EVM430F6736
Hi everyone,
i m working on evm430f6736 and I want to receive the meter data from the RS232 communication via an mcu.
to know the value of the voltage or current for example, you have to send a frame to the rs232 cable, I do that with a serial monitor and I receive a response frame like that
, now I want to decode it, how?
  • Hi  Marwane,
    If you want to decode, you need to follow the communication protocol. The complexity of the communication protocol determines the complexity of decoding.
  • thank you mr joe, i know that
  • Hi Marwance,
    You are welcome. If you have question, you can reply to us.
  • for the communication protocol it s RS232 so it s a serial communication. if you can decode a frame let me know, this is the code:
    //  Software for MSP430 based e-meters.
    //  THIS PROGRAM IS PROVIDED "AS IS". TI MAKES NO WARRANTIES OR
    //  REPRESENTATIONS, EITHER EXPRESS, IMPLIED OR STATUTORY,
    //  INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS
    //  FOR A PARTICULAR PURPOSE, LACK OF VIRUSES, ACCURACY OR
    //  COMPLETENESS OF RESPONSES, RESULTS AND LACK OF NEGLIGENCE.
    //  TI DISCLAIMS ANY WARRANTY OF TITLE, QUIET ENJOYMENT, QUIET
    //  POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY
    //  INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO THE PROGRAM OR
    //  YOUR USE OF THE PROGRAM.
    //  IN NO EVENT SHALL TI BE LIABLE FOR ANY SPECIAL, INCIDENTAL,
    //  CONSEQUENTIAL OR INDIRECT DAMAGES, HOWEVER CAUSED, ON ANY
    //  THEORY OF LIABILITY AND WHETHER OR NOT TI HAS BEEN ADVISED
    //  OF THE POSSIBILITY OF SUCH DAMAGES, ARISING IN ANY WAY OUT
    //  OF THIS AGREEMENT, THE PROGRAM, OR YOUR USE OF THE PROGRAM.
    //  EXCLUDED DAMAGES INCLUDE, BUT ARE NOT LIMITED TO, COST OF
    //  REMOVAL OR REINSTALLATION, COMPUTER TIME, LABOR COSTS, LOSS
    //  OF GOODWILL, LOSS OF PROFITS, LOSS OF SAVINGS, OR LOSS OF
    //  USE OR INTERRUPTION OF BUSINESS. IN NO EVENT WILL TI'S
    //  AGGREGATE LIABILITY UNDER THIS AGREEMENT OR ARISING OUT OF
    //  YOUR USE OF THE PROGRAM EXCEED FIVE HUNDRED DOLLARS
    //  (U.S.$500).
    //  Unless otherwise stated, the Program written and copyrighted
    //  by Texas Instruments is distributed as "freeware".  You may,
    //  only under TI's copyright in the Program, use and modify the
    //  Program without any charge or restriction.  You may
    //  distribute to third parties, provided that you transfer a
    //  copy of this license to the third party and the third party
    //  agrees to these terms by its first use of the Program. You
    //  must reproduce the copyright notice and any other legend of
    //  ownership on each copy or partial copy, of the Program.
    //  You acknowledge and agree that the Program contains
    //  copyrighted material, trade secrets and other TI proprietary
    //  information and is protected by copyright laws,
    //  international copyright treaties, and trade secret laws, as
    //  well as other intellectual property laws.  To protect TI's
    //  rights in the Program, you agree not to decompile, reverse
    //  engineer, disassemble or otherwise translate any object code
    //  versions of the Program to a human-readable form.  You agree
    //  that in no event will you alter, remove or destroy any
    //  copyright notice included in the Program.  TI reserves all
    //  rights not specifically granted under this license. Except
    //  as specifically provided herein, nothing in this agreement
    //  shall be construed as conferring by implication, estoppel,
    //  or otherwise, upon you, any license or other right under any
    //  TI patents, copyrights or trade secrets.
    //  You may not use the Program in non-TI devices.
    //  File: emeter-communications.c
    //  Steve Underwood <steve-underwood@ti.com>
    //  Texas Instruments Hong Kong Ltd.
    //  $Id: emeter-communication.c,v 1.18 2009/04/27 09:05:25 a0754793 Exp $
    /*! \file emeter-structs.h */
    #include <stdint.h>
    #if !defined(__MSP430__)
    #include <stdio.h>
    #include <fcntl.h>
    #include <stdlib.h>
    #include <unistd.h>
    #endif
    #if defined(__GNUC__)
    #include <signal.h>
    #endif
    #if defined(__MSP430__)
    #include <io.h>
    #endif
    #include <emeter-toolkit.h>
    #include "emeter-structs.h"
    #if defined(IEC62056_21_SUPPORT)
    #include "iec62056-21.h"
    #endif
    #if !defined(NULL)
    #define NULL    (void *) 0
    #endif
    #if defined(__MSP430__)  &&  defined(IEC62056_21_SUPPORT)
    uint8_t iec62056_21_address[] = "Node 1";
    uint8_t iec62056_21_address_len = 6;
    #endif
    enum
        MEASURES_ACTIVE_POWER                       = 0x01,
        MEASURES_TRIGONOMETRIC_REACTIVE_POWER       = 0x02,
        MEASURES_APPARENT_POWER                     = 0x04,
        MEASURES_VRMS                               = 0x08,
        MEASURES_IRMS                               = 0x10,
        MEASURES_POWER_FACTOR                       = 0x20,
        MEASURES_MAINS_FREQUENCY                    = 0x40,
        MEASURES_QUADRATURE_REACTIVE_POWER          = 0x80
    enum host_commands_e
        HOST_CMD_GET_METER_CONFIGURATION            = 0x56,
        HOST_CMD_SET_METER_CONSUMPTION              = 0x57,
        HOST_CMD_SET_RTC                            = 0x58,
        HOST_CMD_GET_RTC                            = 0x59,
        HOST_CMD_SET_PASSWORD                       = 0x60,
        HOST_CMD_GET_READINGS_PHASE_1               = 0x61,
        HOST_CMD_GET_READINGS_PHASE_2               = 0x62,
        HOST_CMD_GET_READINGS_PHASE_3               = 0x63,
        HOST_CMD_GET_READINGS_NEUTRAL               = 0x64,
        HOST_CMD_ERASE_FLASH_SEGMENT                = 0x70,
        HOST_CMD_SET_FLASH_POINTER                  = 0x71,
        HOST_CMD_FLASH_DOWNLOAD                     = 0x72,
        HOST_CMD_FLASH_UPLOAD                       = 0x73,
        HOST_CMD_ZAP_MEMORY_AREA                    = 0x74,
        HOST_CMD_SUMCHECK_MEMORY                    = 0x75,
        HOST_CMD_GET_RAW_ACTIVE_POWER_PHASE_1       = 0x91,
        HOST_CMD_GET_RAW_ACTIVE_POWER_PHASE_2       = 0x92,
        HOST_CMD_GET_RAW_ACTIVE_POWER_PHASE_3       = 0x93,
        HOST_CMD_GET_RAW_REACTIVE_POWER_PHASE_1     = 0x95,
        HOST_CMD_GET_RAW_REACTIVE_POWER_PHASE_2     = 0x96,
        HOST_CMD_GET_RAW_REACTIVE_POWER_PHASE_3     = 0x97,
        HOST_CMD_GET_RAW_ACTIVE_POWER_NEUTRAL       = 0x99,
        HOST_CMD_GET_RAW_REACTIVE_POWER_NEUTRAL     = 0x9D,
        HOST_CMD_CHECK_RTC_ERROR                    = 0xA0,
        HOST_CMD_RTC_CORRECTION                     = 0xA1,
        HOST_CMD_MULTIRATE_SET_PARAMETERS           = 0xC0,
        HOST_CMD_MULTIRATE_GET_PARAMETERS           = 0xC1,
        HOST_CMD_MULTIRATE_CLEAR_USAGE              = 0xC2,
        HOST_CMD_MULTIRATE_GET_USAGE                = 0xC3
    #if defined(__MSP430__)  &&  (defined(IEC1107_SUPPORT)  ||  defined(SERIAL_CALIBRATION_SUPPORT))
    #if defined(UART_PORT_3_SUPPORT)
    serial_msg_buf_t tx_msg[4];
    serial_msg_buf_t rx_msg[4];
    #elif defined(UART_PORT_2_SUPPORT)
    serial_msg_buf_t tx_msg[3];
    serial_msg_buf_t rx_msg[3];
    #elif defined(UART_PORT_1_SUPPORT)
    serial_msg_buf_t tx_msg[2];
    serial_msg_buf_t rx_msg[2];
    #elif defined(UART_PORT_0_SUPPORT)
    serial_msg_buf_t tx_msg[1];
    serial_msg_buf_t rx_msg[1];
    #endif
    #endif
    int is_calibration_enabled(void)
        return TRUE;
    #if defined(IEC62056_21_SUPPORT)  ||  defined(IEC1107_D_SUPPORT)
    int iec1107d_status;
    void send_1107d_report(void)
        int i;
        uint8_t x;
        uint8_t bcd[5];
        const uint8_t *s;
        static const uint8_t id[] = "/XXXXXXXXXX V1.00\r\n";
        static const uint8_t serial_number_tag[] = "1-0:0.0.9*255(";
        static const uint8_t property_number_tag[] = "1-0:0.0.0*255(";
        static const uint8_t energy_tag[] = "1-0:1.8.0*255(";
        static const uint8_t status_tag[] = "1-0:96.5.5*255(";
        static const uint8_t factory_number_tag[] = "0-0:96.1.255*255(";
        static const uint8_t even_parity[128] =
            0x00, 0x81, 0x82, 0x03, 0x84, 0x05, 0x06, 0x87,
            0x88, 0x09, 0x0A, 0x8B, 0x0C, 0x8D, 0x8E, 0x0F,
            0x90, 0x11, 0x12, 0x93, 0x14, 0x95, 0x96, 0x17,
            0x18, 0x99, 0x9A, 0x1B, 0x9C, 0x1D, 0x1E, 0x9F,
            0xA0, 0x21, 0x22, 0xA3, 0x24, 0xA5, 0xA6, 0x27,
            0x28, 0xA9, 0xAA, 0x2B, 0xAC, 0x2D, 0x2E, 0xAF,
            0x30, 0xB1, 0xB2, 0x33, 0xB4, 0x35, 0x36, 0xB7,
            0xB8, 0x39, 0x3A, 0xBB, 0x3C, 0xBD, 0xBE, 0x3F,
            0xC0, 0x41, 0x42, 0xC3, 0x44, 0xC5, 0xC6, 0x47,
            0x48, 0xC9, 0xCA, 0x4B, 0xCC, 0x4D, 0x4E, 0xCF,
            0x50, 0xD1, 0xD2, 0x53, 0xD4, 0x55, 0x56, 0xD7,
            0xD8, 0x59, 0x5A, 0xDB, 0x5C, 0xDD, 0xDE, 0x5F,
            0x60, 0xE1, 0xE2, 0x63, 0xE4, 0x65, 0x66, 0xE7,
            0xE8, 0x69, 0x6A, 0xEB, 0x6C, 0xED, 0xEE, 0x6F,
            0xF0, 0x71, 0x72, 0xF3, 0x74, 0xF5, 0xF6, 0x77,
            0x78, 0xF9, 0xFA, 0x7B, 0xFC, 0x7D, 0x7E, 0xFF,
        /* IEC1107 specifies 7 bit + even parity data. We want to use 8 bit data for calibration, so we
           use software generation for the parity bit. */
        /* If the password is set we are in calibration mode, and the IEC1107D messages should not be sent.
           After calibration is complete, the password may or may not have been cleared. If it is still set
           a reset of the MCU will restore normal operation. */
        if ((meter_status & PASSWORD_OK))
            return;
        iec1107d_status = 0;
    #if 0
        if (total_power > 0)
            iec1107d_status |= 0x80;
    #endif
    #if defined(SELF_TEST_SUPPORT)
        if (nv_parms.s.meter_failures != 0xFFFF)
            iec1107d_status |= 0x01;
    #endif
        i = 0;
        s = id;
        while (*s)
            tx_msg[0].buf.uint8[i++] = even_parity[*s++];
        tx_msg[0].buf.uint8[i++] = even_parity['\r'];
        tx_msg[0].buf.uint8[i++] = even_parity['\n'];
    #if 0
    #if 0
        if (nv_parms.s.property_number[0])
            s = property_number_tag;
            while (*s)
            s = nv_parms.s.property_number;
            while (*s)
            tx_msg[0].buf.uint8[i++] = even_parity[')'];
        if (nv_parms.s.serial_number[0])
            s = serial_number_tag;
            while (*s)
            s = nv_parms.s.serial_number;
            while (*s)
    #endif
        s = energy_tag;
        while (*s)
        bin2bcd32(bcd, (long int) &chan[0].current.active_power);
        tx_msg[0].buf.uint8[i++] = even_parity['0' + ((bcd[2] >> 4) & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + (bcd[2] & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + ((bcd[3] >> 4) & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + (bcd[3] & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + ((bcd[4] >> 4) & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + (bcd[4] & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['.'];
        bin2bcd16(bcd, 0);
        tx_msg[0].buf.uint8[i++] = even_parity['0' + ((bcd[1] >> 4) & 0xF)];
        tx_msg[0].buf.uint8[i++] = even_parity['0' + (bcd[1] & 0xF)];
        s = status_tag;
        while (*s)
        x = '0' + ((iec1107d_status >> 4) & 0xF);
        if (x > '9')
            x += 7;
        tx_msg[0].buf.uint8[i++] = even_parity[x];
        x = '0' + (iec1107d_status & 0xF);
        if (x > '9')
            x += 7;
    #if 0
        if (nv_parms.s.factory_number[0])
            s = factory_number_tag;
            while (*s)
            s = nv_parms.s.factory_number;
            while (*s)
    #endif
    #endif
        tx_msg[0].buf.uint8[i++] = even_parity['!'];
        send_message(0, i);
    #if 0
        #if defined(USART1TX_VECTOR)
        U1IE |= UTXIE1;
        #else
        U0IE |= UTXIE0;
        #endif
    #endif
    #endif
    int iec62056_21_process_ack(const uint8_t *msg, int len)
        return len;
    int iec62056_21_process_nak(const uint8_t *msg, int len)
        return len;
    int iec62056_21_process_ident(const uint8_t *msg, int len)
        return len;
    void iec62056_21_process_request(void)
        if (tx_msg[0].len == 0)
            send_1107d_report();
    int iec62056_21_process_header(const uint8_t *msg, int len)
        int i;
        for (i = 0;  i < len  &&  msg[i] != 2;  i++)
        return i;
    int iec62056_21_process_field(const uint8_t instance_id[6], const uint8_t *val, int len)
        return len;
    #endif
    #if defined(__MSP430__)  &&  (defined(IEC62056_21_SUPPORT)  ||  defined(IEC1107_SUPPORT)  ||  defined(SERIAL_CALIBRATION_SUPPORT))
    /* Interrupt routines to send serial messages. */
        #if defined(UART_PORT_0_SUPPORT)
            #if defined(__MSP430_HAS_UART0__)
    ISR(USART0RX, serial_rx_interrupt0)
    #if defined(IEC62056_21_SUPPORT)  ||  defined(DLT645_SUPPORT)
        uint8_t ch;
        ch = RXBUF0;
    #endif
    #if defined(UART0_IEC62056_21_SUPPORT)
        if (inter_char_timeout == 0)
            iec62056_21_rx_restart();
        inter_char_timeout = SAMPLES_PER_10_SECONDS/200;
            iec62056_21_rx_byte(ch & 0x7F);
    #endif
    #if defined(UART0_DLT645_SUPPORT)
        dlt645_rx_byte(0, ch);
    #endif
    ISR(USART0TX, serial_tx_interrupt0)
        TXBUF0 = tx_msg[0].buf.uint8[tx_msg[0].ptr++];
        if (tx_msg[0].ptr >= tx_msg[0].len)
            /* Stop transmission */
            U0IE &= ~UTXIE0;
            tx_msg[0].ptr = 0;
            tx_msg[0].len = 0;
            #elif defined(__MSP430_HAS_USCI_AB0__)
    ISR(USCIAB0RX, serial_rx_interrupt0)
        uint8_t ch;
        ch = UCA0RXBUF;
        //if (inter_char_timeout == 0)
        //    iec62056_21_rx_restart();
        //inter_char_timeout = SAMPLES_PER_10_SECONDS/200;
    #endif
    #endif
    ISR(USCIAB0TX, serial_tx_interrupt0)
        UCA0TXBUF = tx_msg[0].buf.uint8[tx_msg[0].ptr++];
            UC0IE &= ~UCA0TXIE;
            tx_msg[0].ptr = 0;
            tx_msg[0].len = 0;
            #elif defined(__MSP430_HAS_USCI_A0__)
    ISR(USCI_A0, serial_interrupt0)
        uint8_t ch;
        switch(__even_in_range(UCA0IV,USCI_UART_UCRXIFG))
        case USCI_UART_UCRXIFG:
        ch = UCA0RXBUF;
    #endif
    #endif
        break;
        case USCI_UART_UCTXIFG:
            UCA0IE &= ~UCTXIE;
            tx_msg[0].ptr = 0;
            tx_msg[0].len = 0;
        break;
            #elif defined(__MSP430_HAS_EUSCI_A0__)
        uint8_t ch;
        switch(__even_in_range(UCA0IV,USCI_UART_UCTXCPTIFG))
        case USCI_NONE:
        break;
        ch = UCA0RXBUF;
    #endif
    #endif
        break;
            UCA0IE &= ~UCTXIE;
            tx_msg[0].ptr = 0;
            tx_msg[0].len = 0;
        break;
        case USCI_UART_UCSTTIFG:
        break;
        case USCI_UART_UCTXCPTIFG:
        break;
            #else
                #error Device does not have a UART port 0
            #endif
        #endif
        #if defined(UART_PORT_1_SUPPORT)
            #if defined(__MSP430_HAS_UART1__)
    ISR(USART1RX, serial_rx_interrupt1)
        uint8_t ch;
        ch = RXBUF1;
    #if defined(UART1_IEC62056_21_SUPPORT)
    #endif
    #if defined(UART1_DLT645_SUPPORT)
        dlt645_rx_byte(1, ch);
    #endif
    ISR(USART1TX, serial_tx_interrupt1)
        TXBUF1 = tx_msg[1].uint8[tx_msg[1].ptr++];
        if (tx_msg[1].ptr >= tx_msg[1].len)
            U1IE &= ~UTXIE1;
            tx_msg[1].ptr = 0;
            tx_msg[1].len = 0;
            #elif defined(__MSP430_HAS_USCI_AB1__)
    ISR(USCIAB1RX, serial_rx_interrupt1)
        uint8_t ch;
        ch = UCA1RXBUF;
    #endif
    #endif
    ISR(USCIAB1TX, serial_tx_interrupt1)
        UCA1TXBUF = tx_msg[1].buf.uint8[tx_msg[1].ptr++];
            UC1IE &= ~UCA1TXIE;
            tx_msg[1].ptr = 0;
            tx_msg[1].len = 0;
            #elif defined(__MSP430_HAS_USCI_A1__)
    ISR(USCI_A1, serial_interrupt1)
        uint8_t ch;
        switch(__even_in_range(UCA1IV,USCI_UART_UCRXIFG))
        ch = UCA1RXBUF;
        if (tx_msg[1].len == 0)
    #endif
    #endif
        break;
        UCA0TXBUF = tx_msg[1].buf.uint8[tx_msg[1].ptr++];
            UCA1IE &= ~UCTXIE;
            tx_msg[1].ptr = 0;
            tx_msg[1].len = 0;
        break;
            #elif defined(__MSP430_HAS_EUSCI_A1__)
        uint8_t ch;
        switch(__even_in_range(UCA1IV,USCI_UART_UCTXCPTIFG))
        ch = UCA1RXBUF;
    #endif
    #endif
        break;
            UCA1IE &= ~UCTXIE;
            tx_msg[1].ptr = 0;
            tx_msg[1].len = 0;
        break;
        break;
        break;
            #else
                #error Device does not have a UART port 1
            #endif
        #endif
        #if defined(UART_PORT_2_SUPPORT)
            #if defined(__MSP430_HAS_USCI_AB2__)
    ISR(USCIAB2TX, serial_tx_interrupt2)
        UCA2TXBUF = tx_msg[2].uint8[tx_msg[2].ptr++];
        if (tx_msg[2].ptr >= tx_msg[2].len)
            UC2IE &= ~UCA2TXIE;
            tx_msg[2].ptr = 0;
            tx_msg[2].len = 0;
            #else
                #error Device does not have a UART port 2
            #endif
        #endif
            #if defined(__MSP430_HAS_USCI_AB3__)
    ISR(USCIAB3TX, serial_tx_interrupt3)
        UCA3TXBUF = tx_msg[3].uint8[tx_msg[3].ptr++];
        if (tx_msg[3].ptr >= tx_msg[3].len)
            UC3IE &= ~UCA3TXIE;
            tx_msg[3].ptr = 0;
            tx_msg[3].len = 0;
            #else
                #error Device does not have a UART port 3
            #endif
        #endif
    void send_message(int port, int len)
        tx_msg[port].ptr = 0;
        tx_msg[port].len = len;
        switch (port)
        case 0:
            U0IE |= UTXIE0;
            #elif defined(__MSP430_HAS_USCI_A0__) || defined(__MSP430_HAS_EUSCI_A0__)
            UCA0IE |= UCTXIE;
            #else
            UC0IE |= UCA0TXIE;
            #endif
            break;
        #endif
        case 1:
            U1IE |= UTXIE1;
            #elif defined(__MSP430_HAS_USCI_A1__) || defined(__MSP430_HAS_EUSCI_A1__)
            UCA1IE |= UCTXIE;
            #else
            UC1IE |= UCA1TXIE;
            #endif
            break;
        #endif
        case 2:
            UC2IE |= UCA2TXIE;
            break;
        #endif
        case 3:
            UC3IE |= UCA3TXIE;
            break;
        #endif
    #endif
  • Hi Marwane,
    For code example, you can refer to this link:MSP430F673X_USCIA0_UART_03.c (ti.com)
    Best regards
    Joe
