vq; //pi_iq.Out; ipark1.SineA=sin(fThetaA); ipark1.SineB=sin(fThetaB); IPARK_M_MACRO(ipark1) iclarke1.Valpha = ipark1.Alpha; iclarke1.Vbeta = ipark1.Beta; ICLARKE_M_MACRO(iclarke1) A = SQRT_THREE_RECIP * iclarke1.As; B = SQRT_THREE_RECIP * iclarke1.Bs; C = SQRT_THREE_RECIP * iclarke1.Cs; Max = MAX_THREE(A,B,C); Min = MIN_THREE(A,B,C); Vlink_ref = (Max - Min) * fVdcPeak; UP_DOWN_LIMIT(Vlink_ref, 1000.0, 50.0); // ------------------------------------------------------------------------------ // Connect inputs of the SVGEN module and call the space-vector gen. macro // ------------------------------------------------------------------------------ // fUmodAlpha = fSineA; // fUmodBeta = (fSineA + 2.0 * fSineB) * 0.57735026918963; // svgen1.Ualpha = fUmodAlpha * Feedback_vd; // svgen1.Ubeta = fUmodBeta * Feedback_vd; svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; /* // For CSVPWM svgen1.Ualpha = ipark1.Alpha; svgen1.Ubeta = ipark1.Beta; */ /* // DPWM 1 (clamp at peak) //While using DPWM1, use Vdtesting = 0.93*1.15 fUma = ipark1.Alpha; fUmb = 0.5*( 1.732050807 * ipark1.Beta - ipark1.Alpha); fUmc = 0.5*(-1.732050807 * ipark1.Beta - ipark1.Alpha); fUmax = MAX_THREE(fUma, fUmb, fUmc); fUmin = MIN_THREE(fUma, fUmb, fUmc); fUmaxAbs = ABS(fUmax); fUminAbs = ABS(fUmin); if( fUmaxAbs > fUminAbs ) { fUmz = 1.0 - fUmax; } else { fUmz = -1.0 - fUmin; } fUmodA = fUma + fUmz; fUmodB = fUmb + fUmz; fUmodC = fUmc + fUmz; */ SVGENDPWM_240_MACRO(svgen1) // SVGENDQ_MACRO(svgen1) // For CSVPWM //SVGENDPWM_MACRO(svgen1) // ------------------------------------------------------------------------------ // Computed Duty and Write to CMPA register //------------------------------------------------------------------------------ // if(TestPwm == 1) // { // EPwm11Regs.CMPA.bit.CMPA = INV_PWM_TBPRD * fDutyCycle; // EPwm12Regs.CMPA.bit.CMPA = INV_PWM_TBPRD * fDutyCycle; // EPwm9Regs.CMPA.bit.CMPA = INV_PWM_TBPRD * fDutyCycle; // // } // /* // For CSVPWM fUmodA = svgen1.Ta; fUmodB = svgen1.Tb; fUmodC = svgen1.Tc;*/ // 240CPWM fUmodA = -svgen1.Ta; fUmodB = -svgen1.Tb; fUmodC = -svgen1.Tc; // if( fVaAbs > fDBCompThres ) // { // fDBCompA = fDBCompCoeff; // } // // if( fVbAbs > fDBCompThres ) // { // fDBCompB = fDBCompCoeff; // } // // if( fVcAbs > fDBCompThres ) // { // fDBCompC = fDBCompCoeff; // } // // fUmodA = fUmodA * fDBCompA; // fUmodB = fUmodB * fDBCompB; // fUmodC = fUmodC * fDBCompC; usCmpValA = (INV_PWM_HALF_TBPRD * fUmodA) + INV_PWM_HALF_TBPRD; usCmpValB = (INV_PWM_HALF_TBPRD * fUmodB) + INV_PWM_HALF_TBPRD; usCmpValC = (INV_PWM_HALF_TBPRD * fUmodC) + INV_PWM_HALF_TBPRD; UP_DOWN_LIMIT(usCmpValA, INV_PWM_TBPRD, 0); UP_DOWN_LIMIT(usCmpValB, INV_PWM_TBPRD, 0); UP_DOWN_LIMIT(usCmpValC, INV_PWM_TBPRD, 0); // EPwm11Regs.CMPA.bit.CMPA = usCmpValA; //phase A // EPwm12Regs.CMPA.bit.CMPA = usCmpValB; //phase B EPwm7Regs.CMPA.bit.CMPA = usCmpValA; //phase A EPwm8Regs.CMPA.bit.CMPA = usCmpValB; //phase B EPwm9Regs.CMPA.bit.CMPA = usCmpValC; //phase C if( (ACTIVE == usRunState) && (NORMAL == usFaultFlag) ) { if( usResumePWM ) { // only need to change here for enabling/disabling phases EALLOW; GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1; // Phase A Main GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1; GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1; // Phase B Main GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 1; GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 1; // Phase C Main GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 1; GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 1; // Phase C Aux GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 1; GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 1; // Phase B Aux GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 1; GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 1; // Phase A Aux GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 1; EDIS; usResumePWM = 0; } if( (fOver_Current <= ABS(fIdc) ) || (fOver_Current <= ABS(fIindA)) || (fOver_Current <= ABS(fIindB)) || (fOver_Current <= ABS(fIindC)) ) { Shutdown(); fCurrentFaultDc = fIdc; fCurrentFaultA = fIindA; fCurrentFaultB = fIindB; fCurrentFaultC = fIindC; usFaultFlag = OVER_CURRENT; } if( fOver_Voltage <= ABS(fVout) ) { Shutdown(); fVoutFault = fVout; usFaultFlag = OVER_VOLTAGE; } // For CSVPWM // fDutyCycle = fVinFlt / fVdcRef; // for top switch // fDutyCycle = fDutyCycle1 + fVpert; // For 240CPWM // fVdcRef = fVdc * SQRT_THREE_RECIP * fVdcPeak; // UP_DOWN_LIMIT(fVdcRef, 1000.0, 50.0); fDutyCycle = fVinFlt / Vlink_ref; // for top switch UP_DOWN_LIMIT(fDutyCycle, 0.8, 0.3); fDutyCycle2 = fDutyCycle; fDutyCycle3 = fDutyCycle; // For Ramp Change in Reference /* if (fIin_ref2 > fIin_ref1) { fIin_ref1 += fIslope; } else if (fIin_ref2 < fIin_ref1) { fIin_ref1 -= fIslope; } else { fIin_ref1 = fIin_ref2; } fCurrentRef = fIin_ref1; //For Ramp*/ //Close Loop Control for Iin /* // PI CONTROL Current Control fCurrentRef = fIref; fIerr = fCurrentRef - fIdc; fInt += fIerr * fKi * CONTROL_PERIOD; UP_DOWN_LIMIT(fInt, 0.8, -0.8); fCurrCtrl = fKp * fIerr + fInt; UP_DOWN_LIMIT(fCurrCtrl, 0.8, 0.2); fDutyCycle = 1.0 - fCurrCtrl;*/ //Function call to k factor control /* fCurrentRef = fIref; fIerr = fCurrentRef - fIdc; fCurrCtrl = Iin_control(fIerr); UP_DOWN_LIMIT(fCurrCtrl, 0.8, 0.2); fDutyCycle = 1.0 - fCurrCtrl; */ UP_DOWN_LIMIT(fDutyCycle, 0.8, 0.2); fDutyCycle2 = fDutyCycle; fDutyCycle3 = fDutyCycle; EPwm1_CMP = (Uint16)(fDutyCycle * (0.5 * (float32)DC_DC_CONTROL_TBPRD)); EPwm2_CMP = (Uint16)(fDutyCycle2 * (0.5 * (float32)DC_DC_CONTROL_TBPRD)); EPwm3_CMP = (Uint16)(fDutyCycle3 * (0.5 * (float32)DC_DC_CONTROL_TBPRD)); EPwm1Regs.CMPA.bit.CMPA = EPwm1_CMP; // Phase A Main EPwm2Regs.CMPA.bit.CMPA = EPwm2_CMP; // Phase B Main EPwm3Regs.CMPA.bit.CMPA = EPwm3_CMP; // Phase C Main } else { Shutdown(); } // EPwm1_DB = (Uint16)(fTdb * 0.1); // EPwm11Regs.DBFED.bit.DBFED = EPwm1_DB; // EPwm12Regs.DBFED.bit.DBFED = EPwm1_DB; // EPwm9Regs.DBFED.bit.DBFED = EPwm1_DB; // // Connect inputs of the DATALOG module // DlogCh1 = svgen1.Ta; // DlogCh2 = svgen1.Tb; // DlogCh3 = svgen1.Tc; // DlogCh4 = DlogCh2 - DlogCh3; // // ------------------------------------------------------------------------------ // // Call the DATALOG update function. // // ------------------------------------------------------------------------------ // DLOG_4CH_F_FUNC(&dlog_4ch1); //********************************************** // View data in CCS graph //********************************************** if( usStartSaveData == 1 ) { saveIndex++; if( (bufferFull == 0) && (samplePace <= saveIndex) ) { Adc1[resultsIndex] = Vlink_ref *10.0; Adc2[resultsIndex] = Vlink_ref *10.0; Adc3[resultsIndex] = park1.Qs *100.0; Adc4[resultsIndex] = Vlink_ref *10.0; // Adc1[resultsIndex] = ipark1.Alpha *100.0; // Adc2[resultsIndex] = ipark1.Beta *100.0; // Adc3[resultsIndex] = svgen1.Ualpha *100.0; // Adc4[resultsIndex] = svgen1.Ubeta *100.0; resultsIndex++; saveIndex = 0; } if(RESULTS_BUFFER_SIZE <= resultsIndex) { resultsIndex = 0; bufferFull = 1; saveIndex = 0; usStartSaveData = 0; } } GpioDataRegs.GPACLEAR.bit.GPIO20 = 1; AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //clear INT1 flag PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; } // // InitEPwm - Initialize EPWMx configuration // void InitEPwm() { fTdb = 250.0; // ns fTdb2 = 250.0; // ns fTdb3 = 250.0; // ns EPwm1_DB = (Uint16)(fTdb * 0.1); EPwm2_DB = (Uint16)(fTdb2 * 0.1); EPwm3_DB = (Uint16)(fTdb3 * 0.1); fDutyCycle = 0.3; usPhase = (Uint16)(0.666666 * 0.5 * (float32)DC_DC_CONTROL_TBPRD); usPwm2Phase = usPhase; // Phase B Main usPwm3Phase = usPhase; // Phase C Main EPwm1Regs.TBPRD = (Uint16)(0.5 * (float32)DC_DC_CONTROL_TBPRD); // Set timer period EPwm1Regs.TBPHS.bit.TBPHS = 0x0000; // Phase is 0 EPwm1Regs.TBCTR = 0x0000; // Clear counter EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync Output Select: CTR = zero // EPwm1Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // EPwm1Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)CONTROL_TBPRD); EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm1Regs.AQCTLA.bit.CAD = AQ_SET; EPwm1Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm1Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm1Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm1Regs.DBRED.bit.DBRED = EPwm1_DB; EPwm1Regs.DBFED.bit.DBFED = EPwm1_DB; EPwm2Regs.TBPRD = (Uint16)(0.5 * (float32)DC_DC_CONTROL_TBPRD); // Set timer period EPwm2Regs.TBPHS.bit.TBPHS = usPwm2Phase; // Phase is 0 EPwm2Regs.TBCTR = 0x0000; // Clear counter EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading EPwm2Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Count down after the synchronization event EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // EPwm2Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // EPwm2Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)CONTROL_TBPRD); EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm2Regs.AQCTLA.bit.CAD = AQ_SET; EPwm2Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm2Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm2Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm2Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm2Regs.DBRED.bit.DBRED = EPwm2_DB; EPwm2Regs.DBFED.bit.DBFED = EPwm2_DB; EPwm3Regs.TBPRD = (Uint16)(0.5 * (float32)DC_DC_CONTROL_TBPRD); // Set timer period EPwm3Regs.TBPHS.bit.TBPHS = usPwm3Phase; // Phase is 0 EPwm3Regs.TBCTR = 0x0000; // Clear counter EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading EPwm3Regs.TBCTL.bit.PHSDIR = TB_UP; // Count down/up (0/1) after the synchronization event EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // EPwm3Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // EPwm3Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)CONTROL_TBPRD); EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm3Regs.AQCTLA.bit.CAD = AQ_SET; EPwm3Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm3Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm3Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm3Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm3Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm3Regs.DBRED.bit.DBRED = EPwm3_DB; EPwm3Regs.DBFED.bit.DBFED = EPwm3_DB; // // Interrupt setting // EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event // EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 1st event // EPwm1Regs.ETSEL.bit.INTEN = 1; // Enable INT // PWM 4 used as ADC ISR EPwm4Regs.TBPRD = INV_PWM_TBPRD; // Set timer period EPwm4Regs.TBPHS.bit.TBPHS = 0x0000; // Phase is 0 EPwm4Regs.TBCTR = 0x0000; // Clear counter EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm4Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm4Regs.TBCTL.bit.SYNCOSEL = 1; // Sync Output Select: CTR = zero EPwm4Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1; // EPwm11Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)INV_PWM_HALF_TBPRD); EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD; EPwm4Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm4Regs.AQCTLA.bit.CAD = AQ_SET; EPwm4Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm4Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm4Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm4Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm4Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm4Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm4Regs.DBRED.bit.DBRED = EPwm1_DB; EPwm4Regs.DBFED.bit.DBFED = EPwm1_DB; // ADC SOC EALLOW; EPwm4Regs.ETSEL.bit.SOCASEL = 1; // Select SOC on Zero EPwm4Regs.ETSEL.bit.SOCAEN = 1; //enable SOCA EPwm4Regs.ETPS.bit.SOCAPRD = ET_1ST; // Generate pulse on ___ event EDIS; /* EPwm4Regs.ETSEL.bit.SOCAEN = 1; // Enable ePWM4 SOCA pulse EPwm4Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO; // SOCA from ePWM4 Zero event EPwm4Regs.ETPS.bit.SOCAPRD = ET_1ST; // Trigger ePWM4 SOCA on every event EALLOW; PieVectTable.EPWM4_INT = &adca1_isr; // Map CNTL Interrupt PieCtrlRegs.PIEIER3.bit.INTx4 = 1; // PIE level enable, Grp3 / Int1, ePWM4 // EPwm4Regs.CMPB = 50; // ISR trigger point EPwm4Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // INT on CompareB-Up event EPwm4Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm4Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on every 1st event EDIS; IER |= M_INT3; // Enable CPU INT3 connected to EPWM1-6 INTs: EINT; // Enable Global interrupt INTM ERTM; */ // Enable Global realtime interrupt DBGM // PWM modules for 3-phase inverter // EPWM 7,8, 9 EPwm7Regs.TBPRD = INV_PWM_TBPRD; // Set timer period EPwm7Regs.TBPHS.bit.TBPHS = 0x0000; // Phase is 0 EPwm7Regs.TBCTR = 0x0000; // Clear counter EPwm7Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm7Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm7Regs.TBCTL.bit.SYNCOSEL = 1; // Sync Output Select: CTR = zero EPwm7Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm7Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm7Regs.TBCTL.bit.CLKDIV = TB_DIV1; // EPwm11Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)INV_PWM_HALF_TBPRD); EPwm7Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm7Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm7Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; EPwm7Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD; EPwm7Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm7Regs.AQCTLA.bit.CAD = AQ_SET; EPwm7Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm7Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm7Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm7Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm7Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm7Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm7Regs.DBRED.bit.DBRED = EPwm1_DB; EPwm7Regs.DBFED.bit.DBFED = EPwm1_DB; EPwm8Regs.TBPRD = INV_PWM_TBPRD; // Set timer period EPwm8Regs.TBPHS.bit.TBPHS = 0x0000; // Phase is 0 EPwm8Regs.TBCTR = 0x0000; // Clear counter EPwm8Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm8Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm8Regs.TBCTL.bit.SYNCOSEL = 1; // Sync Output Select: CTR = zero EPwm8Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm8Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm8Regs.TBCTL.bit.CLKDIV = TB_DIV1; // EPwm12Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)INV_PWM_HALF_TBPRD); EPwm8Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm8Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm8Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; EPwm8Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD; EPwm8Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm8Regs.AQCTLA.bit.CAD = AQ_SET; EPwm8Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm8Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm8Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm8Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm8Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm8Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm8Regs.DBRED.bit.DBRED = EPwm1_DB; EPwm8Regs.DBFED.bit.DBFED = EPwm1_DB; EPwm9Regs.TBPRD = INV_PWM_TBPRD; // Set timer period EPwm9Regs.TBPHS.bit.TBPHS = 0x0000; // Phase is 0 EPwm9Regs.TBCTR = 0x0000; // Clear counter EPwm9Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up-down EPwm9Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading EPwm9Regs.TBCTL.bit.SYNCOSEL = 1; // Sync Output Select: CTR = zero EPwm9Regs.rsvd2[0] = 0x0002; // EPWMxSYNCOUT Source Enable Register EPwm9Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT EPwm9Regs.TBCTL.bit.CLKDIV = TB_DIV1; // EPwm9Regs.CMPA.bit.CMPA = (Uint16)(fDutyCycle * (float32)INV_PWM_HALF_TBPRD); EPwm9Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO EPwm9Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm9Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD; EPwm9Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD; EPwm9Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Set PWM1A on Zero EPwm9Regs.AQCTLA.bit.CAD = AQ_SET; EPwm9Regs.AQCTLB.bit.CAU = AQ_SET; // Set PWM1A on Zero EPwm9Regs.AQCTLB.bit.CAD = AQ_CLEAR; EPwm9Regs.AQSFRC.bit.RLDCSF = 3; // Load immediately EPwm9Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm9Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; EPwm9Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm9Regs.DBRED.bit.DBRED = EPwm1_DB; EPwm9Regs.DBFED.bit.DBFED = EPwm1_DB; } // // ConfigureADC - Write ADC configurations and power up the ADC for both // ADC A and ADC B // void ConfigureADC(void) { Uint16 acqps; EALLOW; //write configurations AdcaRegs.ADCCTL2.bit.PRESCALE = 2; //set ADCCLK divider to /2.0 AdcSetMode(ADC_ADCA, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE); //Set pulse positions to late AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1; //power up the ADC AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1; //delay for 1ms to allow ADC time to power up DELAY_US(1000); EDIS; // Determine minimum acquisition window (in SYSCLKS) based on resolution if(ADC_RESOLUTION_12BIT == AdcaRegs.ADCCTL2.bit.RESOLUTION) { acqps = 14; //75ns } else //resolution is 16-bit { acqps = 63; //320ns } //Select the channels to convert and end of conversion flag EALLOW; AdcaRegs.ADCSOC0CTL.bit.CHSEL = 0; //SOC0 will convert pin A0 AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is 100 SYSCLK cycles AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = ADCTRIG; //ADCTRIG9 - ePWM3, ADCSOCA, ADCTRIG5 - ePWM1, ADCSOCA AdcaRegs.ADCSOC1CTL.bit.CHSEL = 1; AdcaRegs.ADCSOC1CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC1CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC2CTL.bit.CHSEL = 2; AdcaRegs.ADCSOC2CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC2CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC3CTL.bit.CHSEL = 3; AdcaRegs.ADCSOC3CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC3CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC4CTL.bit.CHSEL = 4; AdcaRegs.ADCSOC4CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC4CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC5CTL.bit.CHSEL = 5; AdcaRegs.ADCSOC5CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC5CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC6CTL.bit.CHSEL = 14; AdcaRegs.ADCSOC6CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC6CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCSOC7CTL.bit.CHSEL = 15; AdcaRegs.ADCSOC7CTL.bit.ACQPS = acqps; AdcaRegs.ADCSOC7CTL.bit.TRIGSEL = ADCTRIG; AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 5; //end of SOCx will set INT1 flag AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared EDIS; //For ADC-B EALLOW; //write configurations AdcbRegs.ADCCTL2.bit.PRESCALE = 2; //set ADCCLK divider to /2.0 AdcSetMode(ADC_ADCB, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE); //Set pulse positions to late AdcbRegs.ADCCTL1.bit.INTPULSEPOS = 1; //power up the ADC AdcbRegs.ADCCTL1.bit.ADCPWDNZ = 1; //delay for 1ms to allow ADC time to power up DELAY_US(1000); EDIS; // Determine minimum acquisition window (in SYSCLKS) based on resolution if(ADC_RESOLUTION_12BIT == AdcbRegs.ADCCTL2.bit.RESOLUTION) { acqps = 14; //75ns } else //resolution is 16-bit { acqps = 63; //320ns } //Select the channels to convert and end of conversion flag EALLOW; AdcbRegs.ADCSOC0CTL.bit.CHSEL = 0; //SOC0 will convert pin A0 AdcbRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is 100 SYSCLK cycles AdcbRegs.ADCSOC0CTL.bit.TRIGSEL = ADCTRIG; //ADCTRIG9 - ePWM3, ADCSOCA, ADCTRIG5 - ePWM1, ADCSOCA AdcbRegs.ADCSOC1CTL.bit.CHSEL = 1; AdcbRegs.ADCSOC1CTL.bit.ACQPS = acqps; AdcbRegs.ADCSOC1CTL.bit.TRIGSEL = ADCTRIG; AdcbRegs.ADCSOC2CTL.bit.CHSEL = 2; AdcbRegs.ADCSOC2CTL.bit.ACQPS = acqps; AdcbRegs.ADCSOC2CTL.bit.TRIGSEL = ADCTRIG; AdcbRegs.ADCINTSEL1N2.bit.INT1SEL = 5; //end of SOCx will set INT1 flag AdcbRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag AdcbRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared EDIS; } void Shutdown(void) { // software forced low on PWMA and PWMB // EPwm1Regs.AQCSFRC.bit.CSFA = 1; // EPwm1Regs.AQCSFRC.bit.CSFB = 1; // ***** THIS LINE HAS NO EFFECT ON PWMB ***** // PWM1B STAYS HIGH EALLOW; GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 0; GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 0; GpioCtrlRegs.GPADIR.bit.GPIO0 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO1 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO2 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO3 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO4 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO5 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO6 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO7 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO8 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO9 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO10 = 1; // output GpioCtrlRegs.GPADIR.bit.GPIO11 = 1; // output EDIS; GpioDataRegs.GPACLEAR.bit.GPIO0 = 1; GpioDataRegs.GPACLEAR.bit.GPIO1 = 1; GpioDataRegs.GPACLEAR.bit.GPIO2 = 1; GpioDataRegs.GPACLEAR.bit.GPIO3 = 1; GpioDataRegs.GPACLEAR.bit.GPIO4 = 1; GpioDataRegs.GPACLEAR.bit.GPIO5 = 1; GpioDataRegs.GPACLEAR.bit.GPIO6 = 1; GpioDataRegs.GPACLEAR.bit.GPIO7 = 1; GpioDataRegs.GPACLEAR.bit.GPIO8 = 1; GpioDataRegs.GPACLEAR.bit.GPIO9 = 1; GpioDataRegs.GPACLEAR.bit.GPIO10 = 1; GpioDataRegs.GPACLEAR.bit.GPIO11 = 1; usRunState = FAULT; usResumePWM = 0; fDutyCycle = 0.0; fDutyCycle2 = 0.0; fDutyCycle3 = 0.0; EPwm1_CMP = 0; EPwm2_CMP = 0; EPwm3_CMP = 0; fVerr = 0.0; fInt2 = 0.0; // fVoltCtrl = 0.0; fIerrA = 0.0; fIerrB = 0.0; fIerrC = 0.0; fIntA = 0.0; fIntB = 0.0; fIntC = 0.0; fCurrCtrlA = 0.0; fCurrCtrlB = 0.0; fCurrCtrlC = 0.0; } // // End of file //
