Part Number: MSP430F5310
How to generate binary file for MSP430F5310?
Hi Nidheesh,
If you want a text file, you can follow the step-by-step instructions found in this thread under the "Using CCS v6.x" tutorial (it will work for the current version of CCS you have now as well). The generated .txt file can be found under the "Debug" folder of the project after you build it. This is the most straightforward method.
If you want a bin file, you can generate a binary file from any TI executable using the tiobj2bin command found in the cg_xml tools. If you would like more specifics on how to use this command, run tiobj2bin from the command line with no arguments and it will dump a one-line help summary.
Hope this helps!
Amruta
