Part Number: MSP430FR6043
We would be interested in the CCS project that is used in the Application note https://www.ti.com/lit/an/slaa969/slaa969.pdf
Can we download it somewhere ?
Olivier
Olivier
Hi Olivier,
On the first page of the Application note, it says "The source files can be downloaded from USSSW_Lib_Gas". If you click on the hyperlink for "USSSW_Lib_Gas" it will take you to the right page, which I have linked here: http://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/USSSWLib/latest/index_FDS.html. Once you download the .zip file you need, you need to extract all, then go to CCS and click on Project > Import CCS Projects. You can then click Browse, find the extracted file, and import it to CCS.
Hope this helps.
Thank you very much for your answer. Nevertheless, the CCS project may not take muxA0/A1 into account in order to measure in a 2-dimensional way.
Are these modifications for this demonstration available ?
Let me check the code and get back to you by 7/30, but in the meantime, take a look at page 4 of the Application note for some more information on modifications and the following code on TI Resource Explorer: https://dev.ti.com/tirex/explore/node?node=AIbAesEBCdCOrbbj5il9sg__IOGqZri__LATEST&search=USSSW.
- Amruta
Hi Olivier,
The source code is provided as-is and does not have the modifications available; however, there are many code examples for the MSP430FR6043 at https://dev.ti.com/tirex/explore/node?node=ADKtHl0F1BdwZ3ZwpnHWjw__IOGqZri__LATEST that go over how to use the various peripherals for the device and can help modify the code to any specific needs.
Hope this helps,
Amruta
