Hi Mallesha,
Can you try the solution from this thread? https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1213407/msp430fr2355-verification-failed-values-at-address-0x08000-do-not-match-please-verify-target-memory-and-memory-map
Brandon Fisher
My firmware engineer released the firmware in .txt file format, and when we attempted to flash it using UniFlash, we encountered an issue. However, when we used the .obj file, we did not encounter any errors
Hi Mallesha,
What tool are you using to generate your .txt and .obj files? Are you using CCS or something else?
Brandon Fisher
Thanks Mallesha,
I assume you are using the MSP430 Hex Utility to generate your .txt file, but i want to be sure that all of the settings looks correct. Can you share a capture of the MSP430 Hex Utility settings in the project properties of your CCS?
Or otherwise share how you are generating the .txt file.
Brandon Fisher
