Part Number: MSP430FR5994
Hi,teams
I want to add IEC60730-related content to the code. I would like to consult. In the routine given by the system, the ADC reference voltage selects the internal reference voltage. In the function library called, the judgment is also based on the internal reference voltage. If I How to modify the corresponding library when an external voltage is selected as the reference voltage?
example:
adcTestHandle.muxChannel=15;
adcTestHandle.pinCount=0x3FF;
adcTestHandle.useInternalInput=INT_REF_1_5_V;
The following are the functions in the library
In the “IEC60730_ADC_TEST_testAdcInput ”function, the internal reference voltage is used to judge the function of the ADC module
/* --COPYRIGHT--,BSD
* Copyright (c) 2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* --/COPYRIGHT--*/
//! \addtogroup adc_test_api
//IEC60730_adc_test.c - ADC Tests for IEC60730 Class B.
#include <msp430.h>
#include "IEC60730_adc_test.h"
#include "IEC60730_user_config.h"
#include "IEC60730_system_config.h"
#include "stdint.h"
//! Tests functionality of ADC converter
//! \param adcTestHandle contains parameter to test ADC channel.
//! This function performs a plausibility check on the ADC10 or ADC12 module.
//! The proper operation of the pin mux selection, and the A/D converter is
//! checked with this function.
//! Before calling this API the user must set values for pinCount, useInternalInput,
//! and muxChannel in IEC60730_ADC_TEST_adcTest_Handle structure.
//! The ADC conversion result is compared with "pinCount" value. The user can
//! define the acceptable ADC count drift by adjusting the values of
//! MINIMUM_ADC_COUNT_DRIFT and MAXIMUM_ADC_COUNT_DRIFT macros in
//! "IEC60730_user_config.h" file.
//! Modified registers are \b ADCxxCTL0
//! \return SIG_ADC_TEST.- if the counts provided by the user match the
//! converted counts.
//! TEST_FAILED. - if ADC test fail and JUMP_TO_FAILSAFE is disabled
//! in "IEC60730_user_config.h".
uint8_t IEC60730_ADC_TEST_testAdcInput(IEC60730_ADC_TEST_adcTest_Handle* adcTestHandle){
int16_t adcCountDelta;
// Feed WDT in case user has WDT enabled before running CPU test
#if ENABLED_WDT
uint16_t wdtConfig = WDTCTL & 0x00ff;
WDTCTL = WDTPW + WDTCNTCL + wdtConfig;
#endif // ENABLED_WDT
#if defined (__MSP430_HAS_ADC12_PLUS__)
// Verify ADC channel selected is valid
if(adcTestHandle->muxChannel>17 || adcTestHandle ->useInternalInput>2){
return TEST_FAILURE;
// If user wants to use ADC channel to sample internal channel (e.g. Vref)
if(adcTestHandle->useInternalInput>0 && adcTestHandle->useInternalInput<3){
// Verify that user has reference generator on
if(!ADC12CTL0&ADC12REFON){
// Verify that user has selected correct reference voltage
if(adcTestHandle->useInternalInput==1 && ADC12CTL0 & ADC12REF2_5V){
}else if (adcTestHandle->useInternalInput==2 && !ADC12CTL0 & ADC12REF2_5V){
// Verify that ADC12 is in single-conversion mode
if(ADC12CTL2 & (ADC12CONSEQ0 + ADC12CONSEQ0) != 0){
// Verify user has correct ADC channel mapped to ADCMEM0
if (!(ADC12MCTL0&(adcTestHandle->muxChannel*0x0001u))){
// Enable conversions
ADC12CTL0 |= ADC12ENC + ADC12SC;
// Poll ADC12IFG
while(!(ADC12IFG & ADC12IFG0));
ADC12CTL0 &= ~(ADC12ENC + ADC12SC);
// Calculate ADC conversion Error
adcCountDelta= ADC12MEM0 - adcTestHandle->pinCount;
ADC12CTL0 &= ~(ADC12IFG0);
// Determine if ADC conversion is within user defined +/- ADC drift
if((adcCountDelta > MINIMUM_ADC_COUNT_DRIFT) && (adcCountDelta < MAXIMUM_ADC_COUNT_DRIFT)){
return(SIG_ADC_TEST);
#endif //__MSP430_HAS_ADC12_PLUS__
#if defined (__MSP430_HAS_ADC10__)
if(adcTestHandle->muxChannel>11 || adcTestHandle ->useInternalInput>2){
// Check if user wants to use internal voltage reference for conversion
if(!ADC10CTL0&REFON){
if(adcTestHandle->useInternalInput==1 && ADC10CTL0&REF2_5V){
}else if (adcTestHandle->useInternalInput==2 && !ADC10CTL0&REF2_5V){
// Verify user has the correct ADC channel selected
if (!(ADC10CTL1&(adcTestHandle->muxChannel*0x1000u))){
// Start ADC conversion
ADC10CTL0 &= ~(ADC10IFG);
ADC10CTL0 |= ENC + ADC10SC;
// Poll ADC10IFG
while(!(ADC10CTL0 & ADC10IFG));
// Stop ADC conversion
ADC10CTL0 &= ~(ENC + ADC10SC);
adcCountDelta= ADC10MEM - adcTestHandle->pinCount;
#endif //__MSP430_HAS_ADC10__
#if defined (__MSP430_HAS_ADC10_B__)
if(adcTestHandle->muxChannel>16 || adcTestHandle ->useInternalInput>2){
if(!REFCTL0&REFON){
if(adcTestHandle->useInternalInput==INT_REF_1_5_V && !((REFCTL0&REFVSEL_0)==REFVSEL_0)){
}else if (adcTestHandle->useInternalInput==INT_REF_2_0_V && !((REFCTL0&REFVSEL_1)==REFVSEL_1)){
}else if (adcTestHandle->useInternalInput==INT_REF_2_5_V && !(((REFCTL0&REFVSEL_2)==REFVSEL_2) || ((REFCTL0&REFVSEL_3)==REFVSEL_3))){
if (!(ADC10MCTL0&(adcTestHandle->muxChannel*0x0001u))){
ADC10CTL0 |= ADC10ENC + ADC10SC;
ADC10IFG &= ~(ADC10IFG0);
// Poll ADC10IFG
while(!ADC10IFG & ADC10IFG0);
ADC10CTL0 &= ~(ADC10ENC + ADC10SC);
adcCountDelta= ADC10MEM0 - adcTestHandle->pinCount;
#endif //__MSP430_HAS_ADC10B__
#if defined (__MSP430_HAS_ADC12_B__)
if(adcTestHandle->muxChannel>32 || adcTestHandle ->useInternalInput>2){
if(!REFCTL0&REFON){
if(adcTestHandle->useInternalInput==INT_REF_1_2_V && !((REFCTL0&REFVSEL_0)==REFVSEL_0)){
ADC12IFGR0 &= ~(ADC12IFG0);
// Poll ADC12IFG
while(!ADC12IFGR0 & ADC12IFG0);
#endif //__MSP430_HAS_ADC12B__
#if defined (__MSP430_HAS_ADC__)
// Verify ADC channel selected is valid ADC module can have 8 or 10 external
// ADC channels and still has internal channels to monitor on chip
// temperature sensor (A12), Vref (A13), Vcc(A14), and Vss(A15)
// In addition ADC module only has Internal 1.5V reference
if(adcTestHandle->muxChannel>16 || adcTestHandle ->useInternalInput>1){
if(adcTestHandle->useInternalInput == INT_REF_1_5_V )
if(!(PMMCTL2 & INTREFEN))
// No need to verify is user has selected correct reference voltage
// since there is only one reference voltage in this family (1.5V)
// Verify ADC module is ON
if(!(ADCCTL0 & ADCON))
// Verify ADC conversion can be triggered via ADCSC bit
if(ADCCTL1 & ADCSHS_3)
// Verify user has the correct ADC channel selected and ADC is in sigle
// channel conversion mode
if((ADCMCTL0_L & 0x0f) != adcTestHandle->muxChannel)
// Verify ADC conversion mode is in single-channel single-conversion mode
if(ADCCTL1_L & ADCCONSEQ_3)
ADCCTL0 |= (ADCENC | ADCSC);
// Poll ADCBUSY Flag
while(ADCCTL1 & ADCBUSY);
adcCountDelta= ADCMEM0 - adcTestHandle->pinCount;
#endif
// Close the Doxygen group.
now,I want to change the reference voltage to an external voltage
adcTestHandle.useInternalInput= EXTERNAL_REF;
How should I modify the content inside the “IEC60730_ADC_TEST_testAdcInput ” function?
