Hi there,
Can you view the disassembly to find what makes you get stuck, and then give me the description? It will be helpful for analyzation.
Sometimes it happens when you do the operation which is linked with the static library, this will not make the impact on your code operation (always occur when you suspend the code, and recover after running).
More often, it happens due to your code running error, this need you location your code and do the analysis. Possible reason may be that you made the variable overflow.
Best Regards
Sal
